cs_equation_bc.h File Reference
+ Include dependency graph for cs_equation_bc.h:
Typedefs
typedef void() cs_cdo_apply_boundary_t(short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_property_data_t *pty, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
 Apply a boundary condition for a given face (inlet, outlet, wall, sliding wall, symmetry...) More...
typedef void() cs_cdo_enforce_bc_t(const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, cs_face_mesh_t *fm, cs_hodge_t *hodge, cs_cell_builder_t *cb, cs_cell_sys_t *csys)
 Enforcement of a boundary condition (Dirichlet, Robin, sliding...) More...
void cs_equation_bc_init_boundary_flux (cs_real_t t_eval, const cs_cdo_quantities_t *cdoq, const cs_equation_param_t *eqp, cs_real_t *values)
 Set the values for the normal boundary flux stemming from the Neumann boundary conditions (zero is left where a Dirichlet is set. This can be updated later on) More...
void cs_equation_bc_set_cw_vb (const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, const cs_flag_t vtx_bc_flag[], const cs_real_t dir_values[], cs_real_t t_eval, cs_cell_sys_t *csys, cs_cell_builder_t *cb)
 Set the BC into a cellwise view of the current system. Case of vertex-based schemes. More...
void cs_equation_bc_set_cw_eb (const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, const cs_real_t dir_values[], cs_cell_sys_t *csys, cs_cell_builder_t *cb)
 Set the BC into a cellwise view of the current system. Case of edge-based schemes. More...
void cs_equation_bc_set_cw_fb (const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, const cs_real_t dir_values[], cs_cell_sys_t *csys, cs_cell_builder_t *cb)
 Set the BC into a cellwise view of the current system. Case of CDO Face-based schemes. More...
void cs_equation_bc_set_cw_macfb (const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, const cs_real_t dir_values[], cs_macfb_builder_t *macb, cs_cell_sys_t *csys)
 Set the BC into a cellwise view of the current system. Case of MAC Face-based schemes. More...
void cs_equation_bc_set_cw_cb (const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, const cs_real_t dir_values[], cs_cell_sys_t *csys, cs_cell_builder_t *cb)
 Set the BC into a cellwise view of the current system. Case of Face-based schemes. More...
void cs_equation_bc_set_vertex_flag (const cs_cdo_connect_t *connect, const cs_cdo_bc_face_t *face_bc, cs_flag_t *vflag)
 Define an array of flags for each vertex collecting the flags of associated boundary faces. More...
void cs_equation_bc_set_edge_flag (const cs_cdo_connect_t *connect, const cs_cdo_bc_face_t *face_bc, cs_flag_t *edge_flag)
 Define an array of flags for each edge collecting the flags of associated boundary faces. More...
void cs_equation_bc_dirichlet_at_vertices (cs_real_t t_eval, const cs_mesh_t *mesh, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, cs_flag_t *bcflag, cs_real_t *values)
 Compute the values of the Dirichlet BCs when DoFs are attached to vertices. More...
void cs_equation_bc_dirichlet_at_faces (const cs_mesh_t *mesh, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_equation_param_t *eqp, const cs_cdo_bc_face_t *face_bc, cs_real_t t_eval, cs_real_t *values)
 Compute the values of the Dirichlet BCs at boundary faces. This can be applied to CDO face-based schemes (DoFs are attached to primal faces), to CDO cell-based schemes or even to FV schemes. More...
void cs_equation_bc_mapped_inlet_at_faces (const cs_cdo_quantities_t *quant, const cs_field_t *val_c, const cs_time_step_t *ts, cs_real_t *values)
 Compute the values of the Dirichlet BCs at boundary faces for mapped inlet only. Be careful, its overwrites BC inlet. This can be applied to CDO face-based schemes (DoFs are attached to primal faces) More...
void cs_equation_compute_neumann_svb (cs_real_t t_eval, short int def_id, short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, double *neu_values)
 Compute the values of the Neumann BCs when DoFs are scalar-valued and attached to a vertex-based schemes (Vb or VCb) Case of the Neumann BCs i.e. Neumann is defined by a scalar. More...
