cs_navsto_param.h
1#ifndef CS_NAVSTO_PARAM_H
2#define CS_NAVSTO_PARAM_H
5 * Functions to handle cs_navsto_param_t structure
28/*----------------------------------------------------------------------------
29 * Local headers
30 *----------------------------------------------------------------------------*/
32#include "alge/cs_param_sles.h"
33#include "base/cs_boundary.h"
34#include "base/cs_math.h"
36#include "cdo/cs_cdo_blas.h"
39#include "cdo/cs_iter_algo.h"
41/*============================================================================
42 * Macro definitions
43 *============================================================================*/
45/* Manage the naming of properties, variables and equations related to the
46 * Navier-Stokes module
47 */
48
49#define CS_NAVSTO_STREAM_EQNAME "streamfunction_eq"
50
51/*============================================================================
52 * Type definitions
53 *============================================================================*/
54
58
80typedef enum {
81
85
87
89
129typedef enum {
130
131 CS_NAVSTO_MODEL_STEADY = 1<<0, /* = 1 */
135 CS_NAVSTO_MODEL_BOUSSINESQ = 1<<4, /* = 16 */
137
139
190typedef enum {
191
194 CS_NAVSTO_POST_VORTICITY = 1<< 2, /* = 4 */
197 CS_NAVSTO_POST_HELICITY = 1<< 5, /* = 32 */
198 CS_NAVSTO_POST_ENSTROPHY = 1<< 6, /* = 64 */
199 CS_NAVSTO_POST_MASS_DENSITY = 1<< 7, /* = 128 */
202 CS_NAVSTO_POST_BOUNDARY_STRESS = 1 << 10, /* = 1024 */
203
205
216typedef enum {
217
218 CS_NAVSTO_NUM_PSEUDO_STEADY = 1 << 0, /* = 1 */
219
221
237typedef enum {
238
242
244
246
262typedef enum {
263
267
269
271
277typedef struct {
278
279 cs_real_t beta; /* Dilatation coefficient */
280 cs_real_t var0; /* Reference value of the variable */
281
282 /* Array of values of the variable (for instance the temperature). This is a
283 * shared pointer. The lifecycle of this array is not managed by this
284 * structure.
285 */
286
288
290
296typedef struct {
297
310
316
322
335
342
350
356
369
375
381
382 /* Boussinesq approximation:
383 *
384 * Take into account buoyancy terms (variation of mass density w.r.t. the
385 * variation of a field (for instance the temperature but can be also a
386 * concentration as in segregation model in the solidification module)
387 *
388 * \var n_boussinesq_terms
389 * Number of contributions to the buoyancy source term in the Boussinesq
390 * approximation
391 *
392 * \var boussinesq_param
393 * Structure storing elements used to compute the Boussinesq approximation
394 */
395
398
413
427
434
442
450
457
465
474
485
491
497
527
545
554 /* \var boundaries
555 * Pointer to a \ref cs_boundary_t structure shared with the domain
556 */
557
559
578
595
607
611
670typedef enum {
671
686
688
690
691/*============================================================================
692 * Inline static public function prototypes
693 *============================================================================*/
694
695/*----------------------------------------------------------------------------*/
704/*----------------------------------------------------------------------------*/
705
706static inline bool
708{
709 if (nsp == NULL)
710 return true;
711
713 return true;
714 else
715 return false;
716}
717
718/*============================================================================
719 * Public function prototypes
720 *============================================================================*/
721
722/*----------------------------------------------------------------------------*/
735/*----------------------------------------------------------------------------*/
736
738cs_navsto_param_create(const cs_boundary_t *boundaries,
741 cs_navsto_param_coupling_t algo_coupling,
743
744/*----------------------------------------------------------------------------*/
752/*----------------------------------------------------------------------------*/
753
756
757/*----------------------------------------------------------------------------*/
766/*----------------------------------------------------------------------------*/
767
768void
770 cs_navsto_key_t key,
771 const char *keyval);
772
773/*----------------------------------------------------------------------------*/
785/*----------------------------------------------------------------------------*/
786
787void
790
791/*----------------------------------------------------------------------------*/
797/*----------------------------------------------------------------------------*/
798
799void
801
802/*----------------------------------------------------------------------------*/
812/*----------------------------------------------------------------------------*/
813
816 cs_real_t dilatation_coef,
817 cs_real_t reference_value);
818
819/*----------------------------------------------------------------------------*/
826/*----------------------------------------------------------------------------*/
827
828void
830 const cs_real_t *var);
831
832/*----------------------------------------------------------------------------*/
841/*----------------------------------------------------------------------------*/
842
845
846/*----------------------------------------------------------------------------*/
