1#ifndef CS_CDO_ADVECTION_H
2#define CS_CDO_ADVECTION_H
void() cs_cdofb_adv_build_t(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, const cs_property_data_t *diff_pty, cs_cdofb_adv_scheme_t *scheme_func, cs_cell_builder_t *cb)
Build the cellwise advection operator for CDO-Fb schemes The local matrix related to this operator is...
Definition: cs_cdo_advection.h:112
void cs_cdofb_advection_solunoc(int dim, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Compute the convection operator attached to a cell with a CDO face-based scheme.
Definition: cs_cdo_advection.cpp:2845
void cs_cdofb_advection_cennoc_v8(int dim, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Definition: cs_cdo_advection.cpp:2452
void cs_cdo_advection_vb_upwcsv_wpty(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_face_mesh_t *fm, cs_cell_builder_t *cb)
Compute the convection operator attached to a cell with a CDO vertex-based scheme with an upwind sche...
Definition: cs_cdo_advection.cpp:3010
void cs_cdofb_advection_no_diffusion(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, const cs_property_data_t *diff_pty, cs_cdofb_adv_scheme_t *scheme_func, cs_cell_builder_t *cb)
Definition: cs_cdo_advection.cpp:1991
void cs_cdofb_advection_sgnoc(int dim, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Definition: cs_cdo_advection.cpp:2982
void cs_cdo_advection_vcb_bc(const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, cs_real_t t_eval, cs_face_mesh_t *fm, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Compute the BC contribution for the convection operator with CDO V+C schemes.
Definition: cs_cdo_advection.cpp:3916
void cs_cdofb_advection_upwnoc(int dim, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Definition: cs_cdo_advection.cpp:2194
void cs_cdo_advection_vb_upwcsv(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_face_mesh_t *fm, cs_cell_builder_t *cb)
Compute the convection operator attached to a cell with a CDO vertex-based scheme without diffusion a...
Definition: cs_cdo_advection.cpp:3101
void cs_cdo_advection_vb_upwnoc(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_face_mesh_t *fm, cs_cell_builder_t *cb)
Compute the convection operator attached to a cell with a CDO vertex-based scheme without diffusion w...
Definition: cs_cdo_advection.cpp:3409
void cs_cdofb_advection_close_default_vect(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Operation done after the matrix related to the advection term has been defined. Follow the prototype ...
Definition: cs_cdo_advection.cpp:1854
void cs_cdofb_advection_close_default_scal(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Definition: cs_cdo_advection.cpp:1825
void cs_cdo_advection_vcb_cw_cst(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_face_mesh_t *fm, cs_cell_builder_t *cb)
Compute the convection operator attached to a cell with a CDO vertex+cell-based scheme when the advec...
Definition: cs_cdo_advection.cpp:3521
void cs_cdofb_advection_cennoc(int dim, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Definition: cs_cdo_advection.cpp:2667
void cs_cdofb_advection_L0noc(int dim, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Definition: cs_cdo_advection.cpp:2606
void cs_cdofb_advection_cencsv(int dim, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Definition: cs_cdo_advection.cpp:2703
void cs_cdo_advection_vb_bc(const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, cs_real_t t_eval, cs_face_mesh_t *fm, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Compute the BC contribution for the convection operator.
Definition: cs_cdo_advection.cpp:3794
void cs_cdofb_advection_close_exp_none_scal(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Definition: cs_cdo_advection.cpp:1899
void cs_cdofb_advection_mixcsv(int dim, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Definition: cs_cdo_advection.cpp:2739
void cs_cdofb_advection_solusymnoc(int dim, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Definition: cs_cdo_advection.cpp:2915
void cs_cdo_advection_vcb(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_face_mesh_t *fm, cs_cell_builder_t *cb)
Compute the convection operator attached to a cell with a CDO vertex+cell-based scheme.
Definition: cs_cdo_advection.cpp:3663
void() cs_cdofb_adv_scheme_t(int dim, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Define the local convection operator in CDO-Fb schemes. Case of an operator that should be assemble i...
