cs_combustion_d3p.h
1#ifndef CS_COMBUSTION_D3P_H
2#define CS_COMBUSTION_D3P_H
5 * Infinitely fast 3-point combustion model
31 * Standard library headers
35 * Local headers
38#include "base/cs_defs.h"
39#include "base/cs_field.h"
42/*----------------------------------------------------------------------------*/
45 * Macro definitions
49 * Type definitions
51
52/*============================================================================
53 * Global variables
54 *============================================================================*/
55
56/*=============================================================================
57 * Public function prototypes
58 *============================================================================*/
59
60/*----------------------------------------------------------------------------*/
65/*----------------------------------------------------------------------------*/
66
67void
69
70/*----------------------------------------------------------------------------*/
75/*----------------------------------------------------------------------------*/
76
77void
79
80/*----------------------------------------------------------------------------*/
81/*
82 * \brief Integration of thermodynamic variablesfunction of mixture fraction.
83 *
84 * Remark: temperature integration could be weighted by Cp.
85 *
86 * \param[in] indpdf indicator for pdf integration or mean value
87 * \param[in] dirmin Dirac's peak value at \f$ f_{min} \f$
88 * \param[in] dirmax Dirac's peak value at \f$ f_{max} \f$
89 * \param[in] fdeb abscissa of rectangle low boundary
90 * \param[in] ffin abscissa of rectangle high boundary
91 * \param[in] hrec rectangle height
92 * \param[in] w1 work array
93 */
95
96void
98 cs_real_t dirmin[],
99 cs_real_t dirmax[],
100 cs_real_t fdeb[],
101 cs_real_t ffin[],
102 cs_real_t hrec[],
103 cs_real_t w1[]);
104
105/*----------------------------------------------------------------------------*/
106
107#endif /* CS_COMBUSTION_D3P_H */
void cs_combustion_d3p_fields_init1(void)
Initialize specific fields for infinitely fast 3-point chemistry combustion model,...
Definition: cs_combustion_d3p.cpp:349
void cs_combustion_d3p_fields_init0(void)
Definition: cs_combustion_d3p.cpp:258
void cs_combustion_d3p_integration(int indpdf[], cs_real_t dirmin[], cs_real_t dirmax[], cs_real_t fdeb[], cs_real_t ffin[], cs_real_t hrec[], cs_real_t w1[])
Definition: cs_combustion_d3p.cpp:437
Definition: cs_defs.h:332
