cs_navsto_param.h File Reference
+ Include dependency graph for cs_navsto_param.h:
Classes
struct  cs_navsto_param_boussinesq_t
 Structure storing the parameters related to the Boussinesq source term in the momentum equation. More...
struct  cs_navsto_param_t
 Structure storing the parameters related to the resolution of the Navier-Stokes system. More...
Macros
#define CS_NAVSTO_STREAM_EQNAME   "streamfunction_eq"
Typedefs
typedef cs_flag_t cs_navsto_param_model_flag_t
typedef cs_flag_t cs_navsto_param_post_flag_t
typedef cs_flag_t cs_navsto_param_num_flag_t
Enumerations
enum  cs_navsto_param_model_t { CS_NAVSTO_MODEL_STOKES , CS_NAVSTO_MODEL_OSEEN , CS_NAVSTO_MODEL_INCOMPRESSIBLE_NAVIER_STOKES , CS_NAVSTO_N_MODELS }
 Describe the system of equations related to the Navier-Stokes to be solved. More...
enum  cs_navsto_param_model_bit_t {
  CS_NAVSTO_MODEL_STEADY = 1<<0 , CS_NAVSTO_MODEL_GRAVITY_EFFECTS = 1<<1 , CS_NAVSTO_MODEL_CORIOLIS_EFFECTS = 1<<2 , CS_NAVSTO_MODEL_PASSIVE_THERMAL_TRACER = 1<<3 ,
  CS_NAVSTO_MODEL_BOUSSINESQ = 1<<4 , CS_NAVSTO_MODEL_WITH_SOLIDIFICATION = 1<<5
 Bit values for additional physical modelling related to the Navier-Stokes system of equations. More...
enum  cs_navsto_param_post_bit_t {
  CS_NAVSTO_POST_VELOCITY_DIVERGENCE = 1<< 0 , CS_NAVSTO_POST_KINETIC_ENERGY = 1<< 1 , CS_NAVSTO_POST_VORTICITY = 1<< 2 , CS_NAVSTO_POST_VELOCITY_GRADIENT = 1<< 3 ,
  CS_NAVSTO_POST_STREAM_FUNCTION = 1<< 4 , CS_NAVSTO_POST_HELICITY = 1<< 5 , CS_NAVSTO_POST_ENSTROPHY = 1<< 6 , CS_NAVSTO_POST_MASS_DENSITY = 1<< 7 ,
  CS_NAVSTO_POST_CELL_MASS_FLUX_BALANCE = 1<< 8 , CS_NAVSTO_POST_PRESSURE_GRADIENT = 1<< 9 , CS_NAVSTO_POST_BOUNDARY_STRESS = 1 << 10
 Bit values for additional generic postprocessing related to the Navier-Stokes module. In what follows, w denotes the vorticity vector, u the velocity vector and k the kinetic energy defined by $ \frac{\rho u}{2} \cdot u $. More...
enum  cs_navsto_param_num_bit_t { CS_NAVSTO_NUM_PSEUDO_STEADY = 1 << 0 }
 Bit values for additional numeric related to the Navier-Stokes system of equations. More...
enum  cs_navsto_param_coupling_t { CS_NAVSTO_COUPLING_ARTIFICIAL_COMPRESSIBILITY , CS_NAVSTO_COUPLING_MONOLITHIC , CS_NAVSTO_COUPLING_PROJECTION , CS_NAVSTO_N_COUPLINGS }
 Choice of algorithm for solving the system. More...
enum  cs_navsto_param_norm_type_t { CS_NAVSTO_PARAM_NORM_L2 , CS_NAVSTO_PARAM_NORM_HDIV , CS_NAVSTO_PARAM_NORM_TRACE , CS_NAVSTO_PARAM_N_NORM_TYPES }
 Choice of the norm for the mass flux used in the non-linear algorithm. More...