Definition: cs_cdo_advection.h:88
void cs_cdo_advection_vb_upwnoc_wpty(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_face_mesh_t *fm, cs_cell_builder_t *cb)
Definition: cs_cdo_advection.cpp:3320
void cs_cdofb_advection(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, const cs_property_data_t *diff_pty, cs_cdofb_adv_scheme_t *scheme_func, cs_cell_builder_t *cb)
Main function to build the cellwise advection operator for CDO face-based schemes....
Definition: cs_cdo_advection.cpp:2092
void cs_cdofb_advection_sgcsv(int dim, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Definition: cs_cdo_advection.cpp:2951
void cs_cdofb_advection_cencsv_v8(int dim, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Definition: cs_cdo_advection.cpp:2526
void cs_cdofb_advection_upwcsv_v8(int dim, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Definition: cs_cdo_advection.cpp:2359
void cs_cdofb_advection_L0csv(int dim, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Definition: cs_cdo_advection.cpp:2637
void() cs_cdovb_advection_bc_t(const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, cs_real_t t_eval, cs_face_mesh_t *fm, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
Compute the BC contribution for the advection operator in CDO vertex-based (or vertex+cell-based) sch...
Definition: cs_cdo_advection.h:179
void() cs_cdofb_adv_close_hook_t(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Definition: cs_cdo_advection.h:133
void cs_cdo_advection_vb_mcucsv(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_face_mesh_t *fm, cs_cell_builder_t *cb)
Compute the convection operator attached to a cell with a CDO vertex-based scheme when a mixed center...
Definition: cs_cdo_advection.cpp:3217
void cs_cdo_advection_vb_mcunoc(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_face_mesh_t *fm, cs_cell_builder_t *cb)
Definition: cs_cdo_advection.cpp:3268
void cs_cdo_advection_vb_cennoc(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_face_mesh_t *fm, cs_cell_builder_t *cb)
Compute the convection operator attached to a cell with a CDO vertex-based scheme when a centered sch...
Definition: cs_cdo_advection.cpp:3473
void cs_cdofb_advection_upwnoc_v8(int dim, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Definition: cs_cdo_advection.cpp:2266
void cs_cdo_advection_cell_upwind_coef(const cs_cdo_quantities_t *cdoq, cs_param_advection_scheme_t scheme, cs_real_t coefval[])
Compute the value of the upwinding coefficient in each cell knowing the related Peclet number.
Definition: cs_cdo_advection.cpp:3981
void cs_cdofb_advection_upwcsv(int dim, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Definition: cs_cdo_advection.cpp:2230
void() cs_cdofb_adv_open_hook_t(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, void *input, cs_cell_builder_t *cb)
Perform preprocessing such as the computation of the advection flux at the expected location in order...
Definition: cs_cdo_advection.h:67
void cs_cdofb_advection_close_exp_none_vect(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Definition: cs_cdo_advection.cpp:1937
void cs_cdofb_advection_solucsv(int dim, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Definition: cs_cdo_advection.cpp:2810
void() cs_cdovb_advection_t(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_face_mesh_t *fm, cs_cell_builder_t *cb)
Compute the convection operator attached to a cell with a CDO vertex-based scheme....
Definition: cs_cdo_advection.h:158
void cs_cdo_advection_vb_cencsv(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *diff_pty, cs_face_mesh_t *fm, cs_cell_builder_t *cb)
Definition: cs_cdo_advection.cpp:3166
void cs_cdofb_advection_solusymcsv(int dim, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Definition: cs_cdo_advection.cpp:2880
void cs_cdofb_advection_open_default(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, void *input, cs_cell_builder_t *cb)
Definition: cs_cdo_advection.cpp:1779
void cs_cdofb_advection_mixnoc(int dim, const cs_cell_mesh_t *cm, const cs_cell_sys_t *csys, cs_cell_builder_t *cb, cs_sdm_t *adv)
Definition: cs_cdo_advection.cpp:2775
Definition: cs_defs.h:332
@ fm
Definition: cs_field_pointer.h:126
Definition: cs_param_types.h:371
Definition: cs_cdo_quantities.h:142
Definition: cs_cdo_local.h:56
Definition: cs_cdo_local.h:242
Definition: cs_cdo_local.h:163
Set of local quantities and connectivities related to a mesh face Structure used to get a better memo...
Definition: cs_cdo_local.h:432
Structure storing the evaluation of a property and its related data.
Definition: cs_property.h:219
