cs_lagr_fragmentation.cpp File Reference
#include <float.h>
#include "bft/bft_printf.h"
#include "base/cs_base.h"
#include "base/cs_field.h"
#include "base/cs_math.h"
#include "base/cs_mem.h"
#include "base/cs_parall.h"
#include "lagr/cs_lagr.h"
#include "lagr/cs_lagr_agglo.h"
#include "lagr/cs_lagr_clogging.h"
#include "lagr/cs_lagr_injection.h"
#include "lagr/cs_lagr_particle.h"
#include "lagr/cs_lagr_stat.h"
#include "base/cs_random.h"
#include "lagr/cs_lagr_fragmentation.h"
+ Include dependency graph for cs_lagr_fragmentation.cpp:
cs_lnum_t cs_lagr_fragmentation (cs_real_t dt, cs_real_t minimum_particle_diam, cs_lnum_t main_start, cs_lnum_t main_end, cs_lnum_t agglo_start, cs_lnum_t agglo_end)
 Particle fragmentation algorithm. More...
◆ cs_lagr_fragmentation()
cs_lnum_t cs_lagr_fragmentation ( cs_real_t  dt,
cs_lnum_t  main_end,
cs_lnum_t  agglo_end
Parcels represent physical particles with similar properties (size). The number of physical particles in a parcel is represented by the statistical weight.
For each parcel, the number of fragmentation events is generated with a Poisson distribution that depends on the fragmentation kernel.
Working hypotheses: 1) Discrete diameters
  • Minimal particle size , called a monomere (unbreakable particle) 2) Fragmentation is binary
  • Equally sized fragments (N0/2, or (N0+-1)/2) 3) Fragmentation is treated after agglomeration
Warning: particle indices are not necessarily contiguous (due to agglomeration occuring before).
Two contiguous groups: particles present before agglomeration newly created particles (due to agglomeration)
[in]dttime step
[in]minimum_particle_diamminumum diameter (monomere diameter)
[in]main_startindex of the first particle in cell present before the agglomeration
[in]main_endindex after the last particle in cell, present before the agglomeration
[in]agglo_startindex of the first particle in cell, created by the agglomeration
[in]agglo_endindex after the last particle in cell, created by the agglomeration
modified list of particles containing newly created parcels at the end
