cs_turbulence_model.cpp File Reference
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "base/cs_assert.h"
#include "base/cs_field.h"
#include "base/cs_function.h"
#include "alge/cs_gradient.h"
#include "base/cs_log.h"
#include "base/cs_log_iteration.h"
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "mesh/cs_mesh.h"
#include "base/cs_parall.h"
#include "base/cs_wall_functions.h"
+ Include dependency graph for cs_turbulence_model.cpp:
void cs_turbulence_init_models (void)
 Initialize additional turbulence model members of turbulence model and RANS model structure. More...
cs_turb_model_t * cs_get_glob_turb_model (void)
 Provide write access to turbulence model structure. More...
void cs_set_glob_turb_model (void)
 Set global pointer to turbulence model structure. More...
void cs_turb_compute_constants (int phase_id)
 Compute turbulence model constants, some of which may depend on the model choice. More...
cs_turb_ref_values_t * cs_get_glob_turb_ref_values (void)
 Provide access to cs_glob_turb_ref_values. More...
cs_turb_rans_model_t * cs_get_glob_turb_rans_model (void)
 Provide access to cs_glob_turb_rans_model. More...
cs_turb_les_model_t * cs_get_glob_turb_les_model (void)
 Provide access to cs_glob_turb_les_model. More...
cs_turb_hybrid_model_t * cs_get_glob_turb_hybrid_model (void)
 Provide access to cs_glob_turb_hybrid_model. More...
const char * cs_turbulence_model_name (cs_turb_model_type_t id)
 Return name string associated with a turbulence model value. More...
void cs_turb_model_log_setup (void)
 Print the turbulence model parameters to setup.log. More...
void cs_turb_constants_log_setup (void)
 Print the turbulent constants to setup.log. More...
void cs_turb_init_ref_quantities (void)
 Compute characteristic length for turbulence if not already done. More...
void cs_clip_turbulent_fluxes (int flux_id, int variance_id)
 Clipping for the turbulence flux vector. More...
void cs_turbulence_function_k (int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals)
 Return or estimate the value of the turbulent kinetic energy over specified elements. More...
void cs_turbulence_function_eps (int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals)
 Return or estimate the value of the turbulent dissipation over specified elements. More...
void cs_turbulence_function_rij (int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals)
 Return or estimate the value of the Reynolds stresses over specified elements. More...
double cs_turb_xkappa = 0.42
double cs_turb_vdriest = 25.6
double cs_turb_cstlog = 5.2
double cs_turb_cstlog_rough = 8.5
double cs_turb_cstlog_alpha
double cs_turb_apow = 8.3
double cs_turb_bpow = 1.0/7.0
double cs_turb_dpow = -1.
double cs_turb_cmu = 0.09
double cs_turb_ce1 = 1.44
double cs_turb_ce2 = 1.92
double cs_turb_ce3 = 1.44
double cs_turb_ce4 = 1.20
double cs_turb_crij_eps = 1.
double cs_turb_crij1 = 1.80
double cs_turb_crij2 = 0.60
double cs_turb_crij_c0 = 3.5
double cs_turb_crij_ct = 1.
double cs_turb_crij3 = 0.55
double cs_turb_crijp1 = 0.50
double cs_turb_crijp2 = 0.30
double cs_turb_cssgs1 = 1.70
double cs_turb_cssgs2 = -1.05
double cs_turb_cssgr1 = 0.90
double cs_turb_cssgr2 = 0.80
double cs_turb_cssgr3 = 0.65
double cs_turb_cssgr4 = 0.625
double cs_turb_cssgr5 = 0.20
double cs_turb_cebms1 = 1.70
double cs_turb_cebms2 = 0.
double cs_turb_cebmr1 = 0.90
double cs_turb_cebmr2 = 0.80
double cs_turb_cebmr3 = 0.65
double cs_turb_cebmr4 = 0.625
double cs_turb_cebmr5 = 0.20
double cs_turb_csrij
double cs_turb_cebmmu = 0.22
double cs_turb_xcl = 0.122
double cs_turb_xa1 = 0.1
double cs_turb_xct = 6.0
double cs_turb_xceta = 80.0
double cs_turb_cpale3 = 2.3
double cs_turb_cpale4 = 0.4
double cs_turb_cpalc1 = 1.7
double cs_turb_cpalc2 = 0.9
double cs_turb_cpalct = 4.0
double cs_turb_cpalcl = 0.164
double cs_turb_cpalet = 75.0
double cs_turb_ckwsk1 = 1.0/0.85
double cs_turb_ckwsk2 = 1.0
double cs_turb_ckwsw1 = 2.0
double cs_turb_ckwsw2 = 1.0/0.856
double cs_turb_ckwbt1 = 0.075
double cs_turb_ckwbt2 = 0.0828
double cs_turb_ckwgm1 = -1.
