cs_lagr_sde_model.cpp File Reference
#include <stddef.h>
#include <float.h>
#include <ctype.h>
#include "bft/bft_printf.h"
#include "bft/bft_error.h"
#include "base/cs_base.h"
#include "base/cs_mem.h"
#include "comb/cs_coal.h"
#include "comb/cs_coal_ht_convert.h"
#include "base/cs_math.h"
#include "mesh/cs_mesh.h"
#include "lagr/cs_lagr.h"
#include "lagr/cs_lagr_tracking.h"
#include "lagr/cs_lagr_prototypes.h"
#include "lagr/cs_lagr_sde.h"
#include "lagr/cs_lagr_sde_model.h"
#include "atmo/cs_air_props.h"
#include "ctwr/cs_ctwr.h"
+ Include dependency graph for cs_lagr_sde_model.cpp:
void cs_lagr_sde_model (cs_lagr_particle_set_t &p_set, const cs_lnum_t p_id, const cs_real_t dt_part, int nor, const cs_real_2_t tempct, cs_real_t *cpgd1, cs_real_t *cpgd2, cs_real_t *cpght)
 Integration of particle stochastic differential equations for specific physical models. More...
Integration of Lagrangian stochastic diferential equations.
◆ cs_lagr_sde_model()
void cs_lagr_sde_model ( cs_lagr_particle_set_t &  p_set,
int  nor,
cs_real_t *  cpgd1,
cs_real_t *  cpgd2,
cs_real_t *  cpght
  • temperature seen by particles,
  • particle temperature,
  • particle diameter
  • particle mass
  • variables related to coal grains (Temp, MCH, MCK)
  • additional user parameters
[in]p_setreference to particle set
[in]p_idparticle id
[in]dt_parttime step associated to the particle
[in]norcurrent step id (for 2nd order scheme)
[in]tempctthermal characteristic time
[out]cpgd1,cpgd2devolatilisation terms 1 and 2
[out]cpghtheterogeneos combusion terms (coal with thermal return coupling)
