cs_atmo_aerosol_ssh.h
1#ifndef CS_ATMO_AEROSOL_SSH_H
2#define CS_ATMO_AEROSOL_SSH_H
5 * Main for atmospheric aerosols library SSH related functions
31 * PLE library headers
34#include <ple_locator.h>
37 * Local headers
38 *----------------------------------------------------------------------------*/
40#include "fvm/fvm_nodal.h"
42#include "base/cs_base.h"
43#include "base/cs_halo.h"
44#include "mesh/cs_mesh.h"
46
48 * Local Macro definitions
50
51/*============================================================================
52 * Type definitions
53 *============================================================================*/
54
55/*============================================================================
56 * Static global variables
58
59/*============================================================================
60 * Public function definitions
61 *============================================================================*/
62
63/*----------------------------------------------------------------------------*/
67/*----------------------------------------------------------------------------*/
68
69void
71
72/*----------------------------------------------------------------------------*/
76/*----------------------------------------------------------------------------*/
77
78void
80
81/*----------------------------------------------------------------------------*/
82/*
83 * \brief This function computes the number of aerosols using the given array
84 */
85/*----------------------------------------------------------------------------*/
86
87void
89
90/*----------------------------------------------------------------------------*/
101/*----------------------------------------------------------------------------*/
102
103void
105 cs_real_t *P,
106 cs_real_t *yw);
107
108/*----------------------------------------------------------------------------*/
114
115void
117
118/*----------------------------------------------------------------------------*/
123/*----------------------------------------------------------------------------*/
124
125void
127
128/*----------------------------------------------------------------------------*/
133/*----------------------------------------------------------------------------*/
134
135void
137
138/*----------------------------------------------------------------------------*/
143/*----------------------------------------------------------------------------*/
144
145void
147
148/*----------------------------------------------------------------------------*/
153/*----------------------------------------------------------------------------*/
154
155void
157
158/*----------------------------------------------------------------------------*/
159
160#endif /* CS_ATMO_AEROSOL_SSH_H */
void cs_atmo_aerosol_ssh_initialize(void)
This function initializes SSH-aerosol.
Definition: cs_atmo_aerosol_ssh.cpp:331
void cs_atmo_aerosol_ssh_get_aero(cs_real_t *)
This function fills the given array with aerosol concentrations and numbers from SSH-aerosol.
Definition: cs_atmo_aerosol_ssh.cpp:659
void cs_atmo_aerosol_ssh_set_gas(cs_real_t *)
This function uses the given array to update the gas concentrations in SSH-aerosol.
Definition: cs_atmo_aerosol_ssh.cpp:701
void cs_atmo_aerosol_ssh_time_advance(void)
This function computes a time step of gaseous chemistry and aerosols dynamic using SSH-aerosol.
Definition: cs_atmo_aerosol_ssh.cpp:752
void cs_atmo_aerosol_ssh_compute_numbers(cs_real_t *)
This function computes the number of aerosols using the given array.
Definition: cs_atmo_aerosol_ssh.cpp:547
void cs_atmo_aerosol_ssh_finalize(void)
This function finalizes SSH-aerosol.
Definition: cs_atmo_aerosol_ssh.cpp:522
void cs_atmo_aerosol_ssh_get_gas(cs_real_t *)
This function fills the given array with gas concentrations from SSH-aerosol.
Definition: cs_atmo_aerosol_ssh.cpp:725
void cs_atmo_aerosol_ssh_set_t_p_h(cs_real_t *T, cs_real_t *P, cs_real_t *yw)
This function takes as input absolute temperature T total pressure P water mass fraction yw It comput...
Definition: cs_atmo_aerosol_ssh.cpp:590
void cs_atmo_aerosol_ssh_set_aero(cs_real_t *)
This function uses the given array to update the aerosol concentrations and numbers in SSH-aerosol.
Definition: cs_atmo_aerosol_ssh.cpp:627
Definition: cs_defs.h:332
