cs_cdo_quantities.h File Reference
#include "base/cs_base.h"
#include "base/cs_math.h"
#include "cdo/cs_flag.h"
#include "mesh/cs_mesh.h"
+ Include dependency graph for cs_cdo_quantities.h:
Classes
struct  cs_quant_info_t
struct  cs_quant_t
struct  cs_cdo_quantities_t
Enumerations
enum  cs_cdo_quantities_cell_center_algo_t { CS_CDO_QUANTITIES_MEANV_CENTER , CS_CDO_QUANTITIES_BARYC_CENTER , CS_CDO_QUANTITIES_SATURNE_CENTER , CS_CDO_QUANTITIES_SUBDIV_CENTER }
 Type of algorithm used to compute the cell centers. More...
enum  cs_cdo_quantities_bit_t {
  CS_CDO_QUANTITIES_EB_SCHEME = 1 << 0 , CS_CDO_QUANTITIES_FB_SCHEME = 1 << 1 , CS_CDO_QUANTITIES_HHO_SCHEME = 1 << 2 , CS_CDO_QUANTITIES_VB_SCHEME = 1 << 3 ,
  CS_CDO_QUANTITIES_VCB_SCHEME = 1 << 4 , CS_CDO_QUANTITIES_CB_SCHEME = 1 << 5 , CS_CDO_QUANTITIES_MAC_SCHEME = 1 << 6
 Bit values for setting which quantities to compute. More...
static double cs_compute_area_from_quant (const cs_quant_t qa, const cs_real_t *xb)
 Compute the area of the triangle of base given by q (related to a segment) with apex located at xa. More...
long long cs_cdo_quantities_get_time_perfo (void)
 Retrieve the time elapsed to build the cs_cdo_quantities_t structure. More...
void cs_cdo_quantities_set (cs_flag_t option_flag)
 Set which quantities have to be computed. Additionnal quantities are added to cs_cdo_quantities_flag (static variable) More...
void cs_cdo_quantities_set_algo_ccenter (cs_cdo_quantities_cell_center_algo_t algo)
 Set the type of algorithm to use for computing the cell center. More...
cs_cdo_quantities_t * cs_cdo_quantities_build (const cs_mesh_t *m, const cs_mesh_quantities_t *mq, const cs_cdo_connect_t *topo)
 Build a cs_cdo_quantities_t structure. Some quantities are shared with the cs_mesh_quantities_t structure and other are not built according to the given flags in cs_cdo_quantities_flag. More...
cs_cdo_quantities_t * cs_cdo_quantities_free (cs_cdo_quantities_t *cdoq)
 Destroy a cs_cdo_quantities_t structure. More...
void cs_cdo_quantities_free_cell_vol (cs_cdo_quantities_t *cdoq)
 Properly free the cell_vol array according to the settings. More...
const cs_real_t * cs_cdo_quantities_get_pvol_fc (const cs_cdo_quantities_t *cdoq, const cs_adjacency_t *c2f)
 Retrieve the portion of volume surrounding each face of a cell. This volume corresponds to a pyramid with base f and apex x_f The computed quantity is scanned with the c2f adjacency structure. More...
void cs_cdo_quantities_compute_pvol_fc (const cs_cdo_quantities_t *cdoq, const cs_adjacency_t *c2f, cs_real_t **p_pvol_fc)
 Compute the portion of volume surrounding each face of a cell. This volume corresponds to a pyramid with base f and apex x_f The computed quantity is scanned with the c2f adjacency structure. More...
const cs_real_t * cs_cdo_quantities_get_pvol_ec (const cs_cdo_quantities_t *cdoq, const cs_adjacency_t *c2e)
 Retrieve the portion of volume surrounding each edge of a cell. This volume corresponds to an octahedron with a vertical axis defined by the edge. If this quantity does not exist, then one computes it and stores it inside the cdoq structures. The computed quantity is scanned with the c2e adjacency structure. More...
void cs_cdo_quantities_compute_pvol_ec (const cs_cdo_quantities_t *cdoq, const cs_adjacency_t *c2e, cs_real_t **p_pvol_ec)
 Compute the portion of volume surrounding each edge of a cell. The computed quantity is scanned with the c2e adjacency structure. More...
