55typedef struct _cs_hho_stokes_t cs_hho_stokes_t;
Definition: cs_field.h:275
time step descriptor
Definition: cs_time_step.h:60
Definition: cs_defs.h:332
unsigned short int cs_flag_t
Definition: cs_defs.h:334
double * cs_hho_stokes_get_face_values(const void *data)
Get the computed values at faces (DoF used in the linear system are located at primal faces)
Definition: cs_hho_stokes.cpp:742
void cs_hho_stokes_update_field(const cs_real_t *solu, const cs_real_t *rhs, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data, cs_real_t *field_val)
Store solution(s) of the linear system into a field structure Update extra-field values required for ...
Definition: cs_hho_stokes.cpp:701
void cs_hho_stokes_initialize_system(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data, cs_matrix_t **system_matrix, cs_real_t **system_rhs)
Create the matrix of the current algebraic system. Allocate and initialize the right-hand side associ...
void * cs_hho_stokes_free_context(void *data)
Destroy a cs_hho_stokes_t structure.
Definition: cs_hho_stokes.cpp:575
void cs_hho_stokes_compute_source(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data)
Compute the contributions of source terms (store inside builder)
Definition: cs_hho_stokes.cpp:608
void cs_hho_stokes_build_system(const cs_mesh_t *mesh, const cs_real_t *field_val, double dt_cur, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data)
Build the linear system arising from a scalar convection/diffusion equation with a HHO scheme....
Definition: cs_hho_stokes.cpp:646
void cs_hho_stokes_get(cs_cell_sys_t **csys, cs_cell_builder_t **cb, cs_hho_builder_t **hhob)
Definition: cs_hho_stokes.cpp:397
void cs_hho_stokes_finalize(void)
Free buffers and generic structures related to HHO schemes.
Definition: cs_hho_stokes.cpp:415
double * cs_hho_stokes_get_cell_values(const void *data)
Get the computed values at cells (DoF used in the linear system are located at primal faces)
Definition: cs_hho_stokes.cpp:764
void cs_hho_stokes_initialize(cs_flag_t scheme_flag, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step, const cs_matrix_assembler_t *ma0, const cs_matrix_assembler_t *ma1, const cs_matrix_assembler_t *ma2, const cs_matrix_structure_t *ms0, const cs_matrix_structure_t *ms1, const cs_matrix_structure_t *ms2)
Allocate work buffer and general structures related to HHO schemes Set shared pointers.
Definition: cs_hho_stokes.cpp:283
void * cs_hho_stokes_init_context(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb)
Initialize a cs_hho_stokes_t structure storing data useful for managing such a scheme.
Definition: cs_hho_stokes.cpp:452
void cs_hho_stokes_extra_op(const char *eqname, const cs_field_t *field, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data)
Definition: cs_hho_stokes.cpp:787
struct _cs_matrix_structure_t cs_matrix_structure_t
Definition: cs_matrix.h:104
Definition: cs_matrix.h:108
double precision, dimension(:,:), pointer solu
Definition: atincl.f90:260
Definition: cs_cdo_connect.h:57
Definition: cs_cdo_quantities.h:142
Definition: cs_cdo_local.h:56
Definition: cs_cdo_local.h:163
Definition: cs_hho_builder.h:50
