cs_paramedmem_coupling_t Struct Reference
#include <cs_paramedmem_coupling_utils.h>
+ Collaboration diagram for cs_paramedmem_coupling_t:
Public Member Functions
void add_mesh_from_criteria (const char *sel_crit, int elt_dim)
 Define coupled mesh based on a selection criteria. More...
void add_mesh_from_zone (const cs_zone_t *zone)
 Define coupled mesh based on a cs_zone_t pointer. More...
void add_mesh_from_ids (cs_lnum_t n_elts, const cs_lnum_t elt_ids[], int elt_dim)
std::string getName () const
 Get name of the coupling. More...
cs_lnum_t get_n_elts () const
 Get number of elements of coupled mesh. More...
const cs_lnum_t * get_elt_list () const
 Get indirection list for elements in coupled mesh. More...
cs_lnum_t get_n_vertices () const
 Get number of vertices of coupled mesh. More...
const cs_lnum_t * get_vertex_list () const
 Get indirection list for vertices in coupled mesh. More...
int add_field (const char *name, int dim, cs_medcpl_field_nature_t field_nature, cs_medcpl_space_discr_t space_discr, cs_medcpl_time_discr_t time_discr)
 Add a coupled field. More...
int add_field (const cs_field_t *f, cs_medcpl_field_nature_t fn, cs_medcpl_time_discr_t td)
 Add a coupled field based on a cs_field_t pointer. More...
void set_values (const char *name, const double values[], const bool use_list_elt=true)
 Assign values based on parent mesh location to associated ParaFIELD objects. More...
void get_values (const char *name, double values[], const bool use_list_elt=true) const
 Copy values from associated ParaFIELD object to array defined parent mesh location. More...
void send_data () const
 Send values of field attached to DEC. More...
void send_data (const char *name, const double *vals, const bool use_list_elt=true)
 Send values of a field. If vals pointer is non-null, values are updated before send. More...
void recv_data ()
 Recieve values of field attached to DEC. More...
void recv_data (const char *name, double *vals, const bool use_list_elt=true)
 Recieve values of a field. More...
void sync_dec ()
 Sync the coupling's the DEC. More...
void attach_field_by_id (int field_id)
 Attach a field to the DEC for send operation using its index. More...
void attach_field_by_name (const char *name)
 Attach a field to the DEC for send operation using its name. More...
void log () const
 Log ParaMEDMEM coupling setup information. More...
Public Attributes
std::string _name
ple_coupling_mpi_set_info_t apps [2]
void * para_mesh
void * dec
void * fields
MPI_Comm comm
bool dec_synced
Member Function Documentation
◆ add_field() [1/2]
int add_field ( const char *  name,
int  dim,
[in]namename of field
[in]dimfield dimension
[in]field_naturefield nature flag
[in]space_discrfield space discretisation (nodes or cells)
[in]time_discrfield coupling time discretisation
index of field within the storing vector
◆ add_field() [2/2]
int add_field ( const cs_field_t *  f,
[in]fpointer to cs_field_t struct
[in]fnfield nature flag
◆ add_mesh_from_criteria()
void add_mesh_from_criteria ( const char *  sel_crit,
int  elt_dim
[in]sel_critgeometrical selection criteria (string)
[in]elt_dimdimension of coupled elements
◆ add_mesh_from_ids()
void add_mesh_from_ids ( cs_lnum_t  n_elts,
int  elt_dim
[in]n_eltslocal number of elements
[in]elt_idslist of local elements
[in]elt_dimdimension of elements (2: faces, 3: cells)
◆ add_mesh_from_zone()
void add_mesh_from_zone ( const cs_zone_t *  zone)
[in]zonepointer to cs_zone_t struct
◆ attach_field_by_id()
void attach_field_by_id ( int  field_id)
[in]field_idindex of field in storing vector
◆ attach_field_by_name()
void attach_field_by_name ( const char *  name)
[in]namename of field (string)
◆ get_elt_list()
const cs_lnum_t * get_elt_list ( ) const
inline
cs_lnum_t pointer to indirection list
◆ get_n_elts()
cs_lnum_t get_n_elts ( ) const
inline
number of elements in mesh associated to coupling
◆ get_n_vertices()
cs_lnum_t get_n_vertices ( ) const
inline
◆ get_values()
void get_values ( const char *  name,
double  values[],
const bool  use_list_elt = true
) const
[in]valuesarray in which values will be stored
[in]use_list_eltCopy values from associated ParaFIELD structure to array defined on mesh location corresponding to coupled elements (and associated ParaMESH).
◆ get_vertex_list()
const cs_lnum_t * get_vertex_list ( ) const
inline
pointer to indirection list; null if locally contiguous or empty
◆ getName()
std::string getName ( ) const
inline
◆ log()
void log ( ) const
◆ recv_data() [1/2]
void recv_data ( )
◆ recv_data() [2/2]
void recv_data ( const char *  name,
double *  vals,
[in]valsarray of values to read
◆ send_data() [1/2]
void send_data ( ) const
◆ send_data() [2/2]
void send_data ( const char *  name,
const double *  vals,
[in]valsarray of values to write
◆ set_values()
void set_values ( const char *  name,
[in]valuesarray of values to write (defined on parent mesh location)
◆ sync_dec()
void sync_dec ( )
Sync the coupling's DEC.
Member Data Documentation
◆ _name
std::string _name
◆ apps
◆ comm
MPI_Comm comm
◆ dec
void* dec
◆ dec_synced
bool dec_synced
◆ fields
void* fields
◆ para_mesh
void* para_mesh
