1#ifndef CS_ATMO_GROUND_MODEL_H
2#define CS_ATMO_GROUND_MODEL_H
void cs_ground_model(void)
Compute ground and interface values using Deardorff force restore method.
Definition: cs_atmo_ground_model.cpp:1052
void cs_atmo_ground_cat(int call_stage)
Ground - atmosphere parameters computed from a "Land use" file.
Definition: cs_atmo_ground_model.cpp:1702
cs_plant_option_t * cs_glob_plant_option
Definition: cs_atmo_ground_model.cpp:129
void cs_atmo_ground_initialize(void)
Build constants and variables to describe ground model.
Definition: cs_atmo_ground_model.cpp:1663
Definition: cs_defs.h:332
Definition: cs_atmo_ground_model.h:48
cs_real_t albedo_plant
Definition: cs_atmo_ground_model.h:60
cs_real_t tort_factor
Definition: cs_atmo_ground_model.h:152
cs_real_t a_pho
Definition: cs_atmo_ground_model.h:72
cs_real_t xiv
Definition: cs_atmo_ground_model.h:124
cs_real_t r_root
Definition: cs_atmo_ground_model.h:126
cs_real_t s_vlmax
Definition: cs_atmo_ground_model.h:108
cs_real_t ground_exch_l
Definition: cs_atmo_ground_model.h:154
cs_real_t zos
Definition: cs_atmo_ground_model.h:146
cs_real_t zref_plant
Definition: cs_atmo_ground_model.h:148
cs_real_t psif_psiv
Definition: cs_atmo_ground_model.h:78
cs_real_t psi_e
Definition: cs_atmo_ground_model.h:134
cs_real_t emi_plant
Definition: cs_atmo_ground_model.h:62
cs_real_t knitro
Definition: cs_atmo_ground_model.h:100
cs_real_t canopy_mix_l
Definition: cs_atmo_ground_model.h:140
cs_real_t ea_jlmax
Definition: cs_atmo_ground_model.h:110
cs_real_t dv
Definition: cs_atmo_ground_model.h:158
cs_real_t v_gco2_decr
Definition: cs_atmo_ground_model.h:122
cs_real_t gamma_0
Definition: cs_atmo_ground_model.h:90
cs_real_t turb_prandtl
Definition: cs_atmo_ground_model.h:142
cs_real_t vlmaxref
Definition: cs_atmo_ground_model.h:98
cs_real_t ea_vlmax
Definition: cs_atmo_ground_model.h:104
cs_real_t z_root
Definition: cs_atmo_ground_model.h:128
cs_real_t eao
Definition: cs_atmo_ground_model.h:86
cs_real_t k_ext_coef
Definition: cs_atmo_ground_model.h:58
cs_real_t v_gco2_incr
Definition: cs_atmo_ground_model.h:120
cs_real_t gamma_1
Definition: cs_atmo_ground_model.h:92
int water_potential_model
Definition: cs_atmo_ground_model.h:132
cs_real_t theta_pho
Definition: cs_atmo_ground_model.h:118
cs_real_t ed_jlmax
Definition: cs_atmo_ground_model.h:112
cs_real_t psi_pow
Definition: cs_atmo_ground_model.h:136
cs_real_t dry_ground_porosity
Definition: cs_atmo_ground_model.h:156
cs_real_t gamma_2
Definition: cs_atmo_ground_model.h:94
cs_real_t d_leaf
Definition: cs_atmo_ground_model.h:54
cs_real_t ed_vlmax
Definition: cs_atmo_ground_model.h:106
cs_real_t h_canopy
Definition: cs_atmo_ground_model.h:50
cs_real_t kref
Definition: cs_atmo_ground_model.h:138
cs_real_t k_eddy_hc
Definition: cs_atmo_ground_model.h:150
cs_real_t c_co2_air
Definition: cs_atmo_ground_model.h:64
cs_real_t h_canopy_exch
Definition: cs_atmo_ground_model.h:52
cs_real_t ea_ground
Definition: cs_atmo_ground_model.h:70
cs_real_t g0_pho
Definition: cs_atmo_ground_model.h:74
cs_real_t leaf_area_index
Definition: cs_atmo_ground_model.h:56
cs_real_t sf_psiv
Definition: cs_atmo_ground_model.h:76
cs_real_t s_jlmax
Definition: cs_atmo_ground_model.h:114
cs_real_t oi
Definition: cs_atmo_ground_model.h:80
cs_real_t eac
Definition: cs_atmo_ground_model.h:88
cs_real_t tem_ref_pho
Definition: cs_atmo_ground_model.h:96
cs_real_t alpha_pho
Definition: cs_atmo_ground_model.h:116
cs_real_t f_co2_0_ground
Definition: cs_atmo_ground_model.h:66
cs_real_t ld_root
Definition: cs_atmo_ground_model.h:130
cs_real_t koref
Definition: cs_atmo_ground_model.h:82
cs_real_t cdrag_leaf
Definition: cs_atmo_ground_model.h:144
cs_real_t temp_ref_co2
Definition: cs_atmo_ground_model.h:68
cs_real_t kcref
Definition: cs_atmo_ground_model.h:84
cs_real_t jlmaxref
Definition: cs_atmo_ground_model.h:102
