cs_solidification.cpp File Reference
Structure and functions handling the solidification module (modified Navier-Stokes + thermal module + transport equations) More...
#include <cassert>
#include "base/cs_array.h"
#include "base/cs_mem.h"
#include "base/cs_parall.h"
#include "base/cs_post.h"
#include "bft/bft_error.h"
#include "cdo/cs_cdofb_scaleq.h"
#include "cdo/cs_navsto_system.h"
#include "cdo/cs_solid_selection.h"
#include "cdo/cs_solidification.h"
+ Include dependency graph for cs_solidification.cpp:
Macros
#define CS_SOLIDIFICATION_DBG   0
bool cs_solidification_is_activated (void)
 Test if solidification module is activated. More...
cs_solidification_t * cs_solidification_get_structure (void)
 Retrieve the main structure to deal with solidification process. More...
void cs_solidification_set_verbosity (int verbosity)
 Set the level of verbosity for the solidification module. More...
void cs_solidification_set_forcing_eps (cs_real_t forcing_eps)
 Set the value of the epsilon parameter used in the forcing term of the momentum equation. More...
cs_solidification_t * cs_solidification_activate (cs_solidification_model_t model, cs_flag_t options, cs_flag_t post_flag, const cs_boundary_t *boundaries, cs_navsto_param_model_t ns_model, cs_navsto_param_model_flag_t ns_model_flag, cs_navsto_param_coupling_t algo_coupling, cs_navsto_param_post_flag_t ns_post_flag)
 Activate the solidification module. More...
void cs_solidification_set_kozeny_carman_parameters (double kozeny_constant, double tortuosity, double s_das)
 Set the parameters involved in the computation of the permeability coefficient of the Kozeny-Carman relation. More...
cs_solidification_stefan_t * cs_solidification_get_stefan_struct (void)
 Get the structure defining the Stefan model. More...
cs_solidification_stefan_t * cs_solidification_check_stefan_model (void)
 Sanity checks on the consistency of the Stefan's model settings. More...
void cs_solidification_set_stefan_model (cs_real_t t_change, cs_real_t latent_heat)
 Set the main physical parameters which describe the Stefan model. More...
cs_solidification_voller_t * cs_solidification_get_voller_struct (void)
 Get the structure defining the Voller model. More...
cs_solidification_voller_t * cs_solidification_check_voller_model (void)
 Sanity checks on the consistency of the Voller's model settings. More...
void cs_solidification_set_voller_model (cs_real_t beta, cs_real_t t_ref, cs_real_t t_solidus, cs_real_t t_liquidus, cs_real_t latent_heat)
 Set the main physical parameters which describe the Voller and Prakash modelling. More...
void cs_solidification_set_voller_model_no_velocity (cs_real_t t_solidus, cs_real_t t_liquidus, cs_real_t latent_heat)
cs_solidification_binary_alloy_t * cs_solidification_get_binary_alloy_struct (void)
 Get the structure defining the binary alloy model. More...
cs_solidification_binary_alloy_t * cs_solidification_check_binary_alloy_model (void)
 Sanity checks on the consistency of the settings of the binary alloy model. More...
void cs_solidification_set_binary_alloy_model (const char *name, const char *varname, cs_real_t beta_t, cs_real_t temp0, cs_real_t beta_c, cs_real_t conc0, cs_real_t kp, cs_real_t mliq, cs_real_t t_eutec, cs_real_t t_melt, cs_real_t solute_diff, cs_real_t latent_heat)
 Set the main physical parameters which describe a solidification process with a binary alloy (with components A and B) Add a transport equation for the solute concentration to simulate the conv/diffusion of the alloy ratio between the two components of the alloy. More...
void cs_solidification_set_strategy (cs_solidification_strategy_t strategy)
 Set the strategy to update quantitiess (liquid fraction and the thermal source term for the two main quantities) More...
void cs_solidification_set_segr_functions (cs_solidification_func_t *vel_forcing, cs_solidification_func_t *cliq_update, cs_solidification_func_t *gliq_update, cs_solidification_func_t *thm_st_update)
 Set the functions to perform the update of physical properties and/or the computation of the thermal source term or quantities and/or the way to perform the coupling between the thermal equation and the bulk concentration computation. All this setting defines the way to compute the solidification process of a binary alloy. If a function is set to nullptr then the automatic settings are kept. More...