854/*----------------------------------------------------------------------------*/
855
856const char *
858
859/*----------------------------------------------------------------------------*/
867/*----------------------------------------------------------------------------*/
868
869const char *
871
872/*----------------------------------------------------------------------------*/
880/*----------------------------------------------------------------------------*/
881
882void
885
886/*----------------------------------------------------------------------------*/
893/*----------------------------------------------------------------------------*/
894
895void
897 cs_real_t pref);
898
899/*----------------------------------------------------------------------------*/
913/*----------------------------------------------------------------------------*/
914
915cs_xdef_t *
917 const char *z_name,
918 const cs_real_3_t val);
919
920/*----------------------------------------------------------------------------*/
935/*----------------------------------------------------------------------------*/
936
937cs_xdef_t *
939 const char *z_name,
940 cs_analytic_func_t *analytic,
941 void *input);
942
943/*----------------------------------------------------------------------------*/
957/*----------------------------------------------------------------------------*/
958
959cs_xdef_t *
961 const char *z_name,
962 cs_real_t val);
963
964/*----------------------------------------------------------------------------*/
979/*----------------------------------------------------------------------------*/
980
981cs_xdef_t *
983 const char *z_name,
984 cs_analytic_func_t *analytic,
985 void *input);
986
987/*----------------------------------------------------------------------------*/
995/*----------------------------------------------------------------------------*/
996
997void
999
1000/*----------------------------------------------------------------------------*/
1008/*----------------------------------------------------------------------------*/
1009
1010void
1012
1013/*----------------------------------------------------------------------------*/
1021/*----------------------------------------------------------------------------*/
1022
1023void
1025
1026/*----------------------------------------------------------------------------*/
1037/*----------------------------------------------------------------------------*/
1038
1039cs_xdef_t *
1041 const char *z_name,
1042 cs_real_t values);
1043
1044/*----------------------------------------------------------------------------*/
1056/*----------------------------------------------------------------------------*/
1057
1058cs_xdef_t *
1060 const char *z_name,
1061 const cs_real_3_t values);
1062
1063/*----------------------------------------------------------------------------*/
1075/*----------------------------------------------------------------------------*/
1076
1077cs_xdef_t *
1079 const char *z_name,
1080 const cs_real_3_t values);
1081
1082/*----------------------------------------------------------------------------*/
1095/*----------------------------------------------------------------------------*/
1096
1097cs_xdef_t *
1099 const char *z_name,
1100 cs_analytic_func_t *ana,
1101 void *input);
1102
1103/*----------------------------------------------------------------------------*/
1122/*----------------------------------------------------------------------------*/
1123
1124cs_xdef_t *
1126 const char *z_name,
1127 cs_flag_t loc,
1128 cs_real_t *array,
1129 bool is_owner,
1130 bool full_length);
1131
1132/*----------------------------------------------------------------------------*/
1145/*----------------------------------------------------------------------------*/
1146
1147cs_xdef_t *
1149 const char *z_name,
1150 cs_flag_t dof_loc,
1151 cs_dof_func_t *func,
1152 void *func_input);
1153
1154/*----------------------------------------------------------------------------*/
1166/*----------------------------------------------------------------------------*/
1167
1168cs_xdef_t *
1170 const char *z_name,
1171 cs_analytic_func_t *ana,
1172 void *input);
1173
1174/*----------------------------------------------------------------------------*/
1185/*----------------------------------------------------------------------------*/
1186
1187cs_xdef_t *
1189 const char *z_name,
1190 const cs_real_3_t val);
1191
1192/*----------------------------------------------------------------------------*/
1209/*----------------------------------------------------------------------------*/
1210
1211cs_xdef_t *
1213 const char *z_name,
1214 cs_flag_t loc,
1215 cs_real_t *array,
1216 bool is_owner,
1217 bool full_length);
1218
1219/*----------------------------------------------------------------------------*/
1226/*----------------------------------------------------------------------------*/
1227
1228void
1230 cs_adv_field_t *adv_fld);
1231
1232#endif /* CS_NAVSTO_PARAM_H */
cs_real_t() cs_cdo_blas_square_norm_t(const cs_real_t *array)
Generic function pointer for computing a square norm. Parallel synchronization is performed inside th...
