cs_at_data_assim.h
1#ifndef CS_AT_DATA_ASSIM_H
2#define CS_AT_DATA_ASSIM_H
5 * Data assimilation
30#include "base/cs_defs.h"
32/*----------------------------------------------------------------------------*/
34#if defined(HAVE_MPI)
35#include <mpi.h>
36#endif
38/*----------------------------------------------------------------------------
39 * Local headers
40 *----------------------------------------------------------------------------*/
45 * Macro definitions
49 * Type definitions
51
52/*============================================================================
53 * Global variables
54 *============================================================================*/
55
56/*=============================================================================
57 * Public function prototypes
58 *============================================================================*/
59
60/*----------------------------------------------------------------------------*/
64/*----------------------------------------------------------------------------*/
65
66void
68
69/*----------------------------------------------------------------------------*/
73/*----------------------------------------------------------------------------*/
74
75void
77
78/*----------------------------------------------------------------------------*/
82/*----------------------------------------------------------------------------*/
83
84void
86
87/*----------------------------------------------------------------------------*/
95/*----------------------------------------------------------------------------*/
96
97void
100 cs_field_t *f);
101
102/*----------------------------------------------------------------------------*/
111/*----------------------------------------------------------------------------*/
112
113void
115 cs_real_t *exp_st,
116 cs_real_t *imp_st);
117
118/*----------------------------------------------------------------------------*/
119
120#endif /* CS_AT_DATA_ASSIM_H */
Definition: cs_field.h:275
void cs_at_data_assim_initialize(void)
Initialize data assimilation structures.
Definition: cs_at_data_assim.cpp:121
void cs_at_data_assim_finalize(void)
Destroy all structures linked to data assimilation.
Definition: cs_at_data_assim.cpp:329
void cs_at_data_assim_build_ops(void)
Build operators.
Definition: cs_at_data_assim.cpp:219
void cs_at_data_assim_log(cs_measures_set_t *ms, cs_at_opt_interp_t *oi, cs_field_t *f)
Log data assimilation.
Definition: cs_at_data_assim.cpp:349
void cs_at_data_assim_source_term(int f_id, cs_real_t *exp_st, cs_real_t *imp_st)
Compute source terms for a given variable and add them up to source term arrays.
Definition: cs_at_data_assim.cpp:498
Definition: cs_defs.h:332
Definition: cs_at_opt_interp.h:58
Definition: cs_measures_util.h:44
