326extern "C" const char *
339extern "C" const char *
Definition: cs_defs.h:332
cs_log_t
Definition: cs_log.h:44
Definition: cs_matrix.h:108
cs_sles_pc_state_t() cs_sles_pc_apply_t(void *context, const cs_real_t *x_in, cs_real_t *x_out)
Function pointer for application of a preconditioner.
Definition: cs_sles_pc.h:144
cs_sles_pc_t * cs_sles_pc_jacobi_create(void)
Create a Jacobi preconditioner.
Definition: cs_sles_pc.cpp:1064
void() cs_sles_pc_free_t(void *context)
Function pointer for freeing of a preconditioner's context data.
Definition: cs_sles_pc.h:162
const char * cs_sles_pc_get_type_name(cs_sles_pc_t *pc)
Return type name of preconditioner context.
Definition: cs_sles_pc.cpp:839
void() cs_sles_pc_tolerance_t(void *context, double precision, double r_norm)
Function pointer for setting of the required tolerance for preconditioners involving an iterative sol...
Definition: cs_sles_pc.h:123
cs_sles_pc_state_t
Definition: cs_sles_pc.h:52
@ CS_SLES_PC_MAX_ITERATION
Definition: cs_sles_pc.h:57
@ CS_SLES_PC_CONVERGED
Definition: cs_sles_pc.h:59
@ CS_SLES_PC_DIVERGED
Definition: cs_sles_pc.h:54
@ CS_SLES_PC_BREAKDOWN
Definition: cs_sles_pc.h:55
Definition: cs_sles_pc.h:65
cs_sles_pc_t * cs_sles_pc_poly_2_create(void)
Create a Polynomial preconditioner of degree 2.
Definition: cs_sles_pc.cpp:1120
void cs_sles_pc_setup(cs_sles_pc_t *pc, const char *name, const cs_matrix_t *a, bool accel, int verbosity)
Setup sparse linear equation preconditioner.
Definition: cs_sles_pc.cpp:944
cs_sles_pc_t * cs_sles_pc_none_create(void)
Create an "identity" (or null) preconditioner.
Definition: cs_sles_pc.cpp:1036
void() cs_sles_pc_destroy_t(void **context)
Definition: cs_sles_pc.h:211
const char * cs_sles_pc_get_type(cs_sles_pc_t *pc)
Definition: cs_sles_pc.cpp:818
void cs_sles_pc_log(cs_sles_pc_t *pc, cs_log_t log_type)
Log preconditioner setup, history and performance data.
Definition: cs_sles_pc.cpp:1020
const char *() cs_sles_pc_get_type_t(const void *context, bool logging)
Function pointer returning the type name of a preconditioner context.
Definition: cs_sles_pc.h:83
void *() cs_sles_pc_clone_t(const void *context)
Function pointer for creation of a preconditioner context based on the copy of another.
Definition: cs_sles_pc.h:199
cs_sles_pc_apply_t * cs_sles_pc_get_apply_func(const cs_sles_pc_t *pc)
Return a pointer to the function used to apply a preconditioner.
Definition: cs_sles_pc.cpp:887
cs_sles_pc_t * cs_sles_pc_define(void *context, cs_sles_pc_get_type_t *get_type_func, cs_sles_pc_setup_t *setup_func, cs_sles_pc_tolerance_t *tolerance_func, cs_sles_pc_apply_t *apply_func, cs_sles_pc_free_t *free_func, cs_sles_pc_log_t *log_func, cs_sles_pc_clone_t *clone_func, cs_sles_pc_destroy_t *destroy_func)
Define sparse linear equation preconditioner.
Definition: cs_sles_pc.cpp:712
cs_sles_pc_t * cs_sles_pc_clone(const cs_sles_pc_t *src)
Create a new preconditioner context based on the copy of another.
Definition: cs_sles_pc.cpp:778
cs_sles_pc_state_t cs_sles_pc_apply(cs_sles_pc_t *pc, cs_real_t *x_in, cs_real_t *x_out)
Apply a preconditioner.
Definition: cs_sles_pc.cpp:976
cs_sles_pc_t * cs_sles_pc_poly_1_create(void)
Create a Polynomial preconditioner of degree 1.
Definition: cs_sles_pc.cpp:1092
void cs_sles_pc_free(cs_sles_pc_t *pc)
Free preconditioner setup.
Definition: cs_sles_pc.cpp:997
void * cs_sles_pc_get_context(cs_sles_pc_t *pc)
Return pointer to preconditioner context structure pointer.
Definition: cs_sles_pc.cpp:864
void() cs_sles_pc_log_t(const void *context, cs_log_t log_type)
Function pointer for logging of preconditioner history and performance data.
Definition: cs_sles_pc.h:177
void() cs_sles_pc_setup_t(void *context, const char *name, const cs_matrix_t *a, bool accel, int verbosity)
Function pointer for pre-resolution setup of a preconditioner context.
Definition: cs_sles_pc.h:100
void cs_sles_pc_set_tolerance(cs_sles_pc_t *pc, double precision, double r_norm)
Set the required tolerance for preconditioners involving an iterative solver.
Definition: cs_sles_pc.cpp:913
const cs_real_t * cs_sles_pc_get_ad_inv(void *context)
Definition: cs_sles_pc.cpp:1154
void cs_sles_pc_destroy(cs_sles_pc_t **pc)
Destroy a sparse linear equation preconditioner.
Definition: cs_sles_pc.cpp:750