double cs_turb_ckwgm2 = -1.
double cs_turb_ckwa1 = 0.31
double cs_turb_ckwc1 = 10.0
double cs_turb_cddes = 0.65
double cs_turb_csas = 0.11
double cs_turb_csas_eta2 = 3.51
double cs_turb_chtles_bt0 = 0.48
double cs_turb_csab1 = 0.1355
double cs_turb_csab2 = 0.622
double cs_turb_csasig = 2.0/3.0
double cs_turb_csav1 = 7.1
double cs_turb_csaw1 = -1.
double cs_turb_csaw2 = 0.3
double cs_turb_csaw3 = 2.0
double cs_turb_cssr1 = 1.0
double cs_turb_cssr2 = 2.0
double cs_turb_cssr3 = 1.0
double cs_turb_ccaze2 = 1.83
double cs_turb_ccazsc = 0.119
double cs_turb_ccaza = 4.3
double cs_turb_ccazb = 5.130
double cs_turb_ccazc = 0.453
double cs_turb_ccazd = 0.682
double cs_turb_xlesfl = 2.0
double cs_turb_ales = 1.0
double cs_turb_bles = 1.0/3.0
double cs_turb_csmago = 0.065
double cs_turb_xlesfd = 1.5
double cs_turb_csmago_max = -1.
double cs_turb_csmago_min = 0.
double cs_turb_cdries = 26.0
double cs_turb_cv2fa1 = 0.05
double cs_turb_cv2fc1 = 1.4
double cs_turb_cv2fc2 = 0.3
double cs_turb_cv2fct = 6.0
double cs_turb_cv2fcl = 0.25
double cs_turb_cv2fet = 110.0
double cs_turb_cnl1 = 0.8
double cs_turb_cnl2 = 11.
double cs_turb_cnl3 = 4.5
double cs_turb_cnl4 = 1e3
double cs_turb_cnl5 = 1.
double cs_turb_cwale = 0.25
double cs_turb_xiafm = 0.7
double cs_turb_etaafm = 0.4
double cs_turb_c1trit = 4.15
double cs_turb_c2trit = 0.55
double cs_turb_c3trit = 0.5
double cs_turb_c4trit = 0.
double cs_turb_cthafm = 0.236
double cs_turb_cthdfm = 0.31
double cs_turb_cthebdfm = 0.22
double cs_turb_xclt = 0.305
Base turbulence model data.
◆ cs_clip_turbulent_fluxes()
void cs_clip_turbulent_fluxes ( int  flux_id,
int  variance_id
[in]flux_idturbulent flux index
[in]variance_idscalar variance index
◆ cs_get_glob_turb_hybrid_model()
cs_turb_hybrid_model_t * cs_get_glob_turb_hybrid_model ( void  )
needed to initialize structure with GUI
◆ cs_get_glob_turb_les_model()
cs_turb_les_model_t * cs_get_glob_turb_les_model ( void  )
◆ cs_get_glob_turb_model()
cs_turb_model_t * cs_get_glob_turb_model ( void  )
◆ cs_get_glob_turb_rans_model()
cs_turb_rans_model_t * cs_get_glob_turb_rans_model ( void  )
◆ cs_get_glob_turb_ref_values()
cs_turb_ref_values_t * cs_get_glob_turb_ref_values ( void  )
◆ cs_set_glob_turb_model()
void cs_set_glob_turb_model ( void  )
This global pointer provides a read-only access to the structure.
