cs_lagr_orientation.cpp File Reference
#include "bft/bft_printf.h"
#include "bft/bft_error.h"
#include "base/cs_base.h"
#include "base/cs_field.h"
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "mesh/cs_mesh.h"
#include "base/cs_random.h"
#include "lagr/cs_lagr.h"
#include "lagr/cs_lagr_particle.h"
#include "lagr/cs_lagr_event.h"
#include "lagr/cs_lagr_orientation.h"
+ Include dependency graph for cs_lagr_orientation.cpp:
static void _mean_stretching_phase_spheroid (const cs_real_t dtp, cs_real_t orientation[3], const cs_real_t Lambda, const cs_real_t beta, const cs_real_t gradvf_sym[3][3])
 Treatment of spheroid stretching by symetric part of the mean velocity gradient. More...
static void _mean_rotation_phase_spheroid (const cs_real_t dtp, cs_real_t orientation[3], const cs_real_t gradvf_ant[3][3])
 Treatment of spheroid rotation increment by antisymetric mean velocity gradient. More...
static void _bm_stretching_phase_spheroid (const cs_real_t dtp, const cs_real_t d_plus, cs_real_t orientation[3], const cs_real_t Lambda, const cs_real_9_t brown)
 Treatment of spheroid stretching by Brownian effect. More...
static void _bm_rotation_phase_spheroid_by_quaternion (const cs_real_t dtp, const cs_real_t d_minus, cs_real_t orient_loc[3], cs_real_t quater_loc[4], const cs_real_9_t brown)
 Treatment of spheroid rotation by Brownian on the sphere using quaternions. More...
void cs_lagr_orientation_dyn_spheroids (cs_lnum_t p_id, int iprev, const cs_real_t dt_part, const cs_real_t gradvf[][3][3])
 Integration of the equations of motion for particle orientation: More...
void cs_lagr_orientation_dyn_jeffery (cs_lnum_t p_id, int iprev, cs_real_t dt_part, const cs_real_t gradvf[][3][3])
 Integration of the Jeffey equations in DNS mode. More...
◆ _bm_rotation_phase_spheroid_by_quaternion()
static void _bm_rotation_phase_spheroid_by_quaternion ( const cs_real_t  dtp,
static
Principle: Use of quaternions to get the rotation angle
[in]dtptime step
[in]d_minusreduced parameter for the (isotropic) fluctuation tensor
[in]orientationspheroid orientation (vector)
[in]brownnormal random number (9 values by particles)
◆ _bm_stretching_phase_spheroid()
static void _bm_stretching_phase_spheroid ( const cs_real_t  dtp,
static
Principle: Euler scheme
[in]dtptime step
[in]d_plusreduced parameter for the (isotropic) fluctuation tensor
[in]Lambdaspheroid shape parameter
◆ _mean_rotation_phase_spheroid()
static void _mean_rotation_phase_spheroid ( const cs_real_t  dtp,
static
Principle: exact matrix rotation (Rodrigues' formula)
TODO: use directly the antisymetric mean velocity gradient matrix Omega
[in]dtptime step
[in]gradvf_antantisymetric part of the fluid velocity gradient (tensor)
◆ _mean_stretching_phase_spheroid()
static void _mean_stretching_phase_spheroid ( const cs_real_t  dtp,
static
Principle: exact exponential scheme
[in]dtptime step
[in]betacoefficient to be added to diagonal elements (if needed)
[in]gradvf_symsymetric part of the fluid velocity gradient (tensor)
◆ cs_lagr_orientation_dyn_jeffery()
void cs_lagr_orientation_dyn_jeffery ( cs_lnum_t  p_id,
int  iprev,
cs_real_t  dt_part,
[in]p_idparticle index
[in]iprevtime step indicator for fields 0: use fields at current time step 1: use fields at previous time step
[in]dt_partintegration time step associated to the particle
[in]gradvffluid velocity gradient
◆ cs_lagr_orientation_dyn_spheroids()
void cs_lagr_orientation_dyn_spheroids ( cs_lnum_t  p_id,
int  iprev,
Details in publication by M. Bossy and L. Campana (INRIA)
