cs_cf_compute.cpp File Reference
Computations for compressible flows. More...
#include <stdarg.h>
#include <mpi.h>
#include "bft/bft_printf.h"
#include "base/cs_array.h"
#include "alge/cs_balance.h"
#include "alge/cs_blas.h"
#include "base/cs_boundary_conditions_set_coeffs.h"
#include "cfbl/cs_cf_boundary_conditions.h"
#include "cfbl/cs_cf_thermo.h"
#include "alge/cs_convection_diffusion.h"
#include "alge/cs_divergence.h"
#include "base/cs_equation_iterative_solve.h"
#include "alge/cs_face_viscosity.h"
#include "base/cs_mem.h"
#include "base/cs_volume_mass_injection.h"
#include "base/cs_mass_source_terms.h"
#include "alge/cs_matrix_building.h"
#include "mesh/cs_mesh.h"
#include "base/cs_parall.h"
#include "base/cs_porous_model.h"
#include "base/cs_velocity_pressure.h"
#include "cfbl/cs_cf_compute.h"
+ Include dependency graph for cs_cf_compute.cpp:
void cs_compressible_pressure_ausm_mass_flux (cs_dispatch_context &ctx, const cs_real_3_t *vel, const cs_real_t *crom, const cs_real_t *brom, const cs_real_t *p, cs_field_bc_coeffs_t *bc_coeffs_v, cs_field_bc_coeffs_t *bc_coeffs_p, cs_real_t *imasfl, cs_real_t *bmasfl)
 Compute the "mass flux" at the faces for the CFL restriction computation and the solving of the pressure (AUSM+up scheme) More...
void cs_cf_convective_mass_flux (int iterns)
 Update the convective mass flux before the velocity prediction step. It is the first step of the compressible algorithm at each time iteration. More...
void cs_cf_cfl_compute (cs_real_t wcf[])
 Computation of the constraint for the CFL (compressible algorithm) More...
◆ cs_cf_cfl_compute()
void cs_cf_cfl_compute ( cs_real_t  wcf[])
[in]wcfcompressible constraint
◆ cs_cf_convective_mass_flux()
void cs_cf_convective_mass_flux ( int  iterns)
This function solves the continuity equation in pressure formulation and then updates the density and the mass flux.
[in]iternsNavier-Stokes iteration number
◆ cs_compressible_pressure_ausm_mass_flux()
void cs_compressible_pressure_ausm_mass_flux ( cs_dispatch_context &  ctx,
const cs_real_3_t *  vel,
const cs_real_t *  crom,
const cs_real_t *  brom,
const cs_real_t *  p,
cs_field_bc_coeffs_t *  bc_coeffs_v,
cs_field_bc_coeffs_t *  bc_coeffs_p,
cs_real_t *  imasfl,
cs_real_t *  bmasfl
[in]ctxdispatch context
[in]velvelocity vector
[in]cromcell density
[in]bromdensity at boundary faces
[in]pthermodynamic pressure
[in]bc_coeffs_vBC structure for velocity vector
[in]bc_coeffs_pBC structure for pressure
[out]imasflInternal faces mass flux
[out]bmasflBoundary faces mass flux