◆ cs_turb_compute_constants()
void cs_turb_compute_constants ( int  phase_id)
[in]phase_idturbulent phase id (-1 for single phase flow)
◆ cs_turb_constants_log_setup()
void cs_turb_constants_log_setup ( void  )
◆ cs_turb_init_ref_quantities()
void cs_turb_init_ref_quantities ( void  )
◆ cs_turb_model_log_setup()
void cs_turb_model_log_setup ( void  )
◆ cs_turbulence_function_eps()
void cs_turbulence_function_eps ( int  location_id,
cs_lnum_t  n_elts,
const cs_lnum_t *  elt_ids,
void *  input,
void *  vals
Returned values are zero for turbulence models other than RANS.
This function matches the cs_eval_at_location_t function profile.
[in]location_idbase associated mesh location id
[in]n_eltsnumber of associated elements
[in]elt_idsids of associated elements, or nullptr if no filtering is required
[in,out]inputignored
[in,out]valspointer to output values (size: n_elts*dimension)
◆ cs_turbulence_function_k()
void cs_turbulence_function_k ( int  location_id,
cs_lnum_t  n_elts,
void *  input,
void *  vals
◆ cs_turbulence_function_rij()
void cs_turbulence_function_rij ( int  location_id,
cs_lnum_t  n_elts,
void *  input,
void *  vals
◆ cs_turbulence_init_models()
void cs_turbulence_init_models ( void  )
◆ cs_turbulence_model_name()
const char * cs_turbulence_model_name ( cs_turb_model_type_t  id)
[in]idmodel type
pointer to turbulence models description name.
◆ cs_turb_ales
Constant used to define, for each cell $\Omega_i$, the width of the (implicit) filter:
  • $\overline{\Delta}=xlesfl(ales*|\Omega_i|)^{bles}$
Useful if and only if model = 40 or 41.
◆ cs_turb_apow
Werner and Wengle coefficient
◆ cs_turb_bles
Constant used to define, for each cell $Omega_i$, the width of the (implicit) filter:
◆ cs_turb_bpow
◆ cs_turb_c1trit
Coefficient of turbulent DFM flow model.
◆ cs_turb_c2trit
◆ cs_turb_c3trit
◆ cs_turb_c4trit
◆ cs_turb_ccaza
Constants of the Cazalbou rotation/curvature correction.
◆ cs_turb_ccazb
◆ cs_turb_ccazc
◆ cs_turb_ccazd
◆ cs_turb_ccaze2
◆ cs_turb_ccazsc
◆ cs_turb_cddes
Constant $ C_{DDES} $ for the $k-\omega$ SST model. Useful if and only if model=60 ( $k-\omega$ SST) and hybrid_turb=CS_HYBRID_DES.
◆ cs_turb_cdries
Van Driest constant appearing in the van Driest damping function applied to the Smagorinsky constant:
  • $ (1-\exp^{(-y^+/cdries}) $.
◆ cs_turb_ce1
Constant $C_{\varepsilon 1}$ for all the RANS turbulence models except for the v2f and the $k-\omega$ models. Useful if and only if model= 20, 21, 30 or 31 ( $k-\varepsilon$ or $R_{ij}-\varepsilon$).
◆ cs_turb_ce2
Constant $C_{\varepsilon 2}$ for the $k-\varepsilon$ and $R_{ij}-\varepsilon$ models. Default value for ( $k-\varepsilon$ or $R_{ij}-\varepsilon$ LRR) is 1.92, modified otherwise. for $R_{ij}-\varepsilon$ SSG or EBRSM: 1.83 for the v2f $\varphi$-model: 1.85
◆ cs_turb_ce3
Constant $C_{\varepsilon 3}$ for the $k-\varepsilon$ and for $R_{ij}-\varepsilon$ models. Equal to cs_turb_ce1 by default, to 2.02 for EBRSM
◆ cs_turb_ce4
Coefficient of interfacial coefficient in k-eps, used in Lagrange treatment.
Constant $C_{\varepsilon 4}$ for the interfacial term (Lagrangian module) in case of two-way coupling. Useful in case of Lagrangian modelling, in $k-\varepsilon$ and $R_{ij}-\varepsilon$ with two-way coupling.
◆ cs_turb_cebmmu
Constant of the Rij-epsilon EBRSM.
