cs_balance.cpp File Reference
Wrapper to the function which adds the explicit part of the convection/diffusion terms of a transport equation of a field. More...
#include <errno.h>
#include <stdarg.h>
#include <float.h>
#include <mpi.h>
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "alge/cs_blas.h"
#include "alge/cs_convection_diffusion.h"
#include "alge/cs_convection_diffusion_priv.h"
#include "alge/cs_gradient.h"
#include "base/cs_boundary_conditions_set_coeffs.h"
#include "base/cs_halo.h"
#include "base/cs_halo_perio.h"
#include "base/cs_log.h"
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "base/cs_field.h"
#include "base/cs_ext_neighborhood.h"
#include "base/cs_parall.h"
#include "base/cs_porous_model.h"
#include "base/cs_timer.h"
#include "base/cs_timer_stats.h"
#include "base/cs_velocity_pressure.h"
#include "mesh/cs_mesh.h"
#include "alge/cs_balance.h"
+ Include dependency graph for cs_balance.cpp:
static cs_real_t * _balance_cell_weight (cs_dispatch_context &ctx, const cs_field_t *f, const cs_equation_param_t *eqp, const cs_halo_type_t halo_type, const bool anisotropic, cs_real_6_t *c_visc, bool &need_free_c_visc)
 Update the cell viscosity for balance. More...
void cs_balance_initialize (void)
 Initialize balance timers. More...
void cs_balance_scalar (int idtvar, int f_id, int imucpp, int imasac, int inc, cs_equation_param_t *eqp, cs_real_t pvar[], const cs_real_t pvara[], cs_field_bc_coeffs_t *bc_coeffs, const cs_real_t i_massflux[], const cs_real_t b_massflux[], const cs_real_t i_visc[], const cs_real_t b_visc[], cs_real_6_t c_visc[], const cs_real_t xcpp[], const cs_real_2_t weighf[], const cs_real_t weighb[], int icvflb, const int icvfli[], cs_real_t rhs[])
 Wrapper to the function which adds the explicit part of the convection/diffusion terms of a transport equation of a scalar field $ \varia $. More...
void cs_balance_scalar (int idtvar, int f_id, int imucpp, int imasac, int inc, cs_equation_param_t *eqp, cs_real_t pvar[], const cs_real_t pvara[], cs_field_bc_coeffs_t *bc_coeffs, const cs_real_t i_massflux[], const cs_real_t b_massflux[], const cs_real_t i_visc[], const cs_real_t b_visc[], cs_real_6_t c_visc[], const cs_real_t xcpp[], const cs_real_2_t weighf[], const cs_real_t weighb[], int icvflb, const int icvfli[], cs_real_t rhs[], cs_real_2_t i_flux[], cs_real_t b_flux[])
void cs_balance_vector (int idtvar, int f_id, int imasac, int inc, int ivisep, cs_equation_param_t *eqp, cs_real_3_t pvar[], const cs_real_3_t pvara[], cs_field_bc_coeffs_t *bc_coeffs, const cs_real_t i_massflux[], const cs_real_t b_massflux[], const cs_real_t i_visc[], const cs_real_t b_visc[], const cs_real_t secvif[], const cs_real_t secvib[], cs_real_6_t c_visc[], const cs_real_2_t weighf[], const cs_real_t weighb[], int icvflb, const int icvfli[], cs_real_3_t i_pvar[], cs_real_3_t b_pvar[], cs_real_3_t smbr[])
 Wrapper to the function which adds the explicit part of the convection/diffusion terms of a transport equation of a vector field $ \vect{\varia} $. More...
void cs_balance_tensor (int idtvar, int f_id, int imasac, int inc, cs_equation_param_t *eqp, cs_real_6_t pvar[], const cs_real_6_t pvara[], cs_field_bc_coeffs_t *bc_coeffs, const cs_real_t i_massflux[], const cs_real_t b_massflux[], const cs_real_t i_visc[], const cs_real_t b_visc[], cs_real_6_t c_visc[], const cs_real_2_t weighf[], const cs_real_t weighb[], int icvflb, const int icvfli[], cs_real_6_t rhs[])
 Wrapper to the function which adds the explicit part of the convection/diffusion terms of a transport equation of a tensor field $ \tens{\varia} $. More...
static int _balance_stat_id = -1
◆ _balance_cell_weight()
static cs_real_t * _balance_cell_weight ( cs_dispatch_context &  ctx,
const cs_field_t *  f,
cs_real_6_t *  c_visc,
bool &  need_free_c_visc
static
[in]contextreference to dispatch context
[in]fpointer to field or nullptr
[in]eqpequation parameters
[in]halo_typehalo type
[in]anisotropicisotropic or anisotropic case
[in]c_viscinitial viscosity by cell
[in,out]need_free_c_viscif c_visc is a work array to free
return c_weight (viscosity by cell)
◆ cs_balance_initialize()
void cs_balance_initialize ( void  )
◆ cs_balance_scalar() [1/2]
void cs_balance_scalar ( int  idtvar,
int  f_id,
int  imucpp,
int  imasac,
int  inc,
cs_real_t  pvar[],
cs_field_bc_coeffs_t *  bc_coeffs,
int  icvflb,
const int  icvfli[],
cs_real_t  rhs[]
More precisely, the right hand side $ Rhs $ is updated as follows:
Rhs = Rhs - \sum_{\fij \in \Facei{\celli}}      \left(
       \dot{m}_\ij \left( \varia_\fij - \varia_\celli \right)
     - \mu_\fij \gradv_\fij \varia \cdot \vect{S}_\ij  \right)
Warning:
  • $ Rhs $ has already been initialized before calling cs_balance_scalar!
