cs_param_saddle_context_simple_t Struct Reference
Structure storing additional elements associated with the usage of the Algebraic Fractional Step methods (AFS) including SIMPLE-like algorithm. More...
#include <cs_param_saddle.h>
+ Collaboration diagram for cs_param_saddle_context_simple_t:
Public Attributes
bool dedicated_init_sles
cs_param_sles_t * init_sles_param
cs_param_sles_t * xtra_sles_param
double scaling_coef
Member Data Documentation
◆ dedicated_init_sles
◆ init_sles_param
init_sles_param
The initial linear system requires a more accurate resolution. Thus, one adds a dedicated cs_param_sles_t structure for this purpose)
◆ scaling_coef
scaling_coef
The scaling_coef used in the lumped inversion if (1,1)-block matrix such as to solve the A.x = 1/scaling_coef. By default the value is 1.0. scaling_coef < 1 corresponds to an under-relaxation on the pressure.
◆ xtra_sles_param
xtra_sles_param
Set of parameters only used in some situations such as the need to solve approximately the A.x = 1 linear system (A is the (1,1)-block matrix). This is a complementary step in the approximation of the Schur complement.
By default, this is a copy of the block11_sles_param with less restrictive convergence criteria