Definition: cs_cdo_blas.h:73
cs_real_t() cs_cdo_blas_square_norm_diff_t(const cs_real_t *a, const cs_real_t *b)
Generic function pointer for computing a square norm of the difference between two arrays (defined at...
Definition: cs_cdo_blas.h:90
cs_real_t() cs_cdo_blas_dotprod_t(const cs_real_t *a, const cs_real_t *b)
Generic function pointer for computing a dot product. Parallel synchronization is performed inside th...
Definition: cs_cdo_blas.h:59
Definition: cs_defs.h:332
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:349
unsigned short int cs_flag_t
Definition: cs_defs.h:334
void cs_navsto_param_transfer(const cs_navsto_param_t *nsp, cs_equation_param_t *eqp)
Apply the numerical settings defined for the Navier-Stokes system to an equation related to this syst...
Definition: cs_navsto_param.cpp:645
void cs_navsto_set_fixed_walls(cs_navsto_param_t *nsp)
Add the definition of boundary conditions related to a fixed wall into the set of parameters for the ...
Definition: cs_navsto_param.cpp:1309
void cs_navsto_set_symmetries(cs_navsto_param_t *nsp)
Add the definition of boundary conditions related to a symmetry into the set of parameters for the ma...
Definition: cs_navsto_param.cpp:1365
void cs_navsto_param_set_quadrature_to_all(cs_navsto_param_t *nsp, cs_quadrature_type_t qtype)
Apply the given quadrature rule to all existing definitions under the cs_navsto_param_t structure.
Definition: cs_navsto_param.cpp:1013
cs_xdef_t * cs_navsto_add_source_term_by_analytic(cs_navsto_param_t *nsp, const char *z_name, cs_analytic_func_t *ana, void *input)
Define a new source term structure defined by an analytical function.
Definition: cs_navsto_param.cpp:1902
cs_flag_t cs_navsto_param_post_flag_t
Definition: cs_navsto_param.h:56
void cs_navsto_set_reference_pressure(cs_navsto_param_t *nsp, cs_real_t pref)
Set the value to consider for the reference pressure.
Definition: cs_navsto_param.cpp:993
cs_xdef_t * cs_navsto_add_source_term_by_value(cs_navsto_param_t *nsp, const char *z_name, const cs_real_3_t val)
Define a new source term structure defined by a constant value.
Definition: cs_navsto_param.cpp:1931
cs_xdef_t * cs_navsto_add_velocity_ic_by_value(cs_navsto_param_t *nsp, const char *z_name, const cs_real_3_t val)
Define the initial condition for the velocity unknowns. This definition can be done on a specified me...
Definition: cs_navsto_param.cpp:1084
const char * cs_navsto_param_get_model_name(cs_navsto_param_model_t model)
Retrieve the name of the model system of equations.
Definition: cs_navsto_param.cpp:937
cs_navsto_key_t
List of available keys for setting the parameters of the Navier-Stokes system.
