1#ifndef CS_SOLIDIFICATION_H
2#define CS_SOLIDIFICATION_H
90#define CS_SOLIDIFICATION_POST_CELL_STATE (1 << 0)
91#define CS_SOLIDIFICATION_POST_ENTHALPY (1 << 1)
92#define CS_SOLIDIFICATION_POST_CBULK_ADIM (1 << 2)
93#define CS_SOLIDIFICATION_POST_CLIQ (1 << 3)
94#define CS_SOLIDIFICATION_POST_LIQUIDUS_TEMPERATURE (1 << 4)
95#define CS_SOLIDIFICATION_POST_SEGREGATION_INDEX (1 << 5)
96#define CS_SOLIDIFICATION_POST_SOLIDIFICATION_RATE (1 << 6)
97#define CS_SOLIDIFICATION_POST_ADVANCED_ANALYSIS (1 << 7)
142#define CS_SOLIDIFICATION_USE_ENTHALPY_VARIABLE (1 << 0)
143#define CS_SOLIDIFICATION_NO_VELOCITY_FIELD (1 << 1)
144#define CS_SOLIDIFICATION_SKIP_RHO_CHECK (1 << 2)
145#define CS_SOLIDIFICATION_WITH_SOLUTE_SOURCE_TERM (1 << 3)
146#define CS_SOLIDIFICATION_USE_EXTRAPOLATION (1 << 4)
147#define CS_SOLIDIFICATION_WITH_PENALIZED_EUTECTIC (1 << 5)
166#define CS_SOLIDIFICATION_BINARY_ALLOY_M_FUNC (1 << 7)
167#define CS_SOLIDIFICATION_BINARY_ALLOY_C_FUNC (1 << 8)
168#define CS_SOLIDIFICATION_BINARY_ALLOY_G_FUNC (1 << 9)
169#define CS_SOLIDIFICATION_BINARY_ALLOY_T_FUNC (1 <<10)
1005 bool &is_last_iter);
Definition: cs_field.h:275
time step descriptor
Definition: cs_time_step.h:60
Definition: cs_defs.h:332
unsigned cs_gnum_t
global mesh entity number
Definition: cs_defs.h:317
Definition: cs_defs.h:325
unsigned short int cs_flag_t
Definition: cs_defs.h:334
cs_flag_t cs_navsto_param_post_flag_t
Definition: cs_navsto_param.h:56
cs_navsto_param_coupling_t
Definition: cs_navsto_param.h:237
cs_navsto_param_model_t
Describe the system of equations related to the Navier-Stokes to be solved.
Definition: cs_navsto_param.h:80
cs_flag_t cs_navsto_param_model_flag_t
Definition: cs_navsto_param.h:55
cs_param_nl_algo_t
Class of non-linear iterative algorithm.
Definition: cs_param_types.h:715
cs_solidification_binary_alloy_t * cs_solidification_get_binary_alloy_struct(void)
Get the structure defining the binary alloy model.
Definition: cs_solidification.cpp:3841
cs_solidification_voller_t * cs_solidification_check_voller_model(void)
Sanity checks on the consistency of the Voller's model settings.
Definition: cs_solidification.cpp:3737
void cs_solidification_set_strategy(cs_solidification_strategy_t strategy)
Set the strategy to update quantitiess (liquid fraction and the thermal source term for the two main ...
Definition: cs_solidification.cpp:4059
cs_solidification_binary_alloy_t * cs_solidification_check_binary_alloy_model(void)
Sanity checks on the consistency of the settings of the binary alloy model.
Definition: cs_solidification.cpp:3871
void() cs_solidification_func_t(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *ts)
Function pointer associated to a solidification model aiming at updating/initializing the solidificat...
Definition: cs_solidification.h:278
void cs_solidification_extra_op(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *ts)
Predefined extra-operations for the solidification module.
Definition: cs_solidification.cpp:5162
void cs_solidification_init_values(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step)
Set an initial values for all quantities related to this module This is done after the setup step.
