cs_combustion_model.h
1#ifndef CS_COMBUSTION_MODEL_H
2#define CS_COMBUSTION_MODEL_H
5 * Combustion model parameters.
34#include <stdarg.h>
37 * Local headers
38 *----------------------------------------------------------------------------*/
40#include "base/cs_defs.h"
42/*=============================================================================
43 * Macro definitions
45
47 * Type definitions
49
51 * Global variables
53
54/*=============================================================================
55 * Public function prototypes
57
58/*----------------------------------------------------------------------------*/
75/*----------------------------------------------------------------------------*/
76
77void
79 int ngazem,
80 int npo,
81 const char nomcoel[][13],
82 double ehcoel[],
83 double cpcoel[],
84 double coeff_therm[][2][5],
85 const double wmolce[],
86 const double th[]);
87
88/*----------------------------------------------------------------------------*/
112/*----------------------------------------------------------------------------*/
113
114void
116 int indpdf[],
117 cs_real_t tpdf[],
118 const cs_real_t fm[],
119 cs_real_t fp2m[],
120 const cs_real_t fmini[],
121 const cs_real_t fmaxi[],
122 cs_real_t dirmin[],
123 cs_real_t dirmax[],
124 cs_real_t fdeb[],
125 cs_real_t ffin[],
126 cs_real_t hrec[]);
127
128/*----------------------------------------------------------------------------*/
129
130#endif /* CS_COMBUSTION_MODEL_H */
void cs_combustion_dirac_pdf(cs_lnum_t n_cells, int indpdf[], cs_real_t tpdf[], const cs_real_t fm[], cs_real_t fp2m[], const cs_real_t fmini[], const cs_real_t fmaxi[], cs_real_t dirmin[], cs_real_t dirmax[], cs_real_t fdeb[], cs_real_t ffin[], cs_real_t hrec[])
Compute rectangle-Dirac pdf parameters.
Definition: cs_combustion_model.cpp:352
void cs_combustion_enthalpy_and_cp_from_janaf(int ncoel, int ngazem, int npo, const char nomcoel[][13], double ehcoel[], double cpcoel[], double coeff_therm[][2][5], const double wmolce[], const double th[])
Compute Enthalpy and Cp based on the JANAF band.
Definition: cs_combustion_model.cpp:130
Definition: cs_defs.h:332
Definition: cs_defs.h:325
@ fp2m
Definition: cs_field_pointer.h:127
@ fm
Definition: cs_field_pointer.h:126