enum  cs_navsto_key_t {
  CS_NSKEY_DOF_REDUCTION , CS_NSKEY_NL_ALGO , CS_NSKEY_NL_ALGO_ATOL , CS_NSKEY_NL_ALGO_DTOL ,
  CS_NSKEY_NL_ALGO_MAX_ITER , CS_NSKEY_NL_ALGO_RTOL , CS_NSKEY_PSTEADY_ALGO_ATOL , CS_NSKEY_PSTEADY_ALGO_RTOL ,
  CS_NSKEY_PSTEADY_ALGO_N_CVG_ITER , CS_NSKEY_PSTEADY_ALGO_N_STEP_SOLVE , CS_NSKEY_NORM_TYPE , CS_NSKEY_SPACE_SCHEME ,
  CS_NSKEY_THERMAL_TOLERANCE , CS_NSKEY_VERBOSITY , CS_NSKEY_N_KEYS
 List of available keys for setting the parameters of the Navier-Stokes system. More...
static bool cs_navsto_param_is_steady (const cs_navsto_param_t *nsp)
 Ask cs_navsto_param_t structure if the settings correspond to a steady computation. More...
cs_navsto_param_t * cs_navsto_param_create (const cs_boundary_t *boundaries, cs_navsto_param_model_t model, cs_navsto_param_model_flag_t model_flag, cs_navsto_param_coupling_t algo_coupling, cs_navsto_param_post_flag_t post_flag)
 Create a new structure to store all numerical parameters related to the resolution of the Navier-Stokes (NS) system. More...
cs_navsto_param_t * cs_navsto_param_free (cs_navsto_param_t *param)
 Free a cs_navsto_param_t structure. More...
void cs_navsto_param_set (cs_navsto_param_t *nsp, cs_navsto_key_t key, const char *keyval)
 Set a parameter attached to a keyname in a cs_navsto_param_t structure. More...
void cs_navsto_param_transfer (const cs_navsto_param_t *nsp, cs_equation_param_t *eqp)
 Apply the numerical settings defined for the Navier-Stokes system to an equation related to this system. Be aware that the user-defined settings can be modified in this function when a different choice is set between the settings for the Navier-Stokes system and the settings for the momentum equation. The final choice is given by the settings for the Navier-Stokes system. More...
void cs_navsto_param_log (const cs_navsto_param_t *nsp)
 Summary of the main cs_navsto_param_t structure. More...
cs_navsto_param_boussinesq_t * cs_navsto_param_add_boussinesq_term (cs_navsto_param_t *nsp, cs_real_t dilatation_coef, cs_real_t reference_value)
 Add a new Boussinesq term (source term for the momemtum equation) More...
void cs_navsto_param_set_boussinesq_array (cs_navsto_param_boussinesq_t *bp, const cs_real_t *var)
 Set the array of values to consider in the Boussinesq term. More...
cs_equation_param_t * cs_navsto_param_get_velocity_param (const cs_navsto_param_t *nsp)
 Retrieve the cs_equation_param_t structure related to the velocity equation (momentum equation in most of the cases) More...
const char * cs_navsto_param_get_model_name (cs_navsto_param_model_t model)
 Retrieve the name of the model system of equations. More...
const char * cs_navsto_param_get_coupling_name (cs_navsto_param_coupling_t coupling)
 Retrieve the name of the coupling algorithm. More...
void cs_navsto_param_set_quadrature_to_all (cs_navsto_param_t *nsp, cs_quadrature_type_t qtype)
 Apply the given quadrature rule to all existing definitions under the cs_navsto_param_t structure. More...
void cs_navsto_set_reference_pressure (cs_navsto_param_t *nsp, cs_real_t pref)
 Set the value to consider for the reference pressure. More...
cs_xdef_t * cs_navsto_add_velocity_ic_by_value (cs_navsto_param_t *nsp, const char *z_name, const cs_real_3_t val)
 Define the initial condition for the velocity unknowns. This definition can be done on a specified mesh location. By default, the unknown is set to zero everywhere. Here the initial value is set to a constant value. More...
cs_xdef_t * cs_navsto_add_velocity_ic_by_analytic (cs_navsto_param_t *nsp, const char *z_name, cs_analytic_func_t *analytic, void *input)
 Define the initial condition for the velocity unknowns. This definition can be done on a specified mesh location. By default, the unknown is set to zero everywhere. Here the initial value is set according to an analytical function. More...