Definition: cs_solidification.cpp:4886
cs_solidification_stefan_t * cs_solidification_check_stefan_model(void)
Sanity checks on the consistency of the Stefan's model settings.
Definition: cs_solidification.cpp:3660
cs_solidification_t * cs_solidification_get_structure(void)
Retrieve the main structure to deal with solidification process.
Definition: cs_solidification.cpp:3211
cs_solidification_model_t
Type of physical model used to simulate the solidifcation/fusion process.
Definition: cs_solidification.h:206
@ CS_SOLIDIFICATION_MODEL_BINARY_ALLOY
Definition: cs_solidification.h:211
@ CS_SOLIDIFICATION_MODEL_VOLLER_NL
Definition: cs_solidification.h:210
@ CS_SOLIDIFICATION_MODEL_VOLLER_PRAKASH_87
Definition: cs_solidification.h:209
@ CS_SOLIDIFICATION_N_MODELS
Definition: cs_solidification.h:213
@ CS_SOLIDIFICATION_MODEL_STEFAN
Definition: cs_solidification.h:208
void cs_solidification_init_setup(void)
Setup equations/properties related to the solidification module.
Definition: cs_solidification.cpp:4314
cs_solidification_t * cs_solidification_destroy_all(void)
Free the main structure related to the solidification module.
Definition: cs_solidification.cpp:4219
Kind of strategy to use to model the segregation/solidification process. This implies a setting of fu...
Definition: cs_solidification.h:254
@ CS_SOLIDIFICATION_STRATEGY_LEGACY
Definition: cs_solidification.h:256
@ CS_SOLIDIFICATION_STRATEGY_TAYLOR
Definition: cs_solidification.h:257
@ CS_SOLIDIFICATION_STRATEGY_PATH
Definition: cs_solidification.h:258
@ CS_SOLIDIFICATION_N_STRATEGIES
Definition: cs_solidification.h:260
void cs_solidification_compute(const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step, bool &is_last_iter)
Solve equations related to the solidification module.
Definition: cs_solidification.cpp:5102
void cs_solidification_set_binary_alloy_model(const char *name, const char *varname, cs_real_t beta_t, cs_real_t temp0, cs_real_t beta_c, cs_real_t conc0, cs_real_t kp, cs_real_t mliq, cs_real_t t_eutec, cs_real_t t_melt, cs_real_t solute_diff, cs_real_t latent_heat)
Set the main physical parameters which describe a solidification process with a binary alloy (with co...
Definition: cs_solidification.cpp:3930
void cs_solidification_finalize_setup(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant)
Finalize the setup stage for equations related to the solidification module.
Definition: cs_solidification.cpp:4475
void cs_solidification_set_verbosity(int verbosity)
Set the level of verbosity for the solidification module.
Definition: cs_solidification.cpp:3225
cs_solidification_t * cs_solidification_activate(cs_solidification_model_t model, cs_flag_t options, cs_flag_t post_flag, const cs_boundary_t *boundaries, cs_navsto_param_model_t ns_model, cs_navsto_param_model_flag_t ns_model_flag, cs_navsto_param_coupling_t algo_coupling, cs_navsto_param_post_flag_t ns_post_flag)
Activate the solidification module.
Definition: cs_solidification.cpp:3269
void cs_solidification_extra_post(void *input, int mesh_id, int cat_id, int ent_flag[5], cs_lnum_t n_cells, cs_lnum_t n_i_faces, cs_lnum_t n_b_faces, const cs_lnum_t cell_ids[], const cs_lnum_t i_face_ids[], const cs_lnum_t b_face_ids[], const cs_time_step_t *time_step)
Predefined post-processing output for the solidification module. Prototype of this function is fixed ...
Definition: cs_solidification.cpp:5339
cs_solidification_state_t
Kind of state in which a cell or an entity is.