cs_solidification_t * cs_solidification_destroy_all (void)
 Free the main structure related to the solidification module. More...
void cs_solidification_init_setup (void)
 Setup equations/properties related to the solidification module. More...
void cs_solidification_finalize_setup (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant)
 Finalize the setup stage for equations related to the solidification module. More...
void cs_solidification_log_setup (void)
 Summarize the solidification module in the log file dedicated to the setup. More...
void cs_solidification_init_values (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step)
 Set an initial values for all quantities related to this module This is done after the setup step. More...
void cs_solidification_compute (const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *time_step, bool &is_last_iter)
 Solve equations related to the solidification module. More...
void cs_solidification_extra_op (const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, const cs_time_step_t *ts)
 Predefined extra-operations for the solidification module. More...
void cs_solidification_extra_post (void *input, int mesh_id, int cat_id, int ent_flag[5], cs_lnum_t n_cells, cs_lnum_t n_i_faces, cs_lnum_t n_b_faces, const cs_lnum_t cell_ids[], const cs_lnum_t i_face_ids[], const cs_lnum_t b_face_ids[], const cs_time_step_t *time_step)
 Predefined post-processing output for the solidification module. Prototype of this function is fixed since it is a function pointer defined in cs_post.h (cs_post_time_mesh_dep_output_t) More...
static const char _state_names [CS_SOLIDIFICATION_N_STATES][32]
◆ CS_SOLIDIFICATION_DBG
◆ cs_solidification_activate()
cs_solidification_t * cs_solidification_activate ( cs_solidification_model_t  model,
cs_flag_t  options,
const cs_boundary_t *  boundaries,
[in]modeltype of modelling
[in]optionsflag to handle optional parameters
[in]post_flagpredefined post-processings
[in]boundariespointer to the domain boundaries
[in]ns_modelmodel equations for the NavSto system
[in]ns_model_flagoption flag for the Navier-Stokes system
[in]algo_couplingalgorithm used for solving the NavSto system
[in]ns_post_flagpredefined post-processings for Navier-Stokes
a pointer to a new allocated solidification structure
◆ cs_solidification_check_binary_alloy_model()
cs_solidification_binary_alloy_t * cs_solidification_check_binary_alloy_model ( void  )
a pointer to the structure
◆ cs_solidification_check_stefan_model()
cs_solidification_stefan_t * cs_solidification_check_stefan_model ( void  )
◆ cs_solidification_check_voller_model()
cs_solidification_voller_t * cs_solidification_check_voller_model ( void  )
◆ cs_solidification_compute()
void cs_solidification_compute ( const cs_mesh_t *  mesh,
const cs_time_step_t *  time_step,
bool &  is_last_iter
[in,out]is_last_iterupdate if is the last iteration
◆ cs_solidification_destroy_all()
cs_solidification_t * cs_solidification_destroy_all ( void  )
a null pointer
◆ cs_solidification_extra_op()
void cs_solidification_extra_op ( const cs_cdo_connect_t *  connect,
const cs_time_step_t *  ts
[in]tspointer to a cs_time_step_t structure
◆ cs_solidification_extra_post()
void cs_solidification_extra_post ( void *  input,
int  mesh_id,
int  cat_id,
int  ent_flag[5],
cs_lnum_t  n_cells,
[in,out]inputpointer to a optional structure (here a cs_gwf_t structure)
[in]mesh_idid of the output mesh for the current call
[in]cat_idcategory id of the output mesh for this call
[in]ent_flagindicate global presence of cells (ent_flag[0]), interior faces (ent_flag[1]), boundary faces (ent_flag[2]), particles (ent_flag[3]) or probes (ent_flag[4])
[in]n_cellslocal number of cells of post_mesh
[in]n_i_faceslocal number of interior faces of post_mesh
[in]n_b_faceslocal number of boundary faces of post_mesh
[in]cell_idslist of cells (0 to n-1)
[in]i_face_idslist of interior faces (0 to n-1)
[in]b_face_idslist of boundary faces (0 to n-1)
[in]time_steppointer to a cs_time_step_t struct.