cs_xdef_t * cs_navsto_add_pressure_ic_by_value (cs_navsto_param_t *nsp, const char *z_name, cs_real_t val)
 Define the initial condition for the pressure unknowns. This definition can be done on a specified mesh location. By default, the unknown is set to zero everywhere. Here the initial value is set to a constant value. More...
cs_xdef_t * cs_navsto_add_pressure_ic_by_analytic (cs_navsto_param_t *nsp, const char *z_name, cs_analytic_func_t *analytic, void *input)
 Define the initial condition for the pressure unknowns. This definition can be done on a specified mesh location. By default, the unknown is set to zero everywhere. Here the initial value is set according to an analytical function. More...
void cs_navsto_set_fixed_walls (cs_navsto_param_t *nsp)
 Add the definition of boundary conditions related to a fixed wall into the set of parameters for the management of the Navier-Stokes system of equations. More...
void cs_navsto_set_symmetries (cs_navsto_param_t *nsp)
 Add the definition of boundary conditions related to a symmetry into the set of parameters for the management of the Navier-Stokes system of equations. More...
void cs_navsto_set_outlets (cs_navsto_param_t *nsp)
 Add the definition of boundary conditions related to outlets into the set of parameters for the management of the Navier-Stokes system of equations. More...
cs_xdef_t * cs_navsto_set_pressure_bc_by_value (cs_navsto_param_t *nsp, const char *z_name, cs_real_t values)
 Set the pressure field on a boundary using a uniform value. More...
cs_xdef_t * cs_navsto_set_velocity_wall_by_value (cs_navsto_param_t *nsp, const char *z_name, const cs_real_3_t values)
 Define the velocity field for a sliding wall boundary using a uniform value. More...
cs_xdef_t * cs_navsto_set_velocity_inlet_by_value (cs_navsto_param_t *nsp, const char *z_name, const cs_real_3_t values)
 Define the velocity field for an inlet boundary using a uniform value. More...
cs_xdef_t * cs_navsto_set_velocity_inlet_by_analytic (cs_navsto_param_t *nsp, const char *z_name, cs_analytic_func_t *ana, void *input)
 Define the velocity field for an inlet boundary using an analytical function. More...
cs_xdef_t * cs_navsto_set_velocity_inlet_by_array (cs_navsto_param_t *nsp, const char *z_name, cs_flag_t loc, cs_real_t *array, bool is_owner, bool full_length)
 Define the velocity field for an inlet boundary using an array of values. More...
cs_xdef_t * cs_navsto_set_velocity_inlet_by_dof_func (cs_navsto_param_t *nsp, const char *z_name, cs_flag_t dof_loc, cs_dof_func_t *func, void *func_input)
 Define the velocity field for an inlet boundary using a DoF function. More...
cs_xdef_t * cs_navsto_add_source_term_by_analytic (cs_navsto_param_t *nsp, const char *z_name, cs_analytic_func_t *ana, void *input)
 Define a new source term structure defined by an analytical function. More...
cs_xdef_t * cs_navsto_add_source_term_by_value (cs_navsto_param_t *nsp, const char *z_name, const cs_real_3_t val)
 Define a new source term structure defined by a constant value. More...
cs_xdef_t * cs_navsto_add_source_term_by_array (cs_navsto_param_t *nsp, const char *z_name, cs_flag_t loc, cs_real_t *array, bool is_owner, bool full_length)
 Define a new source term structure defined by an array. More...
void cs_navsto_add_oseen_field (cs_navsto_param_t *nsp, cs_adv_field_t *adv_fld)
 Add a advection field for the Oseen problem. More...
