cs_domain.h File Reference
+ Include dependency graph for cs_domain.h:
Classes
struct  cs_domain_cdo_context_t
 High-level metadata for handling CDO/HHO schemes. More...
struct  cs_domain_t
 Structure storing the main features of the computational domain and pointers to the main geometrical structures. More...
Enumerations
enum  cs_domain_stage_t {
  CS_DOMAIN_STAGE_BEFORE_STEADY_COMPUTATION , CS_DOMAIN_STAGE_BEFORE_TIME_LOOP , CS_DOMAIN_STAGE_TIME_STEP_BEGIN , CS_DOMAIN_STAGE_TIME_STEP_SUB_ITERATION ,
  CS_DOMAIN_STAGE_TIME_STEP_END , CS_DOMAIN_STAGE_AFTER_TIME_LOOP , CS_DOMAIN_N_STAGES
 Indicator describing at which stage is the computation. More...
static void cs_domain_increment_time_step (cs_domain_t *domain)
 Update the time step after one temporal iteration. More...
cs_domain_t * cs_domain_create (void)
 Create and initialize by default a cs_domain_t structure. More...
void cs_domain_free (cs_domain_t **p_domain)
 Free a cs_domain_t structure. More...
void cs_domain_set_cdo_mode (cs_domain_t *domain, cs_param_cdo_mode_t mode)
 Set the global variable storing the mode of activation to apply to CDO/HHO schemes. Deprecated way to set the CDO mode. More...
int cs_domain_get_cdo_mode (const cs_domain_t *domain)
 Get the mode of activation for the CDO/HHO schemes. Deprecated way to retrieve the CDO mode. More...
void cs_domain_set_output_param (cs_domain_t *domain, int restart_nt, int log_nt, int verbosity)
 Set parameters related to the way output/logging is done. More...
void cs_domain_set_stage (cs_domain_t *domain, cs_domain_stage_t stage)
 Set the computation stage in the domain structure. More...
cs_domain_stage_t cs_domain_get_stage (const cs_domain_t *domain)
 Retrieve the computation stage from the domain structure. More...
bool cs_domain_needs_iteration (cs_domain_t *domain)
 Check if one needs to continue iterations in time. More...
bool cs_domain_needs_log (const cs_domain_t *domain)
 Check if an output is requested according to the domain setting. More...
bool cs_domain_needs_extra_op (cs_domain_t *domain)
 Check if one has to perform extra-operations. More...
void cs_domain_increment_time (cs_domain_t *domain)
 Update time step after one temporal iteration. More...
cs_domain_t * cs_glob_domain
◆ cs_domain_stage_t
This indicator is useful to know at which stage the computation is when a user-defined function is called (for instance cs_user_physical_properties). Up to now, this information is only used in the CDO module.
Enumerator
The computation run is at a stage before computing the steady-state equations
The computation run is at a stage before starting the time loop and after solving all steady-state equations
The computation run is inside the time loop and at the beginning of a time step
The computation run is inside the time loop and inside a sub-iteration process
The computation run is inside the time loop and at the end of an iteration but before the computation of user-defined equation (not triggered by a user)
The computation run is at a stage after the time loop (finalize stage). This stage is useful to free memory allocated during the computation.
CS_DOMAIN_N_STAGES
◆ cs_domain_create()
cs_domain_t * cs_domain_create ( void  )
a pointer to a cs_domain_t structure
◆ cs_domain_free()
void cs_domain_free ( cs_domain_t **  p_domain)
[in,out]p_domainpointer of pointer to a cs_domain_t structure
◆ cs_domain_get_cdo_mode()
int cs_domain_get_cdo_mode ( const cs_domain_t *  domain)
[in]domainpointer to a cs_domain_t structure
the mode of activation for the CDO/HHO module
◆ cs_domain_get_stage()
cs_domain_stage_t cs_domain_get_stage ( const cs_domain_t *  domain)
the current stage in the computation run
◆ cs_domain_increment_time()
void cs_domain_increment_time ( cs_domain_t *  domain)
◆ cs_domain_increment_time_step()
static void cs_domain_increment_time_step ( cs_domain_t *  domain)
inlinestatic
◆ cs_domain_needs_extra_op()
bool cs_domain_needs_extra_op ( cs_domain_t *  domain)
true or false
◆ cs_domain_needs_iteration()
bool cs_domain_needs_iteration ( cs_domain_t *  domain)
true or false
◆ cs_domain_needs_log()
bool cs_domain_needs_log ( const cs_domain_t *  domain)
true or false
◆ cs_domain_set_cdo_mode()
void cs_domain_set_cdo_mode ( cs_domain_t *  domain,
[in]modetype of activation for the CDO/HHO module
◆ cs_domain_set_output_param()
void cs_domain_set_output_param ( cs_domain_t *  domain,
int  restart_nt,
int  log_nt,
int  verbosity
[in]restart_ntfrequency for the restart process
[in]log_ntoutput frequency into the log (> 0: constant with the given frequency, < 0: automatic with log_nt first iterations detailed)
[in]verbositylevel of information displayed
[in]log_ntoutput frequency into the log (> 0: constant with the given frequency, < 0: automatic with log_nt first iterations detailed, 0: do nothing)
◆ cs_domain_set_stage()
void cs_domain_set_stage ( cs_domain_t *  domain,
[in]stagestage in the computation run
◆ cs_glob_domain
cs_domain_t* cs_glob_domain
extern
