cs_atmo_variables.cpp File Reference
#include "bft/bft_error.h"
#include "atmo/cs_atmo_1d_rad.h"
#include "atmo/cs_atmo.h"
#include "atmo/cs_atmo_chemistry.h"
#include "atmo/cs_atmo_imbrication.h"
#include "atmo/cs_at_data_assim.h"
#include "atmo/cs_atmo_profile_std.h"
#include "atmo/cs_air_props.h"
#include "atmo/cs_intprf.h"
#include "base/cs_physical_properties.h"
#include "base/cs_post.h"
#include "base/cs_velocity_pressure.h"
#include "atmo/cs_atmo_variables.h"
+ Include dependency graph for cs_atmo_variables.cpp:
void cs_atmo_add_variable_fields (void)
void cs_atmo_add_property_fields (void)
 Add atmospheric property fields. More...
void cs_atmo_physical_properties_update (void)
 Update the thermo physical properties fields for the humid air and the liquid. More...
void cs_atmo_init_variables_1 (void)
 Initialization of variable options for the atmospheric module before what is done in cs_user_parameters functions. More...
void cs_atmo_init_variables_2 (void)
 Initialization of variable options for the atmospheric module after what is done in cs_user_parameters functions. More...
Add atmospheric model fields.
◆ cs_atmo_add_property_fields()
void cs_atmo_add_property_fields ( void  )
◆ cs_atmo_add_variable_fields()
void cs_atmo_add_variable_fields ( void  )
Add atmospheric variable fields
◆ cs_atmo_init_variables_1()
void cs_atmo_init_variables_1 ( void  )
◆ cs_atmo_init_variables_2()
void cs_atmo_init_variables_2 ( void  )
◆ cs_atmo_physical_properties_update()
void cs_atmo_physical_properties_update ( void  )
Remarks
This function is called at the beginning of each time step.
