cs_lagr_prototypes.h File Reference
+ Include dependency graph for cs_lagr_prototypes.h:
void cs_user_lagr_boundary_conditions (const int itypfb[])
 Define particle boundary conditions. More...
void cs_lagr_user_boundary_interaction (cs_lagr_particle_set_t &p_set, cs_lnum_t p_id, cs_lnum_t face_id, const cs_real_t face_norm[3], const cs_real_t c_intersect[3], cs_real_t t_intersect, int b_zone_id, int *event_flag, cs_lagr_tracking_state_t *tracking_state)
 Handling of a particle interaction with a boundary of type CS_LAGR_BC_USER. More...
void cs_user_lagr_model (void)
void cs_user_lagr_ef (cs_real_t dt_p, const cs_lnum_t p_id, const cs_real_t *taup, const cs_real_3_t *tlag, const cs_real_3_t *piil, const cs_real_33_t *bx, const cs_real_t tsfext, const cs_real_3_t gradpr, const cs_real_33_t gradvf, cs_real_t rho_p, cs_real_3_t fextla)
 User definition of an external force field acting on the particles. More...
void cs_user_lagr_extra_operations (const cs_real_t dt[])
 User function (non-mandatory intervention) More...
void cs_user_lagr_imposed_motion (cs_lagr_particle_set_t &p_set, cs_lnum_t p_id, const cs_real_t coords[3], const cs_real_t dt, cs_real_t disp[3])
 Impose the motion of a particle flagged CS_LAGR_PART_IMPOSED_MOTION. More...
void cs_user_lagr_in_force_coords (cs_lagr_particle_set_t &p_set, const cs_lagr_injection_set_t *zis, const cs_lnum_t particle_range[2], const cs_lnum_t particle_face_id[], const cs_real_t visc_length[])
 User modification of newly injected particle location and cell_id. More...
void cs_user_lagr_in (cs_lagr_particle_set_t &p_set, const cs_lagr_injection_set_t *zis, const cs_lnum_t particle_range[2], const cs_lnum_t particle_face_id[], const cs_real_t visc_length[])
 User modification of newly injected particles. More...
void cs_user_lagr_rt (int phase_id, cs_lagr_particle_set_t &p_set, cs_lnum_t p_id, cs_real_t re_p, cs_real_t uvwr, cs_real_t rho_f, cs_real_t rho_p, cs_real_t nu_f, cs_real_t *taup, const cs_real_t dt)
 Modification of the calculation of the particle relaxation time with respect to the chosen formulation for the drag coefficient. More...
void cs_user_lagr_rt_t (cs_lagr_particle_set_t &p_set, cs_lnum_t p_id, cs_real_t re_p, cs_real_t uvwr, cs_real_t rho_f, cs_real_t rho_p, cs_real_t nu_f, cs_real_t cp_f, cs_real_t k_f, cs_real_2_t tempct, const cs_real_t dt)
 Modification of the calculation of the thermal relaxation time of the particles with respect to the chosen formulation of the Nusselt number. More...
void cs_user_lagr_sde (const cs_real_t dt, const cs_lnum_t p_id, const cs_real_t *taup, const cs_real_3_t *tlag, const cs_real_2_t tempct, const int nor)
 User integration of the SDE for the user-defined variables. More...
void cs_user_lagr_volume_conditions (void)
 Define particle volume conditions. More...
void cs_lagr_user_internal_interaction (cs_lagr_particle_set_t &p_set, cs_lnum_t p_id, cs_lnum_t face_id, const cs_nreal_t face_u_norm[3], const cs_real_t c_intersect[3], cs_real_t t_intersect, cs_lagr_tracking_state_t *tracking_state)
 Handling of a particle interaction with a interior face of type CS_LAGR_BC_USER. More...
◆ cs_lagr_user_boundary_interaction()
void cs_lagr_user_boundary_interaction ( cs_lagr_particle_set_t &  p_set,
cs_lnum_t  p_id,
cs_lnum_t  face_id,
int  b_zone_id,
int *  event_flag,
cs_lagr_tracking_state_t *  tracking_state
[in,out]p_setparticle set
[in]p_idparticle id
[in]face_idboundary face id
[in]face_normunit face (or face subdivision) normal
[in]c_intersectcoordinates of intersection with the face
[in]t_intersectrelative distance (in [0, 1]) of the intersection point with the face relative to the initial trajectory segment
[in]b_zone_idboundary zone id of the matching face
[in,out]event_flagevent flag in case events are available
[in,out]tracking_stateparticle tracking state
◆ cs_lagr_user_internal_interaction()
void cs_lagr_user_internal_interaction ( cs_lagr_particle_set_t &  p_set,
cs_lnum_t  p_id,
cs_lnum_t  face_id,
[in,out]p_setreference to particle set
[in]p_idparticle id
[in]face_idinterior face id
[in]face_u_normunit face (or face subdivision) normal
◆ cs_user_lagr_boundary_conditions()
void cs_user_lagr_boundary_conditions ( const int  itypfb[])
This is used for the definition of inlet and other boundaries, based on predefined boundary zones (cs_zone_t).
