cdo_navsto_ac_ctx_t Struct Reference
#include <cs_navsto_context.h>
+ Inheritance diagram for cdo_navsto_ac_ctx_t:
+ Collaboration diagram for cdo_navsto_ac_ctx_t:
Public Attributes
cs_navsto_ac_t * coupling_context
Parameters of the algorithm
Easy access to useful features and parameters of the algorithm
bool is_zeta_uniform
Convergence monitoring
Structure used to drive the convergence of high-level iterative algorithms
cs_iter_algo_t * nl_algo
- Public Attributes inherited from cdo_navsto_ctx_t
cs_field_t * velocity
cs_field_t * pressure
cs_field_t * divergence
cs_adv_field_t * adv_field
cs_real_t * mass_flux_array
cs_real_t * mass_flux_array_pre
const cs_boundary_type_t * bf_type
cs_cdo_bc_face_t * pressure_bc
int pressure_rescaling
cs_cdo_apply_boundary_t * apply_fixed_wall
cs_cdo_apply_boundary_t * apply_sliding_wall
cs_cdo_apply_boundary_t * apply_velocity_inlet
cs_cdo_apply_boundary_t * apply_symmetry
cs_timer_counter_t timer
Additional Inherited Members
- Public Member Functions inherited from cdo_navsto_ctx_t
cs_real_t * get_mass_flux (bool previous) const
 Retrieve the mass flux array related to the Navier-Stokes system. More...
Member Data Documentation
◆ coupling_context
coupling_context
Pointer to a cs_navsto_ac_t (owned by cs_navsto_system_t) containing the settings related to an artificial compressibility (AC) algorithm
◆ is_zeta_uniform
is_zeta_uniform
Bool telling if the auxiliary parameter zeta is uniform. Not always necessary: zeta is typically used in Artificial Compressibility algos
◆ nl_algo
nl_algo
Structure driving the convergence of the non-linear algorithm