Definition: cs_navsto_param.h:670
@ CS_NSKEY_NL_ALGO_RTOL
Definition: cs_navsto_param.h:677
@ CS_NSKEY_DOF_REDUCTION
Definition: cs_navsto_param.h:672
@ CS_NSKEY_THERMAL_TOLERANCE
Definition: cs_navsto_param.h:684
@ CS_NSKEY_NL_ALGO_ATOL
Definition: cs_navsto_param.h:674
@ CS_NSKEY_NL_ALGO_MAX_ITER
Definition: cs_navsto_param.h:676
@ CS_NSKEY_N_KEYS
Definition: cs_navsto_param.h:687
@ CS_NSKEY_PSTEADY_ALGO_N_CVG_ITER
Definition: cs_navsto_param.h:680
@ CS_NSKEY_PSTEADY_ALGO_ATOL
Definition: cs_navsto_param.h:678
@ CS_NSKEY_NL_ALGO
Definition: cs_navsto_param.h:673
@ CS_NSKEY_PSTEADY_ALGO_N_STEP_SOLVE
Definition: cs_navsto_param.h:681
@ CS_NSKEY_SPACE_SCHEME
Definition: cs_navsto_param.h:683
@ CS_NSKEY_VERBOSITY
Definition: cs_navsto_param.h:685
@ CS_NSKEY_NORM_TYPE
Definition: cs_navsto_param.h:682
@ CS_NSKEY_PSTEADY_ALGO_RTOL
Definition: cs_navsto_param.h:679
@ CS_NSKEY_NL_ALGO_DTOL
Definition: cs_navsto_param.h:675
void cs_navsto_param_set_boussinesq_array(cs_navsto_param_boussinesq_t *bp, const cs_real_t *var)
Set the array of values to consider in the Boussinesq term.
Definition: cs_navsto_param.cpp:880
cs_navsto_param_t * cs_navsto_param_create(const cs_boundary_t *boundaries, cs_navsto_param_model_t model, cs_navsto_param_model_flag_t model_flag, cs_navsto_param_coupling_t algo_coupling, cs_navsto_param_post_flag_t post_flag)
Create a new structure to store all numerical parameters related to the resolution of the Navier-Stok...
Definition: cs_navsto_param.cpp:170
cs_equation_param_t * cs_navsto_param_get_velocity_param(const cs_navsto_param_t *nsp)
Retrieve the cs_equation_param_t structure related to the velocity equation (momentum equation in mos...
Definition: cs_navsto_param.cpp:902
cs_xdef_t * cs_navsto_add_pressure_ic_by_analytic(cs_navsto_param_t *nsp, const char *z_name, cs_analytic_func_t *analytic, void *input)
Define the initial condition for the pressure unknowns. This definition can be done on a specified me...
Definition: cs_navsto_param.cpp:1264
void cs_navsto_add_oseen_field(cs_navsto_param_t *nsp, cs_adv_field_t *adv_fld)
Add a advection field for the Oseen problem.
Definition: cs_navsto_param.cpp:1990
cs_xdef_t * cs_navsto_set_velocity_inlet_by_analytic(cs_navsto_param_t *nsp, const char *z_name, cs_analytic_func_t *ana, void *input)
Define the velocity field for an inlet boundary using an analytical function.
Definition: cs_navsto_param.cpp:1682
cs_xdef_t * cs_navsto_add_pressure_ic_by_value(cs_navsto_param_t *nsp, const char *z_name, cs_real_t val)
Definition: cs_navsto_param.cpp:1214
cs_xdef_t * cs_navsto_add_source_term_by_array(cs_navsto_param_t *nsp, const char *z_name, cs_flag_t loc, cs_real_t *array, bool is_owner, bool full_length)
Define a new source term structure defined by an array.
Definition: cs_navsto_param.cpp:1964
void cs_navsto_param_log(const cs_navsto_param_t *nsp)
Summary of the main cs_navsto_param_t structure.
Definition: cs_navsto_param.cpp:673
cs_xdef_t * cs_navsto_set_velocity_inlet_by_dof_func(cs_navsto_param_t *nsp, const char *z_name, cs_flag_t dof_loc, cs_dof_func_t *func, void *func_input)
Define the velocity field for an inlet boundary using a DoF function.