Definition: cs_solidification.h:236
@ CS_SOLIDIFICATION_STATE_SOLID
Definition: cs_solidification.h:238
@ CS_SOLIDIFICATION_N_STATES
Definition: cs_solidification.h:243
@ CS_SOLIDIFICATION_STATE_LIQUID
Definition: cs_solidification.h:240
@ CS_SOLIDIFICATION_STATE_MUSHY
Definition: cs_solidification.h:239
@ CS_SOLIDIFICATION_STATE_EUTECTIC
Definition: cs_solidification.h:241
cs_solidification_voller_t * cs_solidification_get_voller_struct(void)
Get the structure defining the Voller model.
Definition: cs_solidification.cpp:3707
bool cs_solidification_is_activated(void)
Test if solidification module is activated.
Definition: cs_solidification.cpp:3194
void cs_solidification_set_stefan_model(cs_real_t t_change, cs_real_t latent_heat)
Set the main physical parameters which describe the Stefan model.
Definition: cs_solidification.cpp:3686
void cs_solidification_log_setup(void)
Summarize the solidification module in the log file dedicated to the setup.
Definition: cs_solidification.cpp:4670
void cs_solidification_set_kozeny_carman_parameters(double kozeny_constant, double tortuosity, double s_das)
Set the parameters involved in the computation of the permeability coefficient of the Kozeny-Carman r...
Definition: cs_solidification.cpp:3591
void cs_solidification_set_voller_model_no_velocity(cs_real_t t_solidus, cs_real_t t_liquidus, cs_real_t latent_heat)
Set the main physical parameters which describe the Voller and Prakash modelling.
Definition: cs_solidification.cpp:3812
cs_solidification_stefan_t * cs_solidification_get_stefan_struct(void)
Get the structure defining the Stefan model.
Definition: cs_solidification.cpp:3631
void cs_solidification_set_segr_functions(cs_solidification_func_t *vel_forcing, cs_solidification_func_t *cliq_update, cs_solidification_func_t *gliq_update, cs_solidification_func_t *thm_st_update)
Set the functions to perform the update of physical properties and/or the computation of the thermal ...
Definition: cs_solidification.cpp:4174
void cs_solidification_set_forcing_eps(cs_real_t forcing_eps)
Set the value of the epsilon parameter used in the forcing term of the momentum equation.
Definition: cs_solidification.cpp:3245
void cs_solidification_set_voller_model(cs_real_t beta, cs_real_t t_ref, cs_real_t t_solidus, cs_real_t t_liquidus, cs_real_t latent_heat)
Definition: cs_solidification.cpp:3773
Definition: cs_time_plot.h:44
Structure storing information related to the "physical" boundaries associated with the computational ...
Definition: cs_boundary.h:154
Definition: cs_cdo_connect.h:57
Definition: cs_cdo_quantities.h:142
Definition: cs_iter_algo.h:285
Definition: cs_solidification.h:374
cs_real_t * c_l_faces
Definition: cs_solidification.h:476
cs_real_t t_eut_inf
Definition: cs_solidification.h:402
cs_solidification_func_t * update_clc
Definition: cs_solidification.h:432
cs_real_t ml
Definition: cs_solidification.h:392
cs_real_t kp
Definition: cs_solidification.h:389
cs_real_t * eta_coef_array
Definition: cs_solidification.h:495
const cs_real_t * temp_faces
Definition: cs_solidification.h:480
cs_real_t inv_ml
Definition: cs_solidification.h:393
cs_field_t * c_bulk
Definition: cs_solidification.h:485
cs_real_t * c_l_cells
Definition: cs_solidification.h:475
cs_solidification_func_t * update_velocity_forcing
Definition: cs_solidification.h:428
cs_solidification_func_t * update_thm_st
Definition: cs_solidification.h:424
cs_equation_t * solute_equation
Definition: cs_solidification.h:484
cs_real_t * t_liquidus
Definition: cs_solidification.h:502
cs_real_t t_melt
Definition: cs_solidification.h:397
cs_real_t * cliq_minus_cbulk
