cs_lagr_sde.h
1#ifndef CS_LAGR_LAGESP_H
2#define CS_LAGR_LAGESP_H
5 * Functions and types for LAGESP
30#include "base/cs_defs.h"
32/*----------------------------------------------------------------------------*/
34#if defined(__cplusplus)
36/*============================================================================
37 * Public function prototypes
56/*----------------------------------------------------------------------------*/
57
58void
60 cs_lnum_t p_id,
61 cs_real_t dt_part,
62 int nor,
63 const cs_array<cs_real_t>& taup,
64 const cs_array_2d<cs_real_t>& tlag,
65 const cs_array_2d<cs_real_t>& piil,
66 const cs_array_3d<cs_real_t>& bx,
67 const cs_array_2d<cs_real_t>& vagaus,
68 const cs_real_6_t brgaus,
69 const cs_real_3_t force_p,
70 const cs_real_3_t beta);
71
72/*----------------------------------------------------------------------------*/
96/*----------------------------------------------------------------------------*/
97
98void
100 cs_lnum_t p_id,
101 cs_real_t dt_part,
102 int nor,
103 const cs_array<cs_real_t>& taup,
104 const cs_array_2d<cs_real_t>& tlag,
105 const cs_array_2d<cs_real_t>& piil,
106 const cs_array_3d<cs_real_t>& bx,
107 cs_real_t *tsfext,
108 const cs_real_3_t force_p,
109 const cs_real_t vislen[],
110 const cs_real_3_t beta,
112 cs_real_6_t brgaus,
113 cs_lnum_t *nresnew);
114
115/*----------------------------------------------------------------------------*/
135void
137 const cs_lnum_t p_id,
138 int nor,
139 const cs_real_t dt_part,
140 cs_real_t tcarac,
141 cs_real_t pip);
142
143/*----------------------------------------------------------------------------*/
144
145#endif /* __cplusplus */
146
147#endif /* CS_LAGR_LAGESP_H */
Define a templated array class (owner of data)
Definition: cs_array.h:1118
Definition: cs_defs.h:332
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:349
cs_real_t cs_real_6_t[6]
Definition: cs_defs.h:351
Definition: cs_defs.h:325
cs_lagr_attribute_t
Definition: cs_lagr_particle.h:76
void cs_lagr_sde_attr(cs_lagr_attribute_t attr, const cs_lnum_t p_id, int nor, const cs_real_t dt_part, cs_real_t tcarac, cs_real_t pip)
Integration of a stochastic differential equation (SDE) for a user particle variable (attribute).
Definition: cs_lagr_sde.cpp:3700
void cs_sde_vels_pos_1_st_order_time_integ(cs_lagr_particle_set_t &p_set, cs_lnum_t p_id, cs_real_t dt_part, int nor, const cs_array< cs_real_t > &taup, const cs_array_2d< cs_real_t > &tlag, const cs_array_2d< cs_real_t > &piil, const cs_array_3d< cs_real_t > &bx, const cs_array_2d< cs_real_t > &vagaus, const cs_real_6_t brgaus, const cs_real_3_t force_p, const cs_real_3_t beta)
Integration of SDEs by 1st order time scheme for one particle.
Definition: cs_lagr_sde.cpp:1029
void cs_lagr_sde(cs_lagr_particle_set_t &p_set, cs_lnum_t p_id, cs_real_t dt_part, int nor, const cs_array< cs_real_t > &taup, const cs_array_2d< cs_real_t > &tlag, const cs_array_2d< cs_real_t > &piil, const cs_array_3d< cs_real_t > &bx, cs_real_t *tsfext, const cs_real_3_t force_p, const cs_real_t vislen[], const cs_real_3_t beta, cs_array_2d< cs_real_t > &vagaus, cs_real_6_t brgaus, cs_lnum_t *nresnew)
Integration of particle equations of motion:
Definition: cs_lagr_sde.cpp:3577
Definition: cs_lagr_particle.h:324