◆ cs_turb_cebmr1
◆ cs_turb_cebmr2
◆ cs_turb_cebmr3
◆ cs_turb_cebmr4
◆ cs_turb_cebmr5
◆ cs_turb_cebms1
◆ cs_turb_cebms2
◆ cs_turb_chtles_bt0
Constant $ \beta_0 $ for the HTLES model. Useful if and only if model=60 ( $k-\omega$ SST) or if model=51 ( $BL-v^2-k$) and hybrid_turb=CS_HYBRID_HTLES.
◆ cs_turb_ckwa1
Specific constant of k-omega SST. Constant $a_1$ for the $k-\omega$ SST model. Useful if and only if model=60 ( $k-\omega$ SST).
◆ cs_turb_ckwbt1
Constant $\beta_1$ for the $k-\omega$ SST model. Useful if and only if model=60 ( $k-\omega$ SST).
◆ cs_turb_ckwbt2
Constant $\beta_2$ for the $k-\omega$ SST model. Useful if and only if model=60 ( $k-\omega$ SST).
◆ cs_turb_ckwc1
Constant $ c_1 $ for the $k-\omega$ SST model. Useful if and only if model=60 ( $k-\omega$ SST). Specific constant of k-omega SST.
◆ cs_turb_ckwgm1
$\frac{\beta_1}{C_\mu}-\frac{\kappa^2}{\sqrt{C_\mu}\sigma_{\omega 1}}$. Constant $\gamma_1$ for the $k-\omega$ SST model. Useful if and only if model=60 ( $k-\omega$ SST).
Warning
: $\gamma_1$ is calculated before the call to cs_user_parameters. Hence, if $\beta_1$, $C_\mu$, $\kappa$ or $\sigma_{\omega 1}$ is modified in cs_user_parameters, cs_turb_ckwgm1 must also be modified in accordance.
◆ cs_turb_ckwgm2
$\frac{\beta_2}{C_\mu}-\frac{\kappa^2}{\sqrt{C_\mu}\sigma_{\omega 2}}$. Constant $\gamma_2$ for the $k-\omega$ SST model. Useful if and only if model=60 ( $k-\omega$ SST).
Warning
: $\gamma_2$ is calculated before the call to cs_user_parameters. Hence, if $\beta_2$, $C_\mu$, $\kappa$ or $\sigma_{\omega 2}$ is modified in cs_user_parameters, cs_turb_ckwgm2 must also be modified in accordance.
◆ cs_turb_ckwsk1
Constant $\sigma_{k1}$ for the $k-\omega$ SST model. Useful if and only if model=60.
◆ cs_turb_ckwsk2
Constant $\sigma_{k2}$ for the $k-\omega$ SST model. Useful if and only if model=60.
◆ cs_turb_ckwsw1
Constant $\sigma_{\omega 1}$ for the $k-\omega$ SST model. Useful if and only if model=60 ( $k-\omega$ SST).
◆ cs_turb_ckwsw2
Constant $\sigma_{\omega 2}$ for the $k-\omega$ SST model. Useful if and only if model=60 ( $k-\omega$ SST).
◆ cs_turb_cmu
Constant $C_\mu$ for all the RANS turbulence models. Warning: different value for v2f models. Useful only for RANS models ( $k-\varepsilon$, $R_{ij}-\varepsilon$ or $k-\omega$).
◆ cs_turb_cnl1
Constants for the Baglietto et al. quadratic k-epsilon model. Useful if and only if model = CS_TURB_K_EPSILON_QUAD
◆ cs_turb_cnl2
◆ cs_turb_cnl3
◆ cs_turb_cnl4
◆ cs_turb_cnl5
◆ cs_turb_cpalc1
Specific constant of v2f "BL-v2k" (or phi-alpha).
◆ cs_turb_cpalc2
◆ cs_turb_cpalcl
◆ cs_turb_cpalct
◆ cs_turb_cpale3
◆ cs_turb_cpale4
◆ cs_turb_cpalet
◆ cs_turb_crij1
Constant $C_1$ for the $R_{ij}-\varepsilon$ LRR model. Useful if and only if model=30 ( $R_{ij}-\varepsilon$ LRR).
◆ cs_turb_crij2
Constant $C_2$ for the $R_{ij}-\varepsilon$ LRR model. Useful if and only if model=30 ( $R_{ij}-\varepsilon$ LRR).
◆ cs_turb_crij3
Constant $C_3$ for the $R_{ij}-\varepsilon$ models. Value is 0.55 for SSG and LRR, 0.6 for EBRSM.