Definition: cs_navsto_param.cpp:1834
const char * cs_navsto_param_get_coupling_name(cs_navsto_param_coupling_t coupling)
Retrieve the name of the coupling algorithm.
Definition: cs_navsto_param.cpp:965
cs_xdef_t * cs_navsto_set_velocity_inlet_by_value(cs_navsto_param_t *nsp, const char *z_name, const cs_real_3_t values)
Define the velocity field for an inlet boundary using a uniform value.
Definition: cs_navsto_param.cpp:1618
cs_navsto_param_norm_type_t
Choice of the norm for the mass flux used in the non-linear algorithm.
Definition: cs_navsto_param.h:262
@ CS_NAVSTO_PARAM_NORM_L2
Definition: cs_navsto_param.h:264
@ CS_NAVSTO_PARAM_NORM_HDIV
Definition: cs_navsto_param.h:265
@ CS_NAVSTO_PARAM_NORM_TRACE
Definition: cs_navsto_param.h:266
@ CS_NAVSTO_PARAM_N_NORM_TYPES
Definition: cs_navsto_param.h:268
cs_navsto_param_t * cs_navsto_param_free(cs_navsto_param_t *param)
Free a cs_navsto_param_t structure.
Definition: cs_navsto_param.cpp:350
Definition: cs_navsto_param.h:237
@ CS_NAVSTO_N_COUPLINGS
Definition: cs_navsto_param.h:243
@ CS_NAVSTO_COUPLING_ARTIFICIAL_COMPRESSIBILITY
Definition: cs_navsto_param.h:239
@ CS_NAVSTO_COUPLING_PROJECTION
Definition: cs_navsto_param.h:241
@ CS_NAVSTO_COUPLING_MONOLITHIC
Definition: cs_navsto_param.h:240
Describe the system of equations related to the Navier-Stokes to be solved.
Definition: cs_navsto_param.h:80
@ CS_NAVSTO_MODEL_STOKES
Definition: cs_navsto_param.h:82
@ CS_NAVSTO_MODEL_OSEEN
Definition: cs_navsto_param.h:83
@ CS_NAVSTO_MODEL_INCOMPRESSIBLE_NAVIER_STOKES
Definition: cs_navsto_param.h:84
@ CS_NAVSTO_N_MODELS
Definition: cs_navsto_param.h:86
cs_flag_t cs_navsto_param_model_flag_t
Definition: cs_navsto_param.h:55
cs_navsto_param_boussinesq_t * cs_navsto_param_add_boussinesq_term(cs_navsto_param_t *nsp, cs_real_t dilatation_coef, cs_real_t reference_value)
Add a new Boussinesq term (source term for the momemtum equation)
Definition: cs_navsto_param.cpp:844
cs_xdef_t * cs_navsto_add_velocity_ic_by_analytic(cs_navsto_param_t *nsp, const char *z_name, cs_analytic_func_t *analytic, void *input)
Definition: cs_navsto_param.cpp:1149
cs_navsto_param_post_bit_t
Bit values for additional generic postprocessing related to the Navier-Stokes module....
Definition: cs_navsto_param.h:190
@ CS_NAVSTO_POST_MASS_DENSITY
Definition: cs_navsto_param.h:199
@ CS_NAVSTO_POST_VELOCITY_DIVERGENCE
Definition: cs_navsto_param.h:192
@ CS_NAVSTO_POST_KINETIC_ENERGY
Definition: cs_navsto_param.h:193
@ CS_NAVSTO_POST_HELICITY
Definition: cs_navsto_param.h:197
@ CS_NAVSTO_POST_STREAM_FUNCTION
Definition: cs_navsto_param.h:196
@ CS_NAVSTO_POST_VELOCITY_GRADIENT
Definition: cs_navsto_param.h:195
@ CS_NAVSTO_POST_ENSTROPHY
Definition: cs_navsto_param.h:198
@ CS_NAVSTO_POST_CELL_MASS_FLUX_BALANCE
Definition: cs_navsto_param.h:200
@ CS_NAVSTO_POST_VORTICITY
Definition: cs_navsto_param.h:194
@ CS_NAVSTO_POST_PRESSURE_GRADIENT
Definition: cs_navsto_param.h:201
@ CS_NAVSTO_POST_BOUNDARY_STRESS
Definition: cs_navsto_param.h:202
cs_xdef_t * cs_navsto_set_pressure_bc_by_value(cs_navsto_param_t *nsp, const char *z_name, cs_real_t values)
Set the pressure field on a boundary using a uniform value.