void cs_equation_compute_full_neumann_svb (cs_real_t t_eval, short int def_id, short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, double *neu_values)
 Compute the values of the Neumann BCs when DoFs are scalar-valued and attached to a vertex-based schemes (Vb or VCb) Case of the full Neumann BCs i.e. Neumann is defined by a vector. More...
void cs_equation_compute_neumann_sfb (cs_real_t t_eval, short int def_id, short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, double *neu_values)
 Compute the values of the Neumann BCs when DoFs are attached to the face f. Case of scalar-valued equation (not full Neumann BCs) More...
void cs_equation_compute_full_neumann_sfb (cs_real_t t_eval, short int def_id, short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, double *neu_values)
 Compute the values of the Neumann BCs when DoFs are attached to the face f. Case of scalar-valued equation with a full Neumann BC definition. More...
void cs_equation_compute_neumann_vfb (cs_real_t t_eval, short int def_id, short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, double *neu_values)
 Compute the values of the Neumann BCs at the face f when DoFs are attached to faces. Case of vector-valued equation (not the full Neumann) More...
void cs_equation_bc_cw_robin (cs_real_t t_eval, short int def_id, short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, double *rob_values)
 Compute the values of the Robin BCs for a face (cell-wise compute relying on the cs_cell_mesh_t structure) More...
void cs_equation_bc_cw_turb_smooth_wall (cs_real_t t_eval, short int def_id, short int f, const cs_equation_param_t *eqp, const cs_cell_mesh_t *cm, const cs_real_t nu, const cs_real_t k, const cs_real_t hfc, const cs_real_t *uc, const cs_real_t *uf, double *rob_values)
void cs_equation_bc_circulation_at_edges (cs_real_t t_eval, const cs_mesh_t *mesh, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_equation_param_t *eqp, cs_real_t *values)
 Compute the values of the circulation along primal edges lying on the domain boundary (the integral of the tangential component of vector-valued field). This is used for CDO edge-based schemes where DoFs are attached to (primal) edge-based schemes. More...
void cs_equation_bc_update_for_increment (cs_cell_sys_t *csys)
 Update the boundary conditions to fullfill the constraint when an incremental solve is set. More...
Typedef Documentation
◆ cs_cdo_apply_boundary_t
[in]fface id in the cell mesh numbering
[in]eqppointer to a cs_equation_param_t struct.
[in]ptypointer to a cs_property_data_t structure
[in,out]csysstructure storing the cell-wise system
◆ cs_cdo_enforce_bc_t
[in,out]fmpointer to a cs_face_mesh_t structure
[in,out]hodgepointer to a cs_hodge_t structure
◆ cs_equation_bc_circulation_at_edges()
void cs_equation_bc_circulation_at_edges ( cs_real_t  t_eval,
const cs_mesh_t *  mesh,
cs_real_t *  values
[in]t_evaltime at which one evaluates the boundary cond.
[in,out]valuespointer to the array of values to set
◆ cs_equation_bc_cw_robin()
void cs_equation_bc_cw_robin ( cs_real_t  t_eval,
short int  def_id,
short int  f,
const cs_cell_mesh_t *  cm,
double *  rob_values
[in]def_idid of the definition for setting the Neumann BC
[in]flocal face number in the cs_cell_mesh_t
[in,out]rob_valuesarray storing Robin values to use
◆ cs_equation_bc_cw_turb_smooth_wall()
void cs_equation_bc_cw_turb_smooth_wall ( cs_real_t  t_eval,
short int  def_id,
short int  f,
const cs_real_t  nu,
const cs_real_t  kener,
const cs_real_t *  uc,
