cs_navsto_projection_t Struct Reference
Set of parameters specific for solving the Navier-Stokes system with an incremental projection algorithm. More...
#include <cs_navsto_coupling.h>
+ Collaboration diagram for cs_navsto_projection_t:
Public Attributes
cs_equation_t * prediction
cs_equation_t * correction
cs_real_t * div_st
cs_real_t * bdy_pressure_incr
cs_field_t * predicted_velocity
cs_field_t * phi
cs_field_t * pressure_incr_gradient
All equations are not always created. It depends on the choice of the model
Member Data Documentation
◆ bdy_pressure_incr
bdy_pressure_incr
Pressure increment at the boundary. Used as an array to set the boundary condition arising from a Dirichlet on the pressure.
◆ correction
cs_equation_t* correction
Pressure correction step related to the mass balance equation (scalar-valued)
◆ div_st
div_st
Source term on the correction step stemming from the divergence of the predicted velocity
◆ phi
phi
pressure-related field
◆ predicted_velocity
predicted_velocity
Predicted velocity field (value of the velocity at cells after the prediction step). This values may not be divergence-free.
◆ prediction
cs_equation_t* prediction
Velocity prediction step related to the momentum balance equation (vector-valued)
◆ pressure_incr_gradient
Gradient of pressure increment. Used to store the gradient pressure increment. Only available with verbosity > 1.