◆ cs_solidification_finalize_setup()
void cs_solidification_finalize_setup ( const cs_cdo_connect_t *  connect,
◆ cs_solidification_get_binary_alloy_struct()
cs_solidification_binary_alloy_t * cs_solidification_get_binary_alloy_struct ( void  )
◆ cs_solidification_get_stefan_struct()
cs_solidification_stefan_t * cs_solidification_get_stefan_struct ( void  )
◆ cs_solidification_get_structure()
cs_solidification_t * cs_solidification_get_structure ( void  )
◆ cs_solidification_get_voller_struct()
cs_solidification_voller_t * cs_solidification_get_voller_struct ( void  )
◆ cs_solidification_init_setup()
void cs_solidification_init_setup ( void  )
◆ cs_solidification_init_values()
void cs_solidification_init_values ( const cs_mesh_t *  mesh,
◆ cs_solidification_is_activated()
bool cs_solidification_is_activated ( void  )
◆ cs_solidification_log_setup()
void cs_solidification_log_setup ( void  )
◆ cs_solidification_set_binary_alloy_model()
void cs_solidification_set_binary_alloy_model ( const char *  name,
const char *  varname,
cs_real_t  beta_t,
cs_real_t  temp0,
cs_real_t  beta_c,
cs_real_t  conc0,
cs_real_t  kp,
cs_real_t  mliq,
cs_real_t  t_eutec,
cs_real_t  t_melt,
[in]namename of the binary alloy
[in]varnamename of the unknown related to the tracer eq.
[in]beta_tthermal dilatation coefficient
[in]temp0reference temperature (Boussinesq term)
[in]beta_csolutal dilatation coefficient
[in]conc0reference mixture concentration (Boussinesq term)
[in]kpvalue of the distribution coefficient
[in]mliqliquidus slope for the solute concentration
[in]t_eutectemperature at the eutectic point
[in]t_meltphase-change temperature for the pure material (A)
[in]solute_diffsolutal diffusion coefficient in the liquid
[in]latent_heatlatent heat
◆ cs_solidification_set_forcing_eps()
void cs_solidification_set_forcing_eps ( cs_real_t  forcing_eps)
[in]forcing_epsepsilon used in the penalization term to avoid a division by zero
◆ cs_solidification_set_kozeny_carman_parameters()
void cs_solidification_set_kozeny_carman_parameters ( double  kozeny_constant,
double  tortuosity,
double  s_das
[in]kozeny_constantvalue of the Kozeny constant (default = 5.0)
[in]tortuosityvalue of the tortuosity (default = 2.0)
[in]s_dasvalue of the secondary dendrite arm spacing (default = 0.00085 [m])
◆ cs_solidification_set_segr_functions()
void cs_solidification_set_segr_functions ( cs_solidification_func_t *  vel_forcing,
cs_solidification_func_t *  cliq_update,
cs_solidification_func_t *  gliq_update,
cs_solidification_func_t *  thm_st_update
Set the functions to perform the update of physical properties and/or the computation of the thermal source term or quantities and/or the way to perform the coupling between the thermal equation and the bulk concentration computation. All this setting defines the way to compute the solidification process of a binary alloy. If a function is set to null then the automatic settings are kept.
–Advanced usage– This enables to finely control the numerical or physical modelling aspects.
[in]vel_forcingpointer to update the velocity forcing
[in]cliq_updatepointer to update the liquid concentration
[in]gliq_updatepointer to update the liquid fraction
[in]thm_st_updatepointer to update thermal source terms
◆ cs_solidification_set_stefan_model()
void cs_solidification_set_stefan_model ( cs_real_t  t_change,
[in]t_changeliquidus/solidus temperature (in K)
◆ cs_solidification_set_strategy()
void cs_solidification_set_strategy ( cs_solidification_strategy_t  strategy)
[in]strategystrategy to perform the update of quantities
◆ cs_solidification_set_verbosity()
void cs_solidification_set_verbosity ( int  verbosity)
[in]verbositylevel of verbosity to set
◆ cs_solidification_set_voller_model()
void cs_solidification_set_voller_model ( cs_real_t  beta,
cs_real_t  t_ref,
[in]betathermal dilatation coefficient
[in]t_refreference temperature (for the Boussinesq approx)
[in]t_solidussolidus temperature (in K)
[in]t_liquidusliquidus temperature (in K)
◆ cs_solidification_set_voller_model_no_velocity()
void cs_solidification_set_voller_model_no_velocity ( cs_real_t  t_solidus,
◆ _state_names
const char _state_names[CS_SOLIDIFICATION_N_STATES][32]
static
Initial value:
"Solid",
"Mushy",
"Liquid",
"Eutectic"