Definition: cs_solidification.h:507
cs_real_t dgldC_eut
Definition: cs_solidification.h:407
cs_real_t * tk_bulk
Definition: cs_solidification.h:466
double gliq_relax
Definition: cs_solidification.h:452
cs_real_t inv_kpm1
Definition: cs_solidification.h:391
cs_real_t inv_kp
Definition: cs_solidification.h:390
cs_real_t t_eut
Definition: cs_solidification.h:401
cs_real_t cs1
Definition: cs_solidification.h:406
cs_real_t t_eut_sup
Definition: cs_solidification.h:403
cs_real_t * tx_bulk
Definition: cs_solidification.h:468
cs_property_t * diff_pty
Definition: cs_solidification.h:491
double delta_tolerance
Definition: cs_solidification.h:450
cs_real_t diff_coef
Definition: cs_solidification.h:490
cs_real_t * tbulk_minus_tliq
Definition: cs_solidification.h:506
int n_iter_max
Definition: cs_solidification.h:449
cs_real_t ref_concentration
Definition: cs_solidification.h:382
cs_real_t * ck_bulk
Definition: cs_solidification.h:467
int iter
Definition: cs_solidification.h:448
cs_real_t c_eut
Definition: cs_solidification.h:405
cs_real_t * diff_pty_array
Definition: cs_solidification.h:492
cs_solidification_func_t * update_gl
Definition: cs_solidification.h:420
cs_real_t * cx_bulk
Definition: cs_solidification.h:469
cs_property_t * eta_coef_pty
Definition: cs_solidification.h:494
double eta_relax
Definition: cs_solidification.h:451
Definition: cs_solidification.h:294
Definition: cs_solidification.h:315
int n_iter_max
Definition: cs_solidification.h:320
Definition: cs_solidification.h:311
cs_real_t t_change
Definition: cs_solidification.h:304
double max_delta_h
Definition: cs_solidification.h:321
Definition: cs_solidification.h:515
cs_property_t * mass_density
Definition: cs_solidification.h:529
Definition: cs_solidification.h:598
int verbosity
Definition: cs_solidification.h:522
double forcing_coef
Definition: cs_solidification.h:635
cs_property_t * g_l
Definition: cs_solidification.h:554
cs_flag_t options
Definition: cs_solidification.h:518
cs_time_plot_t * plot_state
Definition: cs_solidification.h:562
cs_field_t * g_l_field
Definition: cs_solidification.h:552
cs_field_t * enthalpy
Definition: cs_solidification.h:581
cs_property_t * viscosity
Definition: cs_solidification.h:540
cs_real_t * forcing_mom_array
Definition: cs_solidification.h:605
Definition: cs_solidification.h:546
cs_real_t * thermal_source_term_array
Definition: cs_solidification.h:588
cs_flag_t post_flag
Definition: cs_solidification.h:520
cs_field_t * temperature
Definition: cs_solidification.h:576
cs_thermal_system_t * thermal_sys
Definition: cs_solidification.h:572
cs_solidification_state_t * cell_state
Definition: cs_solidification.h:558
cs_flag_t model
Definition: cs_solidification.h:517
Definition: cs_solidification.h:633
double s_das
Definition: cs_solidification.h:632
cs_real_t * thermal_reaction_coef_array
Definition: cs_solidification.h:587
double tortuosity
Definition: cs_solidification.h:634
cs_property_t * forcing_mom
Definition: cs_solidification.h:607
cs_property_t * thermal_reaction_coef
Definition: cs_solidification.h:586
cs_lnum_t first_cell
Definition: cs_solidification.h:640
cs_property_t * cp
Definition: cs_solidification.h:534
void * model_context
Definition: cs_solidification.h:592
Definition: cs_solidification.h:337
Definition: cs_solidification.h:359
cs_iter_algo_t * nl_algo
Definition: cs_solidification.h:365
cs_real_t t_solidus
Definition: cs_solidification.h:347
Definition: cs_solidification.h:355
Definition: cs_solidification.h:348
cs_param_nl_algo_t nl_algo_type
Definition: cs_solidification.h:364
Definition: cs_thermal_system.h:135
