cs_lagr_coupling.cpp File Reference
#include <limits.h>
#include <stddef.h>
#include <ctype.h>
#include <float.h>
#include "bft/bft_error.h"
#include "base/cs_array.h"
#include "base/cs_base.h"
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "mesh/cs_mesh.h"
#include "lagr/cs_lagr.h"
#include "lagr/cs_lagr_particle.h"
#include "lagr/cs_lagr_coupling.h"
+ Include dependency graph for cs_lagr_coupling.cpp:
void cs_lagr_coupling_initialize (void)
 Prepare source terms for Lagrangian 2-way coupling. More...
void cs_lagr_coupling_increment_part_contrib (cs_lagr_particle_set_t &p_set, const cs_lnum_t p_id, const cs_real_t dt_part, const bool rebound, const cs_real_t taup, const cs_real_3_t force_p, const cs_real_2_t tempct)
 Increment the source terms for Lagrangian 2-way coupling with quantities attached to a given particle. More...
void cs_lagr_coupling_finalize (void)
 Finalize source terms for Lagrangian 2-way coupling by treating cell-attached properties. More...
◆ cs_lagr_coupling_finalize()
void cs_lagr_coupling_finalize ( void  )
◆ cs_lagr_coupling_increment_part_contrib()
void cs_lagr_coupling_increment_part_contrib ( cs_lagr_particle_set_t &  p_set,
const bool  rebound,
Increment the source terms for Lagrangian 2-way coupling with quantites attached to a given particle.
Remarks
Source terms are computed for the starting cell of a particle during a given iteration. Even if particle exits the domain, it s necessary to compute a source term matching the exchange between the carrier fluid and the particle at the beginning of the time step. If nor == 2 and the particle interacts with a boundary, then the source terms are computed as if nor == 1.
[in]p_setparticle set
[in]p_idparticle id
[in]dt_partremaining time step associated to the particle
[in]reboundtrue if a rebound occured over last trajectory step
[in]taupdynamic characteristic time
[in]force_pforces per mass unit on particles (m/s^2)
[in]tempctthermal characteristic time
◆ cs_lagr_coupling_initialize()
void cs_lagr_coupling_initialize ( void  )