const cs_real_t *  uf,
double *  rob_values
[in]nulaminar kinematic viscosity
[in]kturbulent kinetic energy
[in]hfcdistance from cell center to the wall
[in]uccell velocity
[in]ufface velocity
[in]kenerturbulent kinetic energy
[in]uccell velocity
[in]ufface velocity
◆ cs_equation_bc_dirichlet_at_faces()
void cs_equation_bc_dirichlet_at_faces ( const cs_mesh_t *  mesh,
const cs_cdo_bc_face_t *  face_bc,
cs_real_t  t_eval,
cs_real_t *  values
[in]face_bcpointer to a cs_cdo_bc_face_t structure
◆ cs_equation_bc_dirichlet_at_vertices()
void cs_equation_bc_dirichlet_at_vertices ( cs_real_t  t_eval,
cs_flag_t *  bcflag,
cs_real_t *  values
[in,out]bcflagpointer to an array storing type of BC
◆ cs_equation_bc_init_boundary_flux()
void cs_equation_bc_init_boundary_flux ( cs_real_t  t_eval,
const cs_cdo_quantities_t *  cdoq,
cs_real_t *  values
◆ cs_equation_bc_mapped_inlet_at_faces()
void cs_equation_bc_mapped_inlet_at_faces ( const cs_cdo_quantities_t *  quant,
const cs_field_t *  val_c,
const cs_time_step_t *  ts,
cs_real_t *  values
[in]val_cpointer to a cs_field_t structure
[in]tspointer to a cs_time_step_t structure
◆ cs_equation_bc_set_cw_cb()
void cs_equation_bc_set_cw_cb ( const cs_cell_mesh_t *  cm,
cs_cell_sys_t *  csys,
cs_cell_builder_t *  cb
[in]cmpointer to a cellwise view of the mesh
[in]dir_valuesDirichlet values associated to each face
[in]dir_valuesDirichlet values associated to each vertex
◆ cs_equation_bc_set_cw_eb()
void cs_equation_bc_set_cw_eb ( const cs_cell_mesh_t *  cm,
◆ cs_equation_bc_set_cw_fb()
void cs_equation_bc_set_cw_fb ( const cs_cell_mesh_t *  cm,
◆ cs_equation_bc_set_cw_macfb()
void cs_equation_bc_set_cw_macfb ( const cs_cell_mesh_t *  cm,
cs_macfb_builder_t *  macb,
[in,out]macbpointer to a cs_macfb_builder_t strucuture
[in]dir_valuesDirichlet values associated to each faces
◆ cs_equation_bc_set_cw_vb()
void cs_equation_bc_set_cw_vb ( const cs_cell_mesh_t *  cm,
cs_real_t  t_eval,
[in]vtx_bc_flagBC flags associated to vertices
◆ cs_equation_bc_set_edge_flag()
void cs_equation_bc_set_edge_flag ( const cs_cdo_connect_t *  connect,
cs_flag_t *  edge_flag
[in]face_bcpointer to a structure collecting boundary conditions applied to faces
[in,out]edge_flagBC flag on edges to define
◆ cs_equation_bc_set_vertex_flag()
void cs_equation_bc_set_vertex_flag ( const cs_cdo_connect_t *  connect,
cs_flag_t *  vflag
[in,out]vflagBC flag on vertices to define
◆ cs_equation_bc_update_for_increment()
void cs_equation_bc_update_for_increment ( cs_cell_sys_t *  csys)
[in,out]csyspointer to the cell system structure
◆ cs_equation_compute_full_neumann_sfb()
void cs_equation_compute_full_neumann_sfb ( cs_real_t  t_eval,
short int  def_id,
short int  f,
double *  neu_values
[in,out]neu_valuesarray storing Neumann values for all DoFs
◆ cs_equation_compute_full_neumann_svb()
void cs_equation_compute_full_neumann_svb ( cs_real_t  t_eval,
short int  def_id,
short int  f,
double *  neu_values
[in,out]neu_valuesarray storing the Neumann values for all DoFs
◆ cs_equation_compute_neumann_sfb()
void cs_equation_compute_neumann_sfb ( cs_real_t  t_eval,
short int  def_id,
short int  f,
double *  neu_values
◆ cs_equation_compute_neumann_svb()
void cs_equation_compute_neumann_svb ( cs_real_t  t_eval,
short int  def_id,
short int  f,
double *  neu_values
◆ cs_equation_compute_neumann_vfb()
void cs_equation_compute_neumann_vfb ( cs_real_t  t_eval,
short int  def_id,
short int  f,
double *  neu_values
[in,out]neu_valuesarray storing Neumann values at DoFs