Definition: cs_navsto_param.cpp:1471
void cs_navsto_set_outlets(cs_navsto_param_t *nsp)
Add the definition of boundary conditions related to outlets into the set of parameters for the manag...
Definition: cs_navsto_param.cpp:1416
cs_flag_t cs_navsto_param_num_flag_t
Definition: cs_navsto_param.h:57
cs_xdef_t * cs_navsto_set_velocity_inlet_by_array(cs_navsto_param_t *nsp, const char *z_name, cs_flag_t loc, cs_real_t *array, bool is_owner, bool full_length)
Define the velocity field for an inlet boundary using an array of values.
Definition: cs_navsto_param.cpp:1753
void cs_navsto_param_set(cs_navsto_param_t *nsp, cs_navsto_key_t key, const char *keyval)
Set a parameter attached to a keyname in a cs_navsto_param_t structure.
Definition: cs_navsto_param.cpp:433
cs_xdef_t * cs_navsto_set_velocity_wall_by_value(cs_navsto_param_t *nsp, const char *z_name, const cs_real_3_t values)
Define the velocity field for a sliding wall boundary using a uniform value.
Definition: cs_navsto_param.cpp:1550
cs_navsto_param_num_bit_t
Bit values for additional numeric related to the Navier-Stokes system of equations.
Definition: cs_navsto_param.h:216
@ CS_NAVSTO_NUM_PSEUDO_STEADY
Definition: cs_navsto_param.h:218
static bool cs_navsto_param_is_steady(const cs_navsto_param_t *nsp)
Ask cs_navsto_param_t structure if the settings correspond to a steady computation.
Definition: cs_navsto_param.h:707
cs_navsto_param_model_bit_t
Bit values for additional physical modelling related to the Navier-Stokes system of equations.
Definition: cs_navsto_param.h:129
@ CS_NAVSTO_MODEL_WITH_SOLIDIFICATION
Definition: cs_navsto_param.h:136
@ CS_NAVSTO_MODEL_GRAVITY_EFFECTS
Definition: cs_navsto_param.h:132
@ CS_NAVSTO_MODEL_BOUSSINESQ
Definition: cs_navsto_param.h:135
@ CS_NAVSTO_MODEL_PASSIVE_THERMAL_TRACER
Definition: cs_navsto_param.h:134
@ CS_NAVSTO_MODEL_CORIOLIS_EFFECTS
Definition: cs_navsto_param.h:133
@ CS_NAVSTO_MODEL_STEADY
Definition: cs_navsto_param.h:131
Structure and routines handling the SLES ((Sparse Linear Equation Solver) settings stored inside a cs...
void() cs_dof_func_t(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, void *input, cs_real_t *retval)
Definition: cs_param_types.h:154
cs_param_space_scheme_t
Definition: cs_param_types.h:215
cs_param_nl_algo_t
Class of non-linear iterative algorithm.
Definition: cs_param_types.h:715
cs_param_dof_reduction_t
Definition: cs_param_types.h:244
Type of quadrature to use when computing an integral quantity. This rationale is used for integrals a...
Definition: cs_quadrature.h:79
Definition: cs_advection_field.h:151
Structure storing information related to the "physical" boundaries associated with the computational ...
Definition: cs_boundary.h:154
Structure storing all the parameters to drive the algorithm called Anderson acceleration.