◆ CS_NAVSTO_STREAM_EQNAME
Typedef Documentation
◆ cs_navsto_param_model_flag_t
◆ cs_navsto_param_num_flag_t
◆ cs_navsto_param_post_flag_t
◆ cs_navsto_key_t
Enumerator
Set how the DoFs are defined (similar to CS_EQKEY_DOF_REDUCTION) Enable to set this type of DoFs definition for all related equations
CS_NSKEY_NL_ALGO
Type of algorithm to consider to solve the non-linearity arising from the Navier-Stokes system (Picard or Anderson)
Absolute tolerance at which the non-linearity arising from the advection term is resolved
Threshold at which the non-linear algorithm is set as diverged
Set the maximal number of iterations for solving the non-linearity arising from the advection form
Relative tolerance at which the non-linearity arising from the advection term is resolved
Absolute tolerance at which the pseudo-steady algorithm is resolved
Relative tolerance at which the pseudo-steady algorithm is resolved
Number of consecutively converged iterations before stopping the pseudo-steady algorithm process
Solve the Navier-Stokes equation every n interatios for the pseudo-steady algorithm
CS_NSKEY_NORM_TYPE
Type of norm (and dot product) to consider to compute the normalization and quantities when performing the non-linear algorithm.
Numerical scheme for the space discretization. Available choices are:
  • "cdo_fb" or "cdofb" for CDO face-based scheme
Value of the tolerance criterion under which one stops iterating on the Navier-Stokes and thermal systems
CS_NSKEY_VERBOSITY
Set the level of details for the specific part related to the Navier-Stokes system
CS_NSKEY_N_KEYS
◆ cs_navsto_param_coupling_t
Enumerator
The system is solved using an artificial compressibility algorithm. One vectorial equation is solved followed by a pressure update.
The system is treated as a "monolithic" matrix
The system is solved using an incremental projection algorithm. The potential is based on cell-based scheme
◆ cs_navsto_param_model_bit_t
Enumerator
There is no time dependency in the model
Take into account the gravity effects (add a constant source term equal to rho*vect(g))
Take into account the Coriolis effects (add a source term)
An additional equation is created involving the thermal equation. The advection field is automatically set as the mass flux. By default, the temperature is solved in Celsius and homogeneous Neumann boundary conditions (no flux) are set. This option is not compatible with the option CS_NAVSTO_MODEL_BOUSSINESQ
An additional equation is created involving the thermal equation. The advection field is automatically set as the mass flux. By default, the temperature is solved in Celsius and homogeneous Neumann boundary conditions (no flux) are set. The variation of mass density around a reference value is related to the variation of temperature w.r.t. a reference temperature and it plays a role in the gravity effects (rho.vect(g)) The gradient of temperature is assumed to have a small norm and the mass density variates in a small range. In this case, an additional momentum source term is added.
The Navier-Stokes is modified to take into account solidification process. A boussinesq term is added as well as a head loss term derived from a Darcy approximation. Please see the cs_solidification_model_t structure and related structures for more details
◆ cs_navsto_param_model_t
Enumerator
Stokes equations (mass and momentum) with the classical choice of variables i.e. velocity and pressure. Mass density is assumed to be constant.
Like the incompressible Navier-Stokes equations (mass and momentum) but with a velocity field which is given. Thus the advection term in the momentum equation is linear. Unknowns: velocity and pressure. Mass density is assumed to be constant. The advection field is set using cs_navsto_add_oseen_field
Navier-Stokes equations: mass and momentum with a constant mass density Mass equation is equivalent to an incompressibility constraint
CS_NAVSTO_N_MODELS
◆ cs_navsto_param_norm_type_t
Enumerator
Classical Euclidean l2 norm in the volume mesh
Classical Euclidean l2 norm plus a l2 norm for the divergence of the mass flux in the volume mesh
Euclidean l2 norm on the mesh skeleton
◆ cs_navsto_param_num_bit_t
Enumerator
Use pseudo-steady algorith to solve stationnary problem with unsteady model.
◆ cs_navsto_param_post_bit_t
Enumerator
Compute div(u) and associate a field to this quantity
Compute $ rho/2 u\cdot u $ and associate a field to this quantity
Compute w = curl(u) and associate a field to this quantity
Compute the tensor grad(u) and associate a field to this quantity
Add an equation to compute the stream function and associate a field to this quantity. This equation is a scalar valued diffusion equation: -Lap(Psi) = w_z This is only useful for a 2D computation (assuming that the z-azis is the extruded one, i.e. the flow is in the x-y plane
Compute $ h = u \cdot w $ and associate a field to this quantity
Compute $ w \cdot w $ and associate a field to this quantity
Compute the mass density in each cell and monitor the evolution of the integral of the mass in the full computational domain. If a Boussinesq approximation is set, then the mass density used in the buoyancy term is considered (not the reference value assumed to be constant).
