cs_rad_transfer_absorption.cpp File Reference
#include <errno.h>
#include <limits.h>
#include "bft/bft_error.h"
#include "bft/bft_printf.h"
#include "base/cs_assert.h"
#include "base/cs_base.h"
#include "comb/cs_coal.h"
#include "cogz/cs_combustion_gas.h"
#include "base/cs_field.h"
#include "base/cs_log.h"
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "mesh/cs_mesh.h"
#include "base/cs_parall.h"
#include "pprt/cs_combustion_model.h"
#include "rayt/cs_rad_transfer.h"
#include "rayt/cs_rad_transfer_modak.h"
#include "rayt/cs_rad_transfer_adf_models.h"
#include "rayt/cs_rad_transfer_fsck.h"
#include "rayt/cs_rad_transfer_rcfsk.h"
#include "rayt/cs_rad_transfer_absorption.h"
+ Include dependency graph for cs_rad_transfer_absorption.cpp:
void cs_rad_transfer_absorption (const cs_real_t tempk[], cs_real_t cpro_cak0[], cs_real_t kgas[], cs_real_t agas[], cs_real_t agasb[])
 Compute absorption coefficient for gas mix and particles for pulverized coal or other specific physical models. More...
void cs_rad_transfer_rcfsk_absorption (const cs_real_t tempk[], cs_real_t kgas[], cs_real_t agas[], cs_real_t agasb[])
 Compute absorption coefficient for the case of the RCFSK model. More...
void cs_rad_transfer_absorption_check_p1 (const cs_real_t cpro_cak[])
 Check the absorption validity fo the P-1 approximation. More...
Absorption coefficient computation for radiative transfer with specific physical models.
◆ cs_rad_transfer_absorption()
void cs_rad_transfer_absorption ( const cs_real_t  tempk[],
cs_real_t  kgas[],
cs_real_t  agas[],
cs_real_t  agasb[]
For the P-1 model, this function also checks whether the medium's optical length is at least of the order of unity.
[in]tempkgas phase temperature at cells (in Kelvin)
[out]cpro_cak0medium (gas) Absorption coefficient
[out]kgasradiation coefficients of the gray gases at cells (per gas)
[out]agasweights of the gray gases at cells (per gas)
[out]agasbweights of the gray gases at boundary faces (per gas)
◆ cs_rad_transfer_absorption_check_p1()
void cs_rad_transfer_absorption_check_p1 ( const cs_real_t  cpro_cak[])
For the P-1 model, the medium's optical length should be at least of the order of unity.
[in]cpro_cakabsorption coefficient values (at cells)
◆ cs_rad_transfer_rcfsk_absorption()
void cs_rad_transfer_rcfsk_absorption ( const cs_real_t  tempk[],
cs_real_t  kgas[],
cs_real_t  agas[],
cs_real_t  agasb[]
Compute absorption coefficient for the case of gas combustion.