  • mind the minus sign
Options for the convective scheme:
  • blencp = 0: upwind scheme for the advection
  • blencp = 1: no upwind scheme except in the slope test
  • ischcp = 0: SOLU
  • ischcp = 1: centered
  • ischcp = 2: SOLU with upwind gradient reconstruction
  • ischcp = 3: blending SOLU centered
  • ischcp = 4: NVD-TVD
  • imucpp = 0: do not multiply the convective part by $ C_p $
  • imucpp = 1: multiply the convective part by $ C_p $
[in]idtvarindicator of the temporal scheme
[in]f_idfield id (or -1)
[in]imucppindicator
  • 0 do not multiply the convectiv term by Cp
  • 1 do multiply the convectiv term by Cp
[in]imasactake mass accumulation into account?
[in]incindicator
  • 0 when solving an increment
  • 1 otherwise
[in]eqppointer to a cs_equation_param_t structure which contains variable calculation options
[in]pvarsolved variable (current time step) may be nullptr if pvara != nullptr
[in]pvarasolved variable (previous time step) may be nullptr if pvar != nullptr
[in]bc_coeffsboundary condition structure for the variable
[in]i_massfluxmass flux at interior faces
[in]b_massfluxmass flux at boundary faces
[in]i_visc$ \mu_\fij \dfrac{S_\fij}{\ipf \jpf} $ at interior faces for the r.h.s.
[in]b_visc$ \mu_\fib \dfrac{S_\fib}{\ipf \centf} $ at boundary faces for the r.h.s.
[in]c_viscsymmetric cell tensor $ \tens{\mu}_\celli $
[in]xcpparray of specific heat (Cp)
[in]weighfinternal face weight between cells i j in case of tensor diffusion
[in]weighbboundary face weight for cells i in case of tensor diffusion
[in]icvflbglobal indicator of boundary convection flux
  • 0 upwind scheme at all boundary faces
  • 1 imposed flux at some boundary faces
[in]icvfliboundary face indicator array of convection flux
  • 0 upwind scheme
  • 1 imposed flux
[in,out]rhsright hand side $ \vect{Rhs} $
◆ cs_balance_scalar() [2/2]
int  f_id,
int  imucpp,
int  imasac,
int  inc,
cs_real_t  pvar[],
int  icvflb,
const int  icvfli[],
cs_real_t  rhs[],
cs_real_t  b_flux[]
Warning:
  • ischcp = 0: SOLU
[in]imucppindicator
[in]incindicator
  • 1 otherwise
  • 0 upwind scheme
  • 1 imposed flux
[in,out]i_fluxinterior flux (or nullptr)
[in,out]b_fluxboundary flux (or nullptr)
◆ cs_balance_tensor()
void cs_balance_tensor ( int  idtvar,
int  f_id,
int  imasac,
int  inc,
cs_real_6_t  pvar[],
int  icvflb,
const int  icvfli[],
cs_real_6_t  rhs[]
More precisely, the right hand side $ \vect{Rhs} $ is updated as follows:
\tens{Rhs} = \tens{Rhs} - \sum_{\fij \in \Facei{\celli}}      \left(
       \dot{m}_\ij \left( \tens{\varia}_\fij - \tens{\varia}_\celli \right)
     - \mu_\fij \gradt_\fij \tens{\varia} \cdot \tens{S}_\ij  \right)
Warning:
  • $ \tens{Rhs} $ has already been initialized before calling bilscts!
  • mind the sign minus
  • ischcp = 0: SOLU
[in]incindicator
[in]pvarsolved velocity (current time step)
[in]pvarasolved velocity (previous time step)
  • 0 upwind scheme
  • 1 imposed flux
◆ cs_balance_vector()
void cs_balance_vector ( int  idtvar,
int  f_id,
int  imasac,
int  inc,
int  ivisep,
cs_real_3_t  pvar[],
int  icvflb,
const int  icvfli[],
cs_real_3_t  smbr[]
\vect{Rhs} = \vect{Rhs} - \sum_{\fij \in \Facei{\celli}}      \left(
       \dot{m}_\ij \left( \vect{\varia}_\fij - \vect{\varia}_\celli \right)
     - \mu_\fij \gradt_\fij \vect{\varia} \cdot \vect{S}_\ij  \right)
Remark: if ivisep = 1, then we also take $ \mu \transpose{\gradt\vect{\varia}}
+ \lambda \trace{\gradt\vect{\varia}} $, where $ \lambda $ is the secondary viscosity, i.e. usually $ -\frac{2}{3} \mu $.
Warning:
  • $ \vect{Rhs} $ has already been initialized before calling cs_balance_vector!
  • ischcp = 0: SOLU
[in]incindicator
  • 1 otherwise
[in]ivisepindicator to take $ \divv
                              \left(\mu \gradt \transpose{\vect{a}} \right)
                              -2/3 \grad\left( \mu \dive \vect{a} \right)$
  • 1 take into account,
  • 0 otherwise
[in]bc_coeffs_vboundary condition structure for the variable
[in]secvifsecondary viscosity at interior faces
[in]secvibsecondary viscosity at boundary faces
  • 0 upwind scheme
  • 1 imposed flux
[in,out]smbrright hand side $ \vect{Rhs} $
◆ _balance_stat_id
static