Definition: cs_iter_algo.h:134
Structure storing the parameters related to the Boussinesq source term in the momentum equation.
Definition: cs_navsto_param.h:277
const cs_real_t * var
Definition: cs_navsto_param.h:287
cs_real_t var0
Definition: cs_navsto_param.h:280
cs_real_t beta
Definition: cs_navsto_param.h:279
Definition: cs_navsto_param.h:296
cs_property_t * mass_density
Definition: cs_navsto_param.h:341
int n_velocity_bc_defs
Definition: cs_navsto_param.h:576
cs_cdo_blas_square_norm_t * square_norm
Definition: cs_navsto_param.h:424
cs_xdef_t ** velocity_ic_defs
Definition: cs_navsto_param.h:526
cs_param_nl_algo_t nl_algo_type
Definition: cs_navsto_param.h:433
cs_physical_constants_t * phys_constants
Definition: cs_navsto_param.h:334
cs_iter_algo_param_aac_t anderson_param
Definition: cs_navsto_param.h:456
bool pressure_ic_is_owner
Definition: cs_navsto_param.h:542
Definition: cs_navsto_param.h:309
int n_pressure_ic_defs
Definition: cs_navsto_param.h:543
cs_param_psteady_t psteady_cvg_param
Definition: cs_navsto_param.h:449
int n_pressure_bc_defs
Definition: cs_navsto_param.h:593
cs_xdef_t ** velocity_bc_defs
Definition: cs_navsto_param.h:577
cs_property_t * tot_viscosity
Definition: cs_navsto_param.h:349
cs_turbulence_param_t * turbulence
Definition: cs_navsto_param.h:321
Definition: cs_navsto_param.h:490
bool pressure_bc_is_owner
Definition: cs_navsto_param.h:592
cs_xdef_t ** pressure_bc_defs
Definition: cs_navsto_param.h:594
cs_navsto_param_num_flag_t num_flag
Definition: cs_navsto_param.h:496
Definition: cs_navsto_param.h:315
int n_boussinesq_terms
Definition: cs_navsto_param.h:396
cs_real_t reference_pressure
Definition: cs_navsto_param.h:606
int verbosity
Definition: cs_navsto_param.h:484
bool velocity_bc_is_owner
Definition: cs_navsto_param.h:575
cs_param_dof_reduction_t dof_reduction_mode
Definition: cs_navsto_param.h:368
cs_real_t delta_thermal_tolerance
Definition: cs_navsto_param.h:464
int n_max_outer_iter
Definition: cs_navsto_param.h:473
cs_navsto_param_boussinesq_t * boussinesq_param
Definition: cs_navsto_param.h:397
cs_cdo_blas_dotprod_t * dotprod
Definition: cs_navsto_param.h:426
cs_param_convergence_t nl_cvg_param
Definition: cs_navsto_param.h:441
int n_velocity_ic_defs
Definition: cs_navsto_param.h:525
bool velocity_ic_is_owner
Definition: cs_navsto_param.h:524
cs_cdo_blas_square_norm_diff_t * square_norm_diff
Definition: cs_navsto_param.h:425
const cs_boundary_t * boundaries
Definition: cs_navsto_param.h:558
cs_navsto_param_norm_type_t norm_type
Definition: cs_navsto_param.h:412
cs_property_t * lam_viscosity
Definition: cs_navsto_param.h:355
cs_xdef_t ** pressure_ic_defs
Definition: cs_navsto_param.h:544
cs_param_space_scheme_t space_scheme
Definition: cs_navsto_param.h:380
Definition: cs_navsto_param.h:374
Set of parameters to check the convergence (or the divergence) of an iterative process (tolerances or...
Definition: cs_param_types.h:603
Set of parameters to check the convergence of the pseudo-steady algo.
Definition: cs_param_types.h:631
Physical constants descriptor.
Definition: cs_physical_constants.h:51
Structure storing the parameters related to the resolution of the turbulence modelling....
Definition: cs_cdo_turbulence.h:62
Definition: cs_xdef.h:156
