1#ifndef CS_PARAM_SADDLE_H
2#define CS_PARAM_SADDLE_H
627 double scaling_coef);
643 const double scaling_coef);
Definition: cs_defs.h:528
Definition: cs_defs.h:529
int cs_param_saddle_set_precond(const char *keyval, cs_param_saddle_t *saddlep)
Set the type of preconditioning to apply for this saddle-point system.
Definition: cs_param_saddle.cpp:990
void cs_param_saddle_set_augmentation_coef(cs_param_saddle_t *saddlep, double coef)
Set the scaling in front of the augmentation term when an ALU, a GKB or a block Krylov algorithm is c...
Definition: cs_param_saddle.cpp:552
const char * cs_param_saddle_get_type_name(cs_param_saddle_solver_t type)
Retrieve the name of the type of saddle-point solver.
Definition: cs_param_saddle.cpp:660
cs_param_sles_t * cs_param_saddle_get_schur_sles_param(const cs_param_saddle_t *saddlep)
Get the pointer to the set of parameters to handle a SLES. This SLES is associated to the approximati...
Definition: cs_param_saddle.cpp:791
double cs_param_saddle_get_augmentation_coef(const cs_param_saddle_t *saddlep)
Get the scaling coefficient in front of the augmentation term when an ALU, GKB or block Krylov algori...
Definition: cs_param_saddle.cpp:610
void cs_param_saddle_copy(const cs_param_saddle_t *ref, cs_param_saddle_t *dest)
Copy a cs_param_saddle_t structure from ref to dest.
Definition: cs_param_saddle.cpp:1458
const char * cs_param_saddle_get_name(const cs_param_saddle_t *saddlep)
Retrieve the name of the saddle-point solver.
Definition: cs_param_saddle.cpp:918
Type of solver used to solve a saddle-point system. Up to now, this happens only with CDO cell-based ...
Definition: cs_param_saddle.h:189
@ CS_PARAM_SADDLE_SOLVER_NONE
Definition: cs_param_saddle.h:191
@ CS_PARAM_SADDLE_N_SOLVERS
Definition: cs_param_saddle.h:204
@ CS_PARAM_SADDLE_SOLVER_MUMPS
Definition: cs_param_saddle.h:199
@ CS_PARAM_SADDLE_SOLVER_AFS
Definition: cs_param_saddle.h:194
@ CS_PARAM_SADDLE_SOLVER_UZAWA_CG
Definition: cs_param_saddle.h:202
@ CS_PARAM_SADDLE_SOLVER_GKB
Definition: cs_param_saddle.h:197
@ CS_PARAM_SADDLE_SOLVER_SIMPLE
Definition: cs_param_saddle.h:201
@ CS_PARAM_SADDLE_SOLVER_ALU
Definition: cs_param_saddle.h:193
@ CS_PARAM_SADDLE_SOLVER_FGMRES
Definition: cs_param_saddle.h:195
@ CS_PARAM_SADDLE_SOLVER_MINRES
Definition: cs_param_saddle.h:198
@ CS_PARAM_SADDLE_SOLVER_NOTAY_TRANSFORM
Definition: cs_param_saddle.h:200
@ CS_PARAM_SADDLE_SOLVER_GCR
Definition: cs_param_saddle.h:196
void cs_param_saddle_set_name(const char *name, cs_param_saddle_t *saddlep)
Set the name of the saddle-point system.
Definition: cs_param_saddle.cpp:946
int cs_param_saddle_set_solver(const char *keyval, cs_param_saddle_t *saddlep)
Set the type of solver to apply for this saddle-point system.
Definition: cs_param_saddle.cpp:1164
void cs_param_saddle_set_notay_scaling(cs_param_saddle_t *saddlep, double scaling_coef)
Set the scaling coefficient used in the Notay's transformation devised in "Algebraic multigrid for St...
Definition: cs_param_saddle.cpp:486
void cs_param_saddle_try_init_schur_sles_param(cs_param_saddle_t *saddlep)
Initialize a cs_param_sles_t structure for the Schur approximation nested inside a cs_param_saddle_t ...
Definition: cs_param_saddle.cpp:1437
cs_param_saddle_t * cs_param_saddle_create(void)
Create a cs_param_saddle_t structure No solver is set by default.
Definition: cs_param_saddle.cpp:713
cs_param_saddle_precond_t
Type of preconditioner used to solve a saddle-point system. Up to now, this happens only in two cases...
Definition: cs_param_saddle.h:100
@ CS_PARAM_SADDLE_PRECOND_AFS
Definition: cs_param_saddle.h:103
@ CS_PARAM_SADDLE_PRECOND_NONE
Definition: cs_param_saddle.h:102
@ CS_PARAM_SADDLE_PRECOND_DIAG
Definition: cs_param_saddle.h:104
@ CS_PARAM_SADDLE_N_PRECOND
Definition: cs_param_saddle.h:110
@ CS_PARAM_SADDLE_PRECOND_LOWER
Definition: cs_param_saddle.h:105
@ CS_PARAM_SADDLE_PRECOND_UPPER
Definition: cs_param_saddle.h:107
@ CS_PARAM_SADDLE_PRECOND_UZAWA
Definition: cs_param_saddle.h:108
@ CS_PARAM_SADDLE_PRECOND_SGS
Definition: cs_param_saddle.h:106
cs_param_saddle_schur_approx_t
Strategy to build the Schur complement approximation. This appears in block preconditioning or Uzawa ...