Compute the balance of the mass flux for each cell. When the mass density is constant, this quantity is only a scaling (by the mass density) of the quantity computed with the flag CS_NAVSTO_POST_VELOCITY_DIVERGENCE.
Compute the presure gradient in each cell.
Compute the boundary stress and associate a field to this quantity.
◆ cs_navsto_add_oseen_field()
void cs_navsto_add_oseen_field ( cs_navsto_param_t *  nsp,
cs_adv_field_t *  adv_fld
[in,out]nsppointer to a cs_navsto_param_t
[in,out]adv_fldpointer to a cs_adv_field_t
◆ cs_navsto_add_pressure_ic_by_analytic()
cs_xdef_t * cs_navsto_add_pressure_ic_by_analytic ( cs_navsto_param_t *  nsp,
const char *  z_name,
cs_analytic_func_t *  analytic,
void *  input
[in]z_namename of the associated zone (if null or "" if all cells are considered)
[in]analyticpointer to an analytic function
[in]inputnull or pointer to a structure cast on-the-fly
a pointer to the new cs_xdef_t structure
◆ cs_navsto_add_pressure_ic_by_value()
cs_xdef_t * cs_navsto_add_pressure_ic_by_value ( cs_navsto_param_t *  nsp,
cs_real_t  val
[in]valpointer to the value
◆ cs_navsto_add_source_term_by_analytic()
cs_xdef_t * cs_navsto_add_source_term_by_analytic ( cs_navsto_param_t *  nsp,
cs_analytic_func_t *  ana,
void *  input
[in]z_namename of the associated zone (if null or "" all cells are considered)
[in]anapointer to an analytical function
◆ cs_navsto_add_source_term_by_array()
cs_xdef_t * cs_navsto_add_source_term_by_array ( cs_navsto_param_t *  nsp,
cs_flag_t  loc,
cs_real_t *  array,
bool  is_owner,
bool  full_length
[in]locinformation to know where are located values
[in]arraypointer to an array
[in]is_ownertransfer the lifecycle to the cs_xdef_t structure (true or false)
[in]full_lengthif true, array size is allocated and filled to access the full-length array corresponding to all locations where are defined the values
◆ cs_navsto_add_source_term_by_value()
cs_xdef_t * cs_navsto_add_source_term_by_value ( cs_navsto_param_t *  nsp,
[in]valvector value to set
◆ cs_navsto_add_velocity_ic_by_analytic()
cs_xdef_t * cs_navsto_add_velocity_ic_by_analytic ( cs_navsto_param_t *  nsp,
void *  input
◆ cs_navsto_add_velocity_ic_by_value()
cs_xdef_t * cs_navsto_add_velocity_ic_by_value ( cs_navsto_param_t *  nsp,
◆ cs_navsto_param_add_boussinesq_term()
cs_navsto_param_boussinesq_t * cs_navsto_param_add_boussinesq_term ( cs_navsto_param_t *  nsp,
[in,out]nsppointer to a cs_navsto_param_t struct.
