cs_atmo_chemistry.cpp File Reference
#include <errno.h>
#include <ctype.h>
#include <stdarg.h>
#include <float.h>
#include <mpi.h>
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "atmo/cs_air_props.h"
#include "base/cs_base.h"
#include "cdo/cs_domain.h"
#include "base/cs_field.h"
#include "base/cs_log.h"
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "base/cs_scalar_clipping.h"
#include "mesh/cs_mesh.h"
#include "base/cs_parall.h"
#include "base/cs_parameters_check.h"
#include "atmo/cs_atmo.h"
#include "atmo/cs_atmo_aerosol_ssh.h"
#include "atmo/cs_atmo_chemistry.h"
+ Include dependency graph for cs_atmo_chemistry.cpp:
void cs_atmo_aerosol_initialize (void)
 This function initializes the external aerosol code. More...
void cs_atmo_aerosol_finalize (void)
 This function finalizes the external aerosol code. More...
void cs_atmo_aerosol_get_gas (cs_real_t *array)
 This function fills the given array with gas concentrations from the external aerosol code. More...
void cs_atmo_aerosol_time_advance (void)
 This function computes a time step of gaseous chemistry and aerosols dynamic using the external aerosol code. More...
void cs_atmo_read_aerosol (void)
 Reads initial aerosol concentration and number. More...
void cs_atmo_read_chemistry_profile (int mode)
 Reads the chemistry profile data for the atmospheric chemistry. More...
void cs_atmo_set_chem_conc_file_name (const char *file_name)
 This function set the file name of the chemistry file. More...
void cs_atmo_set_aero_conc_file_name (const char *file_name)
 This function set the file name of the aerosol file. More...
void cs_atmo_init_chemistry (void)
 Initialize chemistry array. More...
void cs_atmo_chemistry_set_spack_file_name (const char *file_name)
 This function set the file name of the SPACK file. More...
void cs_atmo_chemistry_set_aerosol_file_name (const char *file_name)
 This function sets the file name to initialize the aerosol library. More...
void cs_atmo_declare_chem_from_spack (void)
 This function declares additional transported variables for atmospheric module for the chemistry defined from SPACK. More...
void cs_atmo_chemistry_initialization_deactivate (void)
 Deactivate chemistry initialization procedure. More...
int cs_atmo_chemistry_need_initialization (void)
 Check if the chemistry module needs initialization. More...
void cs_atmo_chemistry_initialize_reacnum (void)
 Initialize chemistry cell kinetic rates arrays. More...
void cs_atmo_chemistry_finalize (void)
 Finalize atmospheric chemistry structures. More...
void cs_atmo_chemistry_log_setup (void)
 Print the atmospheric chemistry options to setup.log. More...
void cs_atmo_aerosol_log_setup (void)
 Print the atmospheric aerosols options to setup.log. More...
void cs_atmo_chem_initialize_dlconc0 (void)
 initialize gaseous and particulate concentrations and aerosol number More...
void cs_atmo_chemistry_initialize_conc_profiles (void)
 initialize (allocate) chemistry concentrations profiles More...
void cs_atmo_chem_exp_source_terms (int f_id, cs_real_t st_exp[])
 Computes the explicit chemical source term for atmospheric chemistry in case of a semi-coupled resolution. More...
void cs_atmo_compute_gaseous_chemistry (void)
 Calls the rosenbrock resolution for atmospheric chemistry. More...
◆ cs_atmo_aerosol_finalize()
void cs_atmo_aerosol_finalize ( void  )
◆ cs_atmo_aerosol_get_gas()
void cs_atmo_aerosol_get_gas ( cs_real_t *  array)
[out]arraygas concentrations
◆ cs_atmo_aerosol_initialize()
void cs_atmo_aerosol_initialize ( void  )
◆ cs_atmo_aerosol_log_setup()
void cs_atmo_aerosol_log_setup ( void  )
◆ cs_atmo_aerosol_time_advance()
void cs_atmo_aerosol_time_advance ( void  )
◆ cs_atmo_chem_exp_source_terms()
void cs_atmo_chem_exp_source_terms ( int  f_id,
cs_real_t  st_exp[]
[in]f_idfield id
[out]st_expexplicit part of the source term
◆ cs_atmo_chem_initialize_dlconc0()
void cs_atmo_chem_initialize_dlconc0 ( void  )
◆ cs_atmo_chemistry_finalize()
void cs_atmo_chemistry_finalize ( void  )
◆ cs_atmo_chemistry_initialization_deactivate()
void cs_atmo_chemistry_initialization_deactivate ( void  )
◆ cs_atmo_chemistry_initialize_conc_profiles()
void cs_atmo_chemistry_initialize_conc_profiles ( void  )
◆ cs_atmo_chemistry_initialize_reacnum()
void cs_atmo_chemistry_initialize_reacnum ( void  )
◆ cs_atmo_chemistry_log_setup()
void cs_atmo_chemistry_log_setup ( void  )
◆ cs_atmo_chemistry_need_initialization()
int cs_atmo_chemistry_need_initialization ( void  )
int value : 1 if needed, 0 if not
◆ cs_atmo_chemistry_set_aerosol_file_name()
void cs_atmo_chemistry_set_aerosol_file_name ( const char *  file_name)
[in]file_namename of the file.
◆ cs_atmo_chemistry_set_spack_file_name()
void cs_atmo_chemistry_set_spack_file_name ( const char *  file_name)
◆ cs_atmo_compute_gaseous_chemistry()
void cs_atmo_compute_gaseous_chemistry ( void  )
◆ cs_atmo_declare_chem_from_spack()
void cs_atmo_declare_chem_from_spack ( void  )
◆ cs_atmo_init_chemistry()
void cs_atmo_init_chemistry ( void  )
◆ cs_atmo_read_aerosol()
void cs_atmo_read_aerosol ( void  )
◆ cs_atmo_read_chemistry_profile()
void cs_atmo_read_chemistry_profile ( int  mode)
[in]modeif false reading of dimensions only else reading of data
◆ cs_atmo_set_aero_conc_file_name()
void cs_atmo_set_aero_conc_file_name ( const char *  file_name)
This function set the file name of the aerosol concentration file.
◆ cs_atmo_set_chem_conc_file_name()
void cs_atmo_set_chem_conc_file_name ( const char *  file_name)