Definition: cs_param_saddle.h:251
@ CS_PARAM_SADDLE_SCHUR_NONE
Definition: cs_param_saddle.h:253
@ CS_PARAM_SADDLE_SCHUR_DIAG_INVERSE
Definition: cs_param_saddle.h:255
@ CS_PARAM_SADDLE_SCHUR_LUMPED_INVERSE
Definition: cs_param_saddle.h:257
@ CS_PARAM_SADDLE_N_SCHUR_APPROX
Definition: cs_param_saddle.h:262
@ CS_PARAM_SADDLE_SCHUR_MASS_SCALED_DIAG_INVERSE
Definition: cs_param_saddle.h:259
@ CS_PARAM_SADDLE_SCHUR_MASS_SCALED_LUMPED_INVERSE
Definition: cs_param_saddle.h:260
@ CS_PARAM_SADDLE_SCHUR_IDENTITY
Definition: cs_param_saddle.h:256
Definition: cs_param_saddle.h:258
cs_param_sles_t * cs_param_saddle_get_init_sles_param(const cs_param_saddle_t *saddlep)
Get the pointer to the set of parameters to handle a SLES. This SLES is associated to the initial sad...
Definition: cs_param_saddle.cpp:867
void cs_param_saddle_free(cs_param_saddle_t **p_saddlep)
Free the structure storing the parameter settings for a saddle-point system.
Definition: cs_param_saddle.cpp:755
cs_param_sles_t * cs_param_saddle_get_xtra_sles_param(const cs_param_saddle_t *saddlep)
Get the pointer to the set of parameters to handle a SLES. This SLES is associated to an extra-operat...
Definition: cs_param_saddle.cpp:813
int cs_param_saddle_set_schur_approx(const char *keyval, cs_param_saddle_t *saddlep)
Set the type of Schur approximation to apply to this saddle-point system.
Definition: cs_param_saddle.cpp:1050
int cs_param_saddle_set_solver_class(const char *keyval, cs_param_saddle_t *saddlep)
Set the class of solver to apply for this saddle-point system.
Definition: cs_param_saddle.cpp:1112
void cs_param_saddle_set_block11_sles_param(cs_param_saddle_t *saddlep, const cs_param_sles_t *block11_slesp)
Assign the cs_param_sles_t structure (shared) related to the (1,1)-block to the structure managing th...
Definition: cs_param_saddle.cpp:969
void cs_param_saddle_log(const cs_param_saddle_t *saddlep)
Log the setup information for the given cs_param_saddle_t structure.
Definition: cs_param_saddle.cpp:1576
void cs_param_saddle_set_restart_range(cs_param_saddle_t *saddlep, int restart_range)
Set the number of iterations to store before starting a Krylov solver.
Definition: cs_param_saddle.cpp:444
void cs_param_saddle_set_simple_relaxation_scaling(cs_param_saddle_t *saddlep, const double scaling_coef)
Set the scaling coefficient used in the AFS/SIMPLE-like method devised in "SIMPLE-like preconditioner...
Definition: cs_param_saddle.cpp:514
Structure and routines handling the SLES ((Sparse Linear Equation Solver) settings stored inside a cs...
cs_param_solver_class_t
Definition: cs_param_types.h:752
Set of parameters to check the convergence (or the divergence) of an iterative process (tolerances or...
Definition: cs_param_types.h:603
Structure storing additional elements associated with the usage of the Augmented Lagrangian Uzawa (AL...
Definition: cs_param_saddle.h:388
cs_param_sles_t * init_sles_param
Definition: cs_param_saddle.h:410
bool dedicated_init_sles
Definition: cs_param_saddle.h:402
double augmentation_scaling
Definition: cs_param_saddle.h:395
Structure storing additional elements associated with the usage of block preconditioners with a Krylo...
Definition: cs_param_saddle.h:421
int n_stored_directions
Definition: cs_param_saddle.h:435
Definition: cs_param_saddle.h:428
cs_param_sles_t * xtra_sles_param
Definition: cs_param_saddle.h:447
Structure storing additional elements associated with the usage of the Golub-Kahan Bidiagonalization ...
Definition: cs_param_saddle.h:458
Definition: cs_param_saddle.h:487
Definition: cs_param_saddle.h:479
Definition: cs_param_saddle.h:465
int truncation_threshold
Definition: cs_param_saddle.h:472
Structure storing additional elements associated with the usage of the Notay's algebraic transformati...
Definition: cs_param_saddle.h:498
double scaling_coef
Definition: cs_param_saddle.h:505
Structure storing additional elements associated with the usage of the Algebraic Fractional Step meth...
Definition: cs_param_saddle.h:554
Definition: cs_param_saddle.h:567
Definition: cs_param_saddle.h:560
Definition: cs_param_saddle.h:579
double scaling_coef
Definition: cs_param_saddle.h:587
Structure storing additional elements associated with the usage of the Uzawa-CG algorithm (an Uzawa a...
Definition: cs_param_saddle.h:517
Definition: cs_param_saddle.h:530
Definition: cs_param_saddle.h:523
Definition: cs_param_saddle.h:542
Structure storing all metadata related to the resolution of a saddle-point linear system....
Definition: cs_param_saddle.h:280
cs_param_convergence_t cvg_param
Definition: cs_param_saddle.h:335
cs_param_saddle_precond_t precond
Definition: cs_param_saddle.h:326
cs_param_sles_t * schur_sles_param
Definition: cs_param_saddle.h:368
cs_param_saddle_solver_t solver
Definition: cs_param_saddle.h:319
const cs_param_sles_t * block11_sles_param
Definition: cs_param_saddle.h:344
int verbosity
Definition: cs_param_saddle.h:287
cs_param_solver_class_t solver_class
Definition: cs_param_saddle.h:310
cs_param_saddle_schur_approx_t schur_approx
Definition: cs_param_saddle.h:361
char * name
Definition: cs_param_saddle.h:295
void * context
Definition: cs_param_saddle.h:374
Definition: cs_param_sles.h:63