[in]dilatation_coefvalue of the dilatation coefficient
[in]reference_valuereference value of the associated variable
a pointer to the newly added structure
◆ cs_navsto_param_create()
cs_navsto_param_t * cs_navsto_param_create ( const cs_boundary_t *  boundaries,
[in]boundariespointer to a cs_boundary_t structure
[in]modeltype of model related to the NS system
[in]model_flagadditional high-level model options
[in]algo_couplingalgorithm used for solving the NS system
[in]post_flagpredefined post-processings options
a pointer to a new allocated structure
◆ cs_navsto_param_free()
cs_navsto_param_t * cs_navsto_param_free ( cs_navsto_param_t *  param)
[in,out]parampointer to a cs_navsto_param_t structure
a null pointer
◆ cs_navsto_param_get_coupling_name()
const char * cs_navsto_param_get_coupling_name ( cs_navsto_param_coupling_t  coupling)
[in]couplinga cs_navsto_param_coupling_t
the name
◆ cs_navsto_param_get_model_name()
const char * cs_navsto_param_get_model_name ( cs_navsto_param_model_t  model)
[in]modela cs_navsto_param_model_t
the corresponding name
◆ cs_navsto_param_get_velocity_param()
cs_equation_param_t * cs_navsto_param_get_velocity_param ( const cs_navsto_param_t *  nsp)
a pointer to the set of parameters related to the momentum equation
◆ cs_navsto_param_is_steady()
static bool cs_navsto_param_is_steady ( const cs_navsto_param_t *  nsp)
inlinestatic
true or false
◆ cs_navsto_param_log()
void cs_navsto_param_log ( const cs_navsto_param_t *  nsp)
◆ cs_navsto_param_set()
void cs_navsto_param_set ( cs_navsto_param_t *  nsp,
const char *  keyval
[in,out]nsppointer to a cs_navsto_param_t structure to set
[in]keykey related to the member of eq to set
[in]keyvalaccessor to the value to set
◆ cs_navsto_param_set_boussinesq_array()
void cs_navsto_param_set_boussinesq_array ( cs_navsto_param_boussinesq_t *  bp,
const cs_real_t *  var
[in,out]bppointer to a cs_navsto_param_boussinesq_t structure
[in]varshared pointer to the array of values to consider
◆ cs_navsto_param_set_quadrature_to_all()
void cs_navsto_param_set_quadrature_to_all ( cs_navsto_param_t *  nsp,
[in]qtypetype of quadrature to apply
◆ cs_navsto_param_transfer()
void cs_navsto_param_transfer ( const cs_navsto_param_t *  nsp,
cs_equation_param_t *  eqp
[in,out]eqppointer to a cs_equation_param_t structure
◆ cs_navsto_set_fixed_walls()
void cs_navsto_set_fixed_walls ( cs_navsto_param_t *  nsp)
◆ cs_navsto_set_outlets()
void cs_navsto_set_outlets ( cs_navsto_param_t *  nsp)
◆ cs_navsto_set_pressure_bc_by_value()
cs_xdef_t * cs_navsto_set_pressure_bc_by_value ( cs_navsto_param_t *  nsp,
cs_real_t  values
[in]z_namename of the associated zone (if null or "" all boundary faces are considered)
[in]valuesvalue to set
◆ cs_navsto_set_reference_pressure()
void cs_navsto_set_reference_pressure ( cs_navsto_param_t *  nsp,
cs_real_t  pref
[in]prefvalue of the reference pressure
◆ cs_navsto_set_symmetries()
void cs_navsto_set_symmetries ( cs_navsto_param_t *  nsp)
◆ cs_navsto_set_velocity_inlet_by_analytic()
cs_xdef_t * cs_navsto_set_velocity_inlet_by_analytic ( cs_navsto_param_t *  nsp,
void *  input
◆ cs_navsto_set_velocity_inlet_by_array()
cs_xdef_t * cs_navsto_set_velocity_inlet_by_array ( cs_navsto_param_t *  nsp,
cs_flag_t  loc,
cs_real_t *  array,
bool  is_owner,
bool  full_length
[in]full_lengthif true, the size of "array" should be allocated to the total numbers of entities related to the given location. If false, a new list is allocated and filled with the related subset indirection.
◆ cs_navsto_set_velocity_inlet_by_dof_func()
cs_xdef_t * cs_navsto_set_velocity_inlet_by_dof_func ( cs_navsto_param_t *  nsp,
cs_flag_t  dof_loc,
cs_dof_func_t *  func,
void *  func_input
[in]dof_locwhere are located DoFs
[in]funcpointer to a cs_dof_function_t
[in]func_inputnull or pointer to a structure cast on-the-fly
◆ cs_navsto_set_velocity_inlet_by_value()
cs_xdef_t * cs_navsto_set_velocity_inlet_by_value ( cs_navsto_param_t *  nsp,
[in]valuesarray of three real values
◆ cs_navsto_set_velocity_wall_by_value()
cs_xdef_t * cs_navsto_set_velocity_wall_by_value ( cs_navsto_param_t *  nsp,