◆ cs_turb_crij_c0
Rotta constant $C_0$ for the $R_{ij}-\varepsilon$ model. Useful for the Lagrangian model. The value is set from $C_1$ if and only if model=CS_TURB_RIJ_EPSILON_LRR ( $R_{ij}-\varepsilon$ LRR) and $C_2=0$.
◆ cs_turb_crij_ct
Monin constant $C_T$ for the $DFM$ model on temperature. Useful for the Lagrangian model.
◆ cs_turb_crij_eps
Coefficient of in front of dissipation term in Rij models Default value is 1, can be used to unplung dissipation source term.
◆ cs_turb_crijp1
Constant $C_1^\prime$ for the $R_{ij}-\varepsilon$ LRR model, corresponding to the wall echo terms. Useful if and only if model=30 and cs_turb_rans_model_t::irijec=1 ( $R_{ij}-\varepsilon$ LRR).
◆ cs_turb_crijp2
Constant $C_2^\prime$ for the $R_{ij}-\varepsilon$ LRR model, corresponding to the wall echo terms. Useful if and only if model=30 and cs_turb_rans_model_t::irijec=1 ( $R_{ij}-\varepsilon$ LRR).
◆ cs_turb_csab1
Specific constant of Spalart-Allmaras.
◆ cs_turb_csab2
◆ cs_turb_csas
Constant $ C_{SAS}$ for the hybrid $k-\omega$ SST model. Useful if and only if model=60 ( $k-\omega$ SST) and hybrid_turb=CS_HYBRID_SAS.
◆ cs_turb_csas_eta2
constant $ C_{DDES}$ for the hybrid $k-\omega$ SST model. Useful if and only if model=60 ( $k-\omega$ SST) and hybrid_turb=CS_HYBRID_SAS.
◆ cs_turb_csasig
◆ cs_turb_csav1
◆ cs_turb_csaw1
◆ cs_turb_csaw2
◆ cs_turb_csaw3
◆ cs_turb_csmago
Smagorinsky constant used in the Smagorinsky model for LES. The sub-grid scale viscosity is calculated by $\displaystyle\mu_{sg}=
\rho C_{smago}^2\bar{\Delta}^2\sqrt{2\bar{S}_{ij}\bar{S}_{ij}}$ where $\bar{\Delta}$ is the width of the filter and $\bar{S}_{ij}$ the filtered strain rate.
Useful if and only if model = 40.
Note
In theory Smagorinsky constant is 0.18. For a channel, 0.065 value is rather taken.
◆ cs_turb_csmago_max
Maximum allowed value for the variable $C$ appearing in the LES dynamic model. Any larger value yielded by the calculation procedure of the dynamic model will be clipped to $ smagmx$.
Useful if and only if model = 41.
◆ cs_turb_csmago_min
Minimum allowed value for the variable $C$ appearing in the LES dynamic model. Any smaller value yielded by the calculation procedure of the dynamic model will be clipped to $ smagmn$.
◆ cs_turb_csrij
Constant $C_s$ for the $R_{ij}-\varepsilon$ LRR model. Useful if and only if model=30 ( $R_{ij}-\varepsilon$ LRR).
◆ cs_turb_cssgr1
Constant $C_{r1}$ for the $R_{ij}-\varepsilon$ SSG model. Useful if and only if model=31 ( $R_{ij}-\varepsilon$ SSG).
◆ cs_turb_cssgr2
Constant $C_{r2}$ for the $R_{ij}-\varepsilon$ SSG model. Useful if and only if model=31 ( $R_{ij}-\varepsilon$ SSG).
◆ cs_turb_cssgr3
Constant $C_{r3}$ for the $R_{ij}-\varepsilon$ SSG model. Useful if and only if model=31 ( $R_{ij}-\varepsilon$ SSG).
◆ cs_turb_cssgr4
constant $C_{r4}$ for the $R_{ij}-\varepsilon$ SSG model. Useful if and only if model=31 ( $R_{ij}-\varepsilon$ SSG).
◆ cs_turb_cssgr5
◆ cs_turb_cssgs1
Constant $C_{s1}$ for the $R_{ij}-\varepsilon$ SSG model. Useful if and only if model=31 ( $R_{ij}-\varepsilon$ SSG).
