cs_time_step_options_t Struct Reference
time step options descriptor More...
#include <cs_time_step.h>
+ Collaboration diagram for cs_time_step_options_t:
Public Attributes
int iptlro
cs_time_step_type_t idtvar
double coumax
double cflmmx
double foumax
double varrdt
double dtmin
double dtmax
double relxst
Members of this time step options descriptor are publicly accessible, to allow for concise syntax.
Member Data Documentation
◆ cflmmx
cflmmx
Max. Courant number for the continuity equation in compressible model.
◆ coumax
coumax
Maximum Courant number (when idtvar is different from CS_TIME_STEP_CONSTANT).
◆ dtmax
dtmax
Upper limit for the calculated time step when idtvar is different from CS_TIME_STEP_CONSTANT. Take dtmax = max (ld/ud, sqrt(lt/(gdelta rho/rho)), ...).
◆ dtmin
dtmin
Lower limit for the calculated time step when idtvar is different from CS_TIME_STEP_CONSTANT. Take dtmin = min (ld/ud, sqrt(lt/(gdelta rho/rho)), ...).
◆ foumax
foumax
Maximum Fourier number (when idtvar is different from CS_TIME_STEP_CONSTANT).
◆ idtvar
idtvar
Time step type: constant, adaptive, or steady algorithm variants. If the numerical scheme is a second-order in time, only the option CS_TIME_STEP_CONSTANT is allowed.
◆ iptlro
iptlro
Clip the time step with respect to the buoyant effects
When density gradients and gravity are present, a local thermal time step can be calculated, based on the Brunt-Vaisala frequency. In numerical simulations, it is usually wise for the time step to be lower than this limit, otherwise numerical instabilities may appear.
iptlro indicates whether the time step should be limited to the local thermal time step (=1) or not (=0).
When iptlro=1, the log shows the number of cells where the time step has been clipped due to the thermal criterion, as well as the maximum ratio between the time step and the maximum thermal time step. If idtvar=CS_TIME_STEP_CONSTANT, since the time step is fixed and cannot be clipped, this ratio can be greater than 1. When idtvar > CS_TIME_STEP_CONSTANT, this ratio will be less than 1, except if the constraint dtmin has prevented the code from reaching a sufficiently low value for dt. Useful when density gradients and gravity are present.
◆ relxst
relxst
Relaxation coefficient for the steady algorithm. relxst = 1 : no relaxation.
◆ varrdt
varrdt
Maximum allowed relative increase in the calculated time step value between two successive time steps (to ensure stability, any decrease in the time step is immediate and without limit).
Useful when idtvar is different from CS_TIME_STEP_CONSTANT.
