cs_divergence.h File Reference
#include "base/cs_base.h"
#include "base/cs_field.h"
#include "base/cs_halo.h"
#include "alge/cs_gradient.h"
#include "mesh/cs_mesh.h"
+ Include dependency graph for cs_divergence.h:
void cs_mass_flux (const cs_mesh_t *m, const cs_mesh_quantities_t *fvq, int f_id, int itypfl, int iflmb0, int init, int inc, int imrgra, int nswrgu, cs_gradient_limit_t imligu, int iwarnu, double epsrgu, double climgu, const cs_real_t rom[], const cs_real_t romb[], const cs_real_3_t vel[], cs_field_bc_coeffs_t *bc_coeffs_v, cs_real_t *i_massflux, cs_real_t *b_massflux)
void cs_divergence (const cs_mesh_t *m, int init, const cs_real_t i_massflux[], const cs_real_t b_massflux[], cs_real_t *diverg)
 Add the integrated mass flux on the cells. More...
void cs_tensor_divergence (const cs_mesh_t *m, int init, const cs_real_3_t i_massflux[], const cs_real_3_t b_massflux[], cs_real_3_t *diverg)
 Add the integrated mass flux on the cells for a tensor variable. More...
void cs_ext_force_flux (const cs_mesh_t *m, cs_mesh_quantities_t *fvq, int init, int nswrgu, const cs_real_3_t frcxt[], const cs_real_t cofbfp[], cs_real_t *i_massflux, cs_real_t *b_massflux, const cs_real_t i_visc[], const cs_real_t b_visc[], const cs_real_t viselx[], const cs_real_t visely[], const cs_real_t viselz[])
 Project the external source terms to the faces in coherence with cs_face_diffusion_scalar for the improved hydrostatic pressure algorithm (iphydr=1). More...
void cs_ext_force_anisotropic_flux (const cs_mesh_t *m, cs_mesh_quantities_t *fvq, int init, int nswrgp, int ircflp, const cs_real_3_t frcxt[], const cs_real_t cofbfp[], const cs_real_t i_visc[], const cs_real_t b_visc[], cs_real_6_t viscel[], const cs_real_2_t weighf[], cs_real_t *i_massflux, cs_real_t *b_massflux)
 Project the external source terms to the faces in coherence with cs_face_anisotropic_diffusion_scalar for the improved hydrostatic pressure algorithm (iphydr=1). More...
void cs_tensor_face_flux (const cs_mesh_t *m, const cs_mesh_quantities_t *fvq, int f_id, int itypfl, int iflmb0, int init, int inc, const cs_equation_param_t *eqp, const cs_real_t c_rho[], const cs_real_t b_rho[], const cs_real_6_t c_var[], const cs_field_bc_coeffs_t *bc_coeffs_ts, cs_real_3_t *i_massflux, cs_real_3_t *b_massflux)
 Add $ \rho \tens{r} \vect{s}_\ij$ to a flux. More...
◆ cs_divergence()
void cs_divergence ( const cs_mesh_t *  m,
int  init,
cs_real_t *  diverg
\dot{m}_i = \dot{m}_i + \sum_{\fij \in \Facei{\celli}} \dot{m}_\ij
[in]mpointer to mesh
[in]initindicator
  • 1 initialize the divergence to 0
  • 0 otherwise
[in]i_massfluxmass flux at interior faces
[in]b_massfluxmass flux at boundary faces
[in,out]divergmass flux divergence
◆ cs_ext_force_anisotropic_flux()
void cs_ext_force_anisotropic_flux ( const cs_mesh_t *  m,
cs_mesh_quantities_t *  fvq,
int  init,
int  nswrgp,
int  ircflp,
cs_real_t *  i_massflux,
cs_real_t *  b_massflux
[in]fvqpointer to finite volume quantities
[in]initindicator
  • 1 initialize the mass flux to 0
  • 0 otherwise
[in]nswrgpnumber of reconstruction sweeps for the gradients
[in]ircflpindicator
  • 1 flux reconstruction,
  • 0 otherwise
[in]frcxtbody force creating the hydrostatic pressure
[in]cofbfpboundary condition array for the diffusion of the variable (implicit part)
[in]i_visc$ \mu_\fij \dfrac{S_\fij}{\ipf \jpf} $ at interior faces for the r.h.s.
[in]b_visc$ \mu_\fib \dfrac{S_\fib}{\ipf \centf} $ at border faces for the r.h.s.
[in]viscelsymmetric cell tensor $ \tens{\mu}_\celli $
[in]weighfinternal face weight between cells i j in case of tensor diffusion
[in,out]i_massfluxmass flux at interior faces
[in,out]b_massfluxmass flux at boundary faces
◆ cs_ext_force_flux()
void cs_ext_force_flux ( const cs_mesh_t *  m,
int  init,
int  nswrgu,
cs_real_t *  b_massflux,
[in]initindicator
  • 0 otherwise
[in]nswrgunumber of reconstruction sweeps for the gradients
[in]viselxviscosity by cell, dir x
[in]viselyviscosity by cell, dir y
[in]viselzviscosity by cell, dir z
◆ cs_mass_flux()
void cs_mass_flux ( const cs_mesh_t *  m,
const cs_mesh_quantities_t *  fvq,
int  f_id,
int  itypfl,
int  iflmb0,
int  init,
int  inc,
int  imrgra,
int  nswrgu,
int  iwarnu,
double  epsrgu,
double  climgu,
cs_field_bc_coeffs_t *  bc_coeffs_v,
◆ cs_tensor_divergence()
void cs_tensor_divergence ( const cs_mesh_t *  m,
int  init,
cs_real_3_t *  diverg
[in]initindicator
  • 0 otherwise
[in]i_massfluxmass flux vector at interior faces
[in]b_massfluxmass flux vector at boundary faces
[in,out]divergmass flux divergence vector
◆ cs_tensor_face_flux()
void cs_tensor_face_flux ( const cs_mesh_t *  m,
int  f_id,
int  itypfl,
int  iflmb0,
int  init,
int  inc,
const cs_field_bc_coeffs_t *  bc_coeffs_ts,
cs_real_3_t *  i_massflux,
cs_real_3_t *  b_massflux
[in]f_idfield id (or -1)
[in]itypflindicator (take rho into account or not)
  • 1 compute $ \rho\vect{u}\cdot\vect{s} $
  • 0 compute $ \vect{u}\cdot\vect{s} $
[in]iflmb0the mass flux is set to 0 on walls and symmetries if = 1
[in]initthe mass flux is initialized to 0 if > 0
[in]incindicator
  • 0 solve an increment
  • 1 otherwise
[in]imrgraindicator
  • 0 iterative gradient
  • 1 least square gradient
[in]nswrgunumber of sweeps for the reconstruction of the gradients
[in]imliguclipping gradient method
  • < 0 no clipping
  • = 0 thanks to neighbooring gradients
  • = 1 thanks to the mean gradient
[in]iwarnuverbosity
[in]epsrgurelative precision for the gradient reconstruction
[in]climguclipping coefficient for the computation of the gradient
[in]c_rhocell density
[in]b_rhodensity at boundary faces
[in]c_varvariable
[in]bc_coeffs_tsboundary condition structure for the variable
[in,out]i_massfluxmass flux at interior faces $ \dot{m}_\fij $
[in,out]b_massfluxmass flux at boundary faces $ \dot{m}_\fib $