◆ cs_turb_cssgs2
Constant $C_{s2}$ for the $R_{ij}-\varepsilon$ SSG model. Useful if and only if model=31 ( $R_{ij}-\varepsilon$ SSG).
◆ cs_turb_cssr1
Constant of the Spalart-Shur rotation/curvature correction.
◆ cs_turb_cssr2
◆ cs_turb_cssr3
◆ cs_turb_cstlog
Constant of logarithmic smooth law function: $ \dfrac{1}{\kappa} \ln(y^+) + cstlog $ ( $ cstlog = 5.2 $).
Constant of the logarithmic wall function. Useful if and only if model != CS_TURB_NONE (mixing length, $k-\varepsilon$, $R_{ij}-\varepsilon$, LES, v2f or $k-\omega$).
◆ cs_turb_cstlog_alpha
Constant $ \alpha $ for logarithmic law function switching from rough to smooth: $ \dfrac{1}{\kappa} \ln(y u_k/(\nu + \alpha \xi u_k)) + cstlog $ ( $ \alpha = \exp \left( -\kappa (8.5 - 5.2) \right) $).
◆ cs_turb_cstlog_rough
Constant of logarithmic rough law function: $ \dfrac{1}{\kappa} \ln(y/\xi) + cstlog_{rough} $ ( $ cstlog_{rough} = 8.5 $).
◆ cs_turb_cthafm
Constant of GGDH and AFM on the thermal scalar.
◆ cs_turb_cthdfm
◆ cs_turb_cthebdfm
◆ cs_turb_cv2fa1
Constant $a_1$ for the v2f $\varphi$-model. Useful if and only if model=50 (v2f $\varphi$-model).
◆ cs_turb_cv2fc1
Constant $C_1$ for the v2f $\varphi$-model. Useful if and only if model=50 (v2f $\varphi$-model).
◆ cs_turb_cv2fc2
Constant $C_2$ for the v2f $\varphi$-model. Useful if and only if model=50 (v2f $\varphi$-model).
◆ cs_turb_cv2fcl
Constant $C_L$ for the v2f $\varphi$-model. Useful if and only if model=50 (v2f $\varphi$-model).
◆ cs_turb_cv2fct
Constant $C_T$ for the v2f $\varphi$-model. Useful if and only if model=50 (v2f $\varphi$-model).
◆ cs_turb_cv2fet
Constant $C_\eta$ for the v2f $\varphi$-model. Useful if and only if model=50 (v2f $\varphi$-model).
◆ cs_turb_cwale
Constant of the WALE LES method.
◆ cs_turb_dpow
◆ cs_turb_etaafm
Coefficient of turbulent AFM flow model.
◆ cs_turb_vdriest
Van Driest constant. (= 25.6)
Useful if and only if cs_glob_wall_functions::iwallf = CS_WALL_F_2SCALES_VDRIEST. (Two scales log law at the wall using Van Driest mixing length expression).
◆ cs_turb_xa1
Constant in the expression of Ce1' for the Rij-epsilon EBRSM.
◆ cs_turb_xceta
◆ cs_turb_xcl
◆ cs_turb_xclt
constant of EB-AFM and EB-DFM (0.122*2.5, See F. Dehoux thesis)
◆ cs_turb_xct
◆ cs_turb_xiafm
◆ cs_turb_xkappa
Karman constant. (= 0.42)
Useful if and only if model != CS_TURB_NONE. (mixing length, $k-\varepsilon$, $R_{ij}-\varepsilon$, LES, v2f or $k-\omega$).
◆ cs_turb_xlesfd
Ratio between explicit and explicit filter width for a dynamic model. Constant used to define, for each cell $\Omega_i$, the width of the explicit filter used in the framework of the LES dynamic model: $\widetilde{\overline{\Delta}}=xlesfd\overline{\Delta}$.
◆ cs_turb_xlesfl
Constant used in the definition of LES filtering diameter: $ \delta = \text{xlesfl} . (\text{ales} . volume)^{\text{bles}}$ cs_turb_xlesfl is a constant used to define, for each cell $\Omega_i$, the width of the (implicit) filter: $\overline{\Delta}=xlesfl(ales*|\Omega_i|)^{bles}$