const cs_real_t * cs_cdo_quantities_get_dual_volumes (cs_cdo_quantities_t *cdoq, const cs_cdo_connect_t *connect)
 Compute or retrieve the dual volume surrounding each vertex. The parallel operation (sum reduction) is performed inside this function so that the full dual volume (i.e. taking into account all ranks) is computed. The sum of all the portions of dual cell associated to a vertex in each cell is taken into account. More...
void cs_cdo_quantities_compute_dual_volumes (const cs_cdo_quantities_t *cdoq, const cs_cdo_connect_t *connect, cs_real_t **p_dual_vol)
 Compute the dual volume surrounding each vertex. The parallel operation (sum reduction) is performed inside this function so that the full dual volume (i.e. taking into account all ranks) is computed. The sum of all the portions of dual cell associated to a vertex in each cell is taken into account. More...
void cs_cdo_quantities_compute_i_tef (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, cs_lnum_t f_id, cs_real_t tef[])
 Compute the area of the triangles with basis each edge of the face and apex the face center. Case of interior faces. Storage in agreement with the bf2v adjacency structure. More...
void cs_cdo_quantities_compute_b_tef (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, cs_lnum_t bf_id, cs_real_t tef[])
 Compute the area of the triangles with basis each edge of the face and apex the face center. Case of boundary faces. Storage in agreement with the bf2v adjacency structure. More...
void cs_cdo_quantities_compute_i_wvf (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, cs_lnum_t f_id, cs_real_t wvf[])
 Compute the weight related to each vertex of a face. This weight ensures a 2nd order approximation if the face center is the face barycenter. Case of interior faces. More...
void cs_cdo_quantities_compute_b_wvf (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, cs_lnum_t bf_id, cs_real_t wvf[])
 Compute the weight related to each vertex of a face. This weight ensures a 2nd order approximation if the face center is the face barycenter. Case of boundary faces. More...
void cs_quant_dump (FILE *f, cs_lnum_t num, const cs_quant_t q)
 Dump a cs_quant_t structure. More...
◆ cs_cdo_quantities_bit_t
Enumerator
Geometrical quantities related to edge-based schemes
Geometrical quantities related to face-based schemes
Geometrical quantities related to HHO schemes
Geometrical quantities related to vertex-based schemes
Geometrical quantities related to vertex+cell-based schemes
Geometrical quantities related to cell-based schemes
Geometrical quantities related to MAC face-based schemes
◆ cs_cdo_quantities_cell_center_algo_t
Enumerator
Cell center is computed as the mean of cell vertices
Cell center is computed as the real cell barycenter (default choice relying on an adaptation of the Mirtich algorithm
Cell center corresponds to the one defined in cs_mesh_quantities_t (i.e. one points to the one used in the legacy Finite Volume scheme).
Cell center is computed thanks to an implicit face/cell subdivision into tetrahedra. This may be useful to handle properly meshes with non-planar faces or with a poor mesh quality.
◆ cs_cdo_quantities_build()
cs_cdo_quantities_t * cs_cdo_quantities_build ( const cs_mesh_t *  m,
const cs_mesh_quantities_t *  mq,
const cs_cdo_connect_t *  topo
[in]mpointer to a cs_mesh_t structure
[in]mqpointer to a cs_mesh_quantities_t structure
[in]topopointer to a cs_cdo_connect_t structure
a new allocated pointer to a cs_cdo_quantities_t structure
◆ cs_cdo_quantities_compute_b_tef()
void cs_cdo_quantities_compute_b_tef ( const cs_cdo_connect_t *  connect,
const cs_cdo_quantities_t *  cdoq,
cs_lnum_t  bf_id,
cs_real_t  tef[]
[in]bf_idborder face id
[in,out]tefquantities to compute (pre-allocated)
◆ cs_cdo_quantities_compute_b_wvf()
void cs_cdo_quantities_compute_b_wvf ( const cs_cdo_connect_t *  connect,
cs_lnum_t  bf_id,
cs_real_t  wvf[]
[in,out]wvfquantities to compute (pre-allocated)
◆ cs_cdo_quantities_compute_dual_volumes()
void cs_cdo_quantities_compute_dual_volumes ( const cs_cdo_quantities_t *  cdoq,
cs_real_t **  p_dual_vol
[in]cdoqadditional quantities for CDO schemes
[in]connectadditional connectivities for CDO schemes
[in,out]p_dual_voldouble pointer to the dual volumes related to each vertex. Allocated if null.