[in]bc_typetype of the boundary faces
◆ cs_user_lagr_ef()
void cs_user_lagr_ef ( cs_real_t  dt_p,
const cs_real_t *  taup,
const cs_real_3_t *  tlag,
const cs_real_3_t *  piil,
const cs_real_33_t *  bx,
cs_real_t  rho_p,
cs_real_3_t  fextla
It must be prescribed in every cell and be homogeneous to gravity (m/s^2) By default gravity and drag force are the only forces acting on the particles (the gravity components gx gy gz are assigned in the GUI or in cs_user_parameters) Note that taup, tlag, piil and bx are associated to the particle and their value for all phases is provided
[in]dt_ptime step (for the cell)
[in]p_idparticle id
[in]taupparticle relaxation time
[in]tlagrelaxation time for the flow
[in]piilterm in the integration of the sde
[in]bxcharacteristics of the turbulence
[in]tsfextinfos for the return coupling
[in,out]rho_pparticle density
[out]fextlauser external force field (m/s^2)$
◆ cs_user_lagr_extra_operations()
void cs_user_lagr_extra_operations ( const cs_real_t  dt[])
User-defined modifications on the variables at the end of the Lagrangian time step and calculation of user-defined additional statistics on the particles.
◆ cs_user_lagr_imposed_motion()
void cs_user_lagr_imposed_motion ( cs_lagr_particle_set_t &  p_set,
cs_lnum_t  p_id,
const cs_real_t  dt,
cs_real_t  disp[3]
User-defined modifications on the particle position and its velocity.
[in]p_setparticle set
[in]p_idparticle id
[in]coordsold particle coordinates
[in]dttime step (per particle)
[out]dispparticle dispacement
◆ cs_user_lagr_in()
void cs_user_lagr_in ( cs_lagr_particle_set_t &  p_set,
const cs_lagr_injection_set_t *  zis,
This function is called after the initialization of the new particles in order to modify them according to new particle profiles (injection profiles, statistical weights, correction of the diameter if the standard-deviation option is activated); the modification of particles position should preferentially be made in cs_user_lagr_in_force_coords to get an initialization of particle properties coherent with the local fields.
This function is called for each injection zone and class. Particles with ids between pset->n_particles and n_elts are initialized but may be modified by this function.
[in]zisinjection data for this set
[in]particle_rangestart and past-the-end ids of new particles for this zone and class
[in]particle_face_idface ids of new particles if zone is a boundary, NULL otherwise
[in]visc_lengthviscous layer thickness (size: number of mesh boundary faces)
◆ cs_user_lagr_in_force_coords()
void cs_user_lagr_in_force_coords ( cs_lagr_particle_set_t &  p_set,
This function is called before the initialization of the new particles in order to initialize them according to new particle positions, to this aim it is necessary to modify the cell_id associated to the particle accordingly.
◆ cs_user_lagr_model()
void cs_user_lagr_model ( void  )
◆ cs_user_lagr_rt()
void cs_user_lagr_rt ( int  phase_id,
cs_lnum_t  p_id,
cs_real_t  re_p,
cs_real_t  uvwr,
cs_real_t  rho_f,
cs_real_t  rho_p,
cs_real_t  nu_f,
cs_real_t *  taup,
const cs_real_t  dt
This function is called in a loop on the particles, so be careful to avoid too costly operations.
 \f$\tau_c = \frac{m_p{C_p}_p}{PId_p^2h_e}\f$
 \f$\tau_c\f$  : Thermal relaxation time (value to be computed)
 \f$m_p\f$     : Particle mass
 \f${C_p}_p\f$ : Particle specific heat
 \f$d_p\f$     : Particle diameter
 \f$h_e\f$     : Coefficient of thermal exchange
The coefficient of thermal exchange is calculated from a Nusselt number, itself evaluated by a correlation (Ranz-Marshall by default)
\f$\nu = \frac{h_ed_p}{\lambda} = 2 + 0.55{\Re_e}_p^{0.5}P_{rt}^{0.33}\f$
\f$\lambda\f$ : Thermal conductivity of the carrier field
\f${\Re_e}_p\f$     : Particle Reynolds number
$ P_{rt}$ : Prandtl number
◆ cs_user_lagr_rt_t()
void cs_user_lagr_rt_t ( cs_lagr_particle_set_t &  p_set,
cs_lnum_t  p_id,
cs_real_t  re_p,
cs_real_t  uvwr,
cs_real_t  rho_f,
cs_real_t  rho_p,
cs_real_t  nu_f,
cs_real_t  cp_f,
cs_real_t  k_f,
cs_real_2_t  tempct,
const cs_real_t  dt
◆ cs_user_lagr_sde()
void cs_user_lagr_sde ( const cs_real_t  dt,
const int  nor
The variables are constant by default. The SDE must be of the form:
   \frac{dT}{dt}=\frac{T - PIP}{Tca}
T: particle attribute representing the variable Tca: characteristic time for the sde to be prescribed in the array auxl1 PIP: coefficient of the SDE (pseudo RHS) to be prescribed in the array auxl2. If the chosen scheme is first order (nordre=1) then, at the first and only call pip is expressed as a function of the quantities of the previous time step (contained in the particle data). If the chosen scheme is second order (nordre=2) then, at the first call (nor=1) pip is expressed as a function of the quantities of the previous time step, and at the second passage (nor=2) pip is expressed as a function of the quantities of the current time step.
Note that taup, tlag are associated to the particle and their value for all phases is provided
[in]dttime step (per cell)
[in]p_idparticle id
[in]tempctcharacteristic thermal time and implicit source term of return coupling
[in]norcurrent step id (for 2nd order scheme)
◆ cs_user_lagr_volume_conditions()
void cs_user_lagr_volume_conditions ( void  )
This is used definition of for injection based on predefined volume zones (cs_zone_t).
