cs_lagr_particle_set_t Struct Reference
#include <cs_lagr_particle.h>
+ Collaboration diagram for cs_lagr_particle_set_t:
Public Member Functions
 cs_lagr_particle_set_t ()
 Default constructor. More...
 cs_lagr_particle_set_t (cs_lnum_t n_part_max, const cs_lagr_attribute_map_t *map)
 Constructor. More...
 cs_lagr_particle_set_t (const cs_lagr_particle_set_t &other)
 Copy constructor (shallow copy) More...
CS_F_HOST_DEVICE cs_lagr_particle_set_t (cs_lagr_particle_set_t &&other)
 Move constructor. More...
 ~cs_lagr_particle_set_t ()
 Default destructor. More...
CS_F_HOST_DEVICE cs_lagr_particle_set_t & operator= (cs_lagr_particle_set_t other)
 Assignment operator. More...
CS_F_HOST int resize (const cs_lnum_t n_particles_max_min)
 Resize particles set. More...
template<typename T >
CS_F_HOST_DEVICE T & attr (cs_lnum_t particle_id, cs_lagr_attribute_t attr)
 Access attribute based on particle id and a given type. More...
CS_F_HOST_DEVICE T & attr (cs_lnum_t particle_id, cs_lagr_attribute_t attr) const
 Access attribute based on particle id and a given type from a const particle set. More...
CS_F_HOST_DEVICE T & attr_n (cs_lnum_t particle_id, int time_id, cs_lagr_attribute_t attr)
 Access attribute based on particle id, time id and a given type. More...
CS_F_HOST_DEVICE T & attr_n (cs_lnum_t p_id, int time_id, cs_lagr_attribute_t attr) const
 Access attribute based on particle id, time id and a given type for a const particle set. More...
CS_F_HOST_DEVICE T * attr_get_ptr (cs_lnum_t p_id, cs_lagr_attribute_t attr)
 Get a pointer to attribute values. More...
CS_F_HOST_DEVICE const T * attr_get_const_ptr (cs_lnum_t p_id, cs_lagr_attribute_t attr)
 Get a const pointer to attribute values. More...
CS_F_HOST_DEVICE T * attr_n_get_ptr (cs_lnum_t p_id, int time_id, cs_lagr_attribute_t attr)
CS_F_HOST_DEVICE const T * attr_n_get_const_ptr (cs_lnum_t p_id, int time_id, cs_lagr_attribute_t attr)
CS_F_HOST_DEVICE int flag (cs_lnum_t p_id, int mask)
 Check if a flag is set for a given particle based on a mask. More...
CS_F_HOST_DEVICE void set_flag (cs_lnum_t p_id, int mask)
 Set flag for a given particle. More...
CS_F_HOST_DEVICE void unset_flag (cs_lnum_t p_id, int mask)
 Unset a flag for a given particle. More...
CS_F_HOST_DEVICE cs_real_t * source_terms (cs_lnum_t p_id, cs_lagr_attribute_t attr)
 Get pointer to 2nd order scheme source terms for an attribute of a given particle in a set. More...
CS_F_HOST_DEVICE const cs_real_t * source_terms_const (cs_lnum_t p_id, cs_lagr_attribute_t attr)
template<typename... Args>
auto attr_real (Args &&... args) -> decltype(attr< cs_real_t >(std::forward< Args >(args)...))
auto attr_lnum (Args &&... args) -> decltype(attr< cs_lnum_t >(std::forward< Args >(args)...))
auto attr_gnum (Args &&... args) -> decltype(attr< cs_gnum_t >(std::forward< Args >(args)...))
auto attr_n_real (Args &&... args) -> decltype(attr_n< cs_real_t >(std::forward< Args >(args)...))
auto attr_n_lnum (Args &&... args) -> decltype(attr_n< cs_lnum_t >(std::forward< Args >(args)...))
auto attr_n_gnum (Args &&... args) -> decltype(attr_n< cs_gnum_t >(std::forward< Args >(args)...))
auto attr_real_ptr (Args &&... args) -> decltype(attr_get_ptr< cs_real_t >(std::forward< Args >(args)...))
auto attr_lnum_ptr (Args &&... args) -> decltype(attr_get_ptr< cs_lnum_t >(std::forward< Args >(args)...))
auto attr_gnum_ptr (Args &&... args) -> decltype(attr_get_ptr< cs_gnum_t >(std::forward< Args >(args)...))
auto attr_real_const_ptr (Args &&... args) -> decltype(attr_get_const_ptr< cs_real_t >(std::forward< Args >(args)...))
auto attr_lnum_const_ptr (Args &&... args) -> decltype(attr_get_const_ptr< cs_lnum_t >(std::forward< Args >(args)...))