[in,out]p_dual_voldouble pointer to the dual volumes related to each vertex. Allocated if nullptr.
◆ cs_cdo_quantities_compute_i_tef()
void cs_cdo_quantities_compute_i_tef ( const cs_cdo_connect_t *  connect,
cs_lnum_t  f_id,
cs_real_t  tef[]
[in]f_idinterior face id
◆ cs_cdo_quantities_compute_i_wvf()
void cs_cdo_quantities_compute_i_wvf ( const cs_cdo_connect_t *  connect,
cs_lnum_t  f_id,
cs_real_t  wvf[]
◆ cs_cdo_quantities_compute_pvol_ec()
void cs_cdo_quantities_compute_pvol_ec ( const cs_cdo_quantities_t *  cdoq,
const cs_adjacency_t *  c2e,
cs_real_t **  p_pvol_ec
[in]cdoqpointer to cs_cdo_quantities_t structure
[in]c2epointer to the cell --> edges connectivity
[in,out]p_pvol_ecdouble pointer to the edge volume in each cell If not allocated before calling this function, one allocates the array storing the volumes
◆ cs_cdo_quantities_compute_pvol_fc()
void cs_cdo_quantities_compute_pvol_fc ( const cs_cdo_quantities_t *  cdoq,
const cs_adjacency_t *  c2f,
cs_real_t **  p_pvol_fc
[in]c2fpointer to the cell --> faces connectivity
[in,out]p_pvol_fcdouble pointer to the face volume in each cell If not allocated before calling this function, one allocates the array storing the volumes
◆ cs_cdo_quantities_free()
cs_cdo_quantities_t * cs_cdo_quantities_free ( cs_cdo_quantities_t *  cdoq)
[in]cdoqpointer to structure to free
a null pointer
◆ cs_cdo_quantities_free_cell_vol()
void cs_cdo_quantities_free_cell_vol ( cs_cdo_quantities_t *  cdoq)
[in,out]cdoqpointer to cs_cdo_quantities_t structure
◆ cs_cdo_quantities_get_dual_volumes()
const cs_real_t * cs_cdo_quantities_get_dual_volumes ( cs_cdo_quantities_t *  cdoq,
[in,out]cdoqadditional quantities for CDO schemes
the dual volume associated to each vertex
◆ cs_cdo_quantities_get_pvol_ec()
const cs_real_t * cs_cdo_quantities_get_pvol_ec ( const cs_cdo_quantities_t *  cdoq,
the volume associated to each edge in each cell
◆ cs_cdo_quantities_get_pvol_fc()
const cs_real_t * cs_cdo_quantities_get_pvol_fc ( const cs_cdo_quantities_t *  cdoq,
the volume associated to each face in each cell
◆ cs_cdo_quantities_get_time_perfo()
long long cs_cdo_quantities_get_time_perfo ( void  )
the value of the time elapsed in ns
◆ cs_cdo_quantities_set()
void cs_cdo_quantities_set ( cs_flag_t  option_flag)
[in]option_flagflag to set geometrical quantities to compute
◆ cs_cdo_quantities_set_algo_ccenter()
void cs_cdo_quantities_set_algo_ccenter ( cs_cdo_quantities_cell_center_algo_t  algo)
[in]algotype of algorithm
◆ cs_compute_area_from_quant()
static double cs_compute_area_from_quant ( const cs_quant_t  qa,
const cs_real_t *  xb
inlinestatic
[in]qapointer to a cs_quant_t structure related to a segment
[in]xbcoordinates of the apex to consider
the value the area of the triangle
◆ cs_quant_dump()
void cs_quant_dump ( FILE *  f,
cs_lnum_t  num,
const cs_quant_t  q
[in]fFILE struct (stdout if nullptr)
[in]numentity number related to this quantity struct.
[in]qcs_quant_t structure to dump
