cs_iter_algo_t Struct Reference
Structure to handle the convergence of an iterative algorithm. More...
#include <cs_iter_algo.h>
+ Collaboration diagram for cs_iter_algo_t:
Public Attributes
cs_iter_algo_type_t type
cs_param_convergence_t cvg_param
int verbosity
bool header_done
void * context
Metadata to manage an iterative algorithm such as Picard or Uzawa for instance. This structure can handle a two-level (i.e. outer/inner) iterative algorithm since the notion of inner and outer iterations is defined. Nevertheless, only the outer iterative algorithm is managed (information about inner iterations are only for monitoring purposes).
Member Data Documentation
◆ context
context
pointer to structure cast on the fly
◆ cvg_param
cvg_param
structure storing the main settings
◆ header_done
header_done
Is the header line printed ? true or false
◆ type
type
Type of iterative algorithm to consider. Useful to cast on-the-fly the context structure
◆ verbosity
verbosity
Level of printed information