auto attr_gnum_const_ptr (Args &&... args) -> decltype(attr_get_const_ptr< cs_gnum_t >(std::forward< Args >(args)...))
auto attr_n_real_ptr (Args &&... args) -> decltype(attr_n_get_ptr< cs_real_t >(std::forward< Args >(args)...))
auto attr_n_lnum_ptr (Args &&... args) -> decltype(attr_n_get_ptr< cs_lnum_t >(std::forward< Args >(args)...))
auto attr_n_gnum_ptr (Args &&... args) -> decltype(attr_n_get_ptr< cs_gnum_t >(std::forward< Args >(args)...))
auto attr_n_real_const_ptr (Args &&... args) -> decltype(attr_n_get_const_ptr< cs_real_t >(std::forward< Args >(args)...))
auto attr_n_lnum_const_ptr (Args &&... args) -> decltype(attr_n_get_const_ptr< cs_lnum_t >(std::forward< Args >(args)...))
auto attr_n_gnum_const_ptr (Args &&... args) -> decltype(attr_n_get_const_ptr< cs_gnum_t >(std::forward< Args >(args)...))
Public Attributes
cs_lnum_t n_part_new
cs_lnum_t n_part_out
cs_lnum_t n_part_merged
cs_lnum_t n_part_dep
cs_lnum_t n_part_fou
cs_lnum_t n_part_resusp
cs_lnum_t n_failed_part
cs_real_t weight
cs_real_t weight_new
cs_real_t weight_out
cs_real_t weight_merged
cs_real_t weight_dep
cs_real_t weight_fou
cs_real_t weight_resusp
cs_real_t weight_failed
const cs_lagr_attribute_map_t * p_am
unsigned char * p_buffer
Constructor & Destructor Documentation
◆ cs_lagr_particle_set_t() [1/4]
◆ cs_lagr_particle_set_t() [2/4]
cs_lagr_particle_set_t ( cs_lnum_t  n_part_max,
const cs_lagr_attribute_map_t *  map
Constructor.
[in]n_part_maxMaximal number of particles
[in]mapAttribute map
◆ cs_lagr_particle_set_t() [3/4]
[in]otherreference to other set
◆ cs_lagr_particle_set_t() [4/4]
Move constructor.
[in]other&& reference for move
◆ ~cs_lagr_particle_set_t()
Default destructor.
Member Function Documentation
◆ attr() [1/2]
CS_F_HOST_DEVICE T & attr ( cs_lnum_t  particle_id,
inline
Template Parameters
T: type used to cast attribute.
reference to attribute of type "T"
[in]particle_idParticle id
[in]attrattribute id (enum)
◆ attr() [2/2]
) const
inline
Template Parameters
◆ attr_get_const_ptr()
CS_F_HOST_DEVICE const T * attr_get_const_ptr ( cs_lnum_t  p_id,
inline
Template Parameters
const pointer of type T*
[in]p_idparticle id
◆ attr_get_ptr()
CS_F_HOST_DEVICE T * attr_get_ptr ( cs_lnum_t  p_id,
inline
Template Parameters
pointer of type T*
[in]p_idparticle id
◆ attr_gnum()
auto attr_gnum ( Args &&...  args) -> decltype(attr<cs_gnum_t>(std::forward<Args>(args)...))
inline
◆ attr_gnum_const_ptr()
auto attr_gnum_const_ptr ( Args &&...  args) -> decltype(attr_get_const_ptr<cs_gnum_t>(std::forward<Args>(args)...))
inline
◆ attr_gnum_ptr()
auto attr_gnum_ptr ( Args &&...  args) -> decltype(attr_get_ptr<cs_gnum_t>(std::forward<Args>(args)...))
inline
◆ attr_lnum()
auto attr_lnum ( Args &&...  args) -> decltype(attr<cs_lnum_t>(std::forward<Args>(args)...))
inline
◆ attr_lnum_const_ptr()
auto attr_lnum_const_ptr ( Args &&...  args) -> decltype(attr_get_const_ptr<cs_lnum_t>(std::forward<Args>(args)...))
inline
◆ attr_lnum_ptr()
auto attr_lnum_ptr ( Args &&...  args) -> decltype(attr_get_ptr<cs_lnum_t>(std::forward<Args>(args)...))
inline
◆ attr_n() [1/2]
CS_F_HOST_DEVICE T & attr_n ( cs_lnum_t  p_id,
int  time_id,
) const
inline
Template Parameters
[in]p_idParticle id
[in]time_idtime id
◆ attr_n() [2/2]
CS_F_HOST_DEVICE T & attr_n ( cs_lnum_t  particle_id,
int  time_id,
inline
Template Parameters
[in]time_idtime id
◆ attr_n_get_const_ptr()
CS_F_HOST_DEVICE const T * attr_n_get_const_ptr ( cs_lnum_t  p_id,
int  time_id,
inline
Template Parameters
[in]p_idparticle id
[in]time_idtime id
◆ attr_n_get_ptr()
CS_F_HOST_DEVICE T * attr_n_get_ptr ( cs_lnum_t  p_id,
int  time_id,
inline
Template Parameters
pointer of type T*
[in]p_idparticle id
[in]time_idtime id
◆ attr_n_gnum()
auto attr_n_gnum ( Args &&...  args) -> decltype(attr_n<cs_gnum_t>(std::forward<Args>(args)...))
inline
◆ attr_n_gnum_const_ptr()
auto attr_n_gnum_const_ptr ( Args &&...  args) -> decltype(attr_n_get_const_ptr<cs_gnum_t>(std::forward<Args>(args)...))
inline
◆ attr_n_gnum_ptr()
auto attr_n_gnum_ptr ( Args &&...  args) -> decltype(attr_n_get_ptr<cs_gnum_t>(std::forward<Args>(args)...))
inline
◆ attr_n_lnum()
auto attr_n_lnum ( Args &&...  args) -> decltype(attr_n<cs_lnum_t>(std::forward<Args>(args)...))
inline
◆ attr_n_lnum_const_ptr()
auto attr_n_lnum_const_ptr ( Args &&...  args) -> decltype(attr_n_get_const_ptr<cs_lnum_t>(std::forward<Args>(args)...))
inline
◆ attr_n_lnum_ptr()
auto attr_n_lnum_ptr ( Args &&...  args) -> decltype(attr_n_get_ptr<cs_lnum_t>(std::forward<Args>(args)...))
inline
◆ attr_n_real()
auto attr_n_real ( Args &&...  args) -> decltype(attr_n<cs_real_t>(std::forward<Args>(args)...))
inline
◆ attr_n_real_const_ptr()
auto attr_n_real_const_ptr ( Args &&...  args) -> decltype(attr_n_get_const_ptr<cs_real_t>(std::forward<Args>(args)...))
inline
◆ attr_n_real_ptr()
auto attr_n_real_ptr ( Args &&...  args) -> decltype(attr_n_get_ptr<cs_real_t>(std::forward<Args>(args)...))
inline
◆ attr_real()
auto attr_real ( Args &&...  args) -> decltype(attr<cs_real_t>(std::forward<Args>(args)...))
inline
◆ attr_real_const_ptr()
auto attr_real_const_ptr ( Args &&...  args) -> decltype(attr_get_const_ptr<cs_real_t>(std::forward<Args>(args)...))
inline
◆ attr_real_ptr()
auto attr_real_ptr ( Args &&...  args) -> decltype(attr_get_ptr<cs_real_t>(std::forward<Args>(args)...))
inline
◆ flag()
CS_F_HOST_DEVICE int flag ( cs_lnum_t  p_id,
int  mask
inline
1 if mask is set, 0 otherwise
[in]p_idparticle id
[in]maskmask
◆ operator=()
◆ resize()
CS_F_HOST int resize ( const cs_lnum_t  n_particles_max_min)
Resize the particle set.
[in]n_particles_max_minminimum local max number of particles
◆ set_flag()
CS_F_HOST_DEVICE void set_flag ( cs_lnum_t  p_id,
int  mask
inline
[in]p_idparticle id
[in]maskmask
◆ source_terms()
CS_F_HOST_DEVICE cs_real_t * source_terms ( cs_lnum_t  p_id,
inline
[in]p_idparticle id
[in]attrrequested attribute id
pointer to current attribute data
◆ source_terms_const()
CS_F_HOST_DEVICE const cs_real_t * source_terms_const ( cs_lnum_t  p_id,
inline
[in]p_idparticle id
◆ unset_flag()
CS_F_HOST_DEVICE void unset_flag ( cs_lnum_t  p_id,
int  mask
inline
[in]p_idparticle id
[in]maskmask
Member Data Documentation
◆ n_failed_part
◆ n_part_dep
◆ n_part_fou
◆ n_part_merged
◆ n_part_new
◆ n_part_out
◆ n_part_resusp
◆ n_particles
◆ n_particles_max
◆ p_am
particle attributes maps (p_am + i for time n-i)
◆ p_buffer
unsigned char* p_buffer
Particles data buffer
◆ weight
cs_real_t weight
◆ weight_dep
◆ weight_failed
◆ weight_fou
◆ weight_merged
◆ weight_new
◆ weight_out
◆ weight_resusp
