cs_lagr_agglo.h
1#ifndef CS_LAGR_AGGLO_H
2#define CS_LAGR_AGGLO_H
5 * Agglomeration modeling.
30#include "base/cs_defs.h"
33 * Standard C library headers
37 * Local headers
38 *----------------------------------------------------------------------------*/
45 * Public function prototypes
48/*----------------------------------------------------------------------------*/
59/*----------------------------------------------------------------------------*/
60
61void
63 cs_lnum_2_t arr2[],
64 cs_lnum_t n1,
65 cs_lnum_t n2,
66 cs_lnum_2_t arr3[]);
67
68/*----------------------------------------------------------------------------*/
102/*----------------------------------------------------------------------------*/
103
107 cs_real_t minimum_particle_diam,
108 cs_lnum_t start_particle,
109 cs_lnum_t end_particle);
110
111/*----------------------------------------------------------------------------*/
112
114
115#endif /* CS_LAGR_AGGLO_H*/
Definition: cs_defs.h:528
Definition: cs_defs.h:332
cs_lnum_t cs_lnum_2_t[2]
Definition: cs_defs.h:342
Definition: cs_defs.h:529
Definition: cs_defs.h:325
@ dt
Definition: cs_field_pointer.h:61
void cs_lagr_agglo_merge_arrays(cs_lnum_2_t arr1[], cs_lnum_2_t arr2[], cs_lnum_t n1, cs_lnum_t n2, cs_lnum_2_t arr3[])
Merge two sorted arrays in a third sorted array.
Definition: cs_lagr_agglo.cpp:307
cs_lnum_t cs_lagr_agglomeration(cs_lnum_t cell_id, cs_real_t dt, cs_real_t minimum_particle_diam, cs_lnum_t start_particle, cs_lnum_t end_particle)
Agglomeration algorithm based on algorithms used in rare gas modelling.
Definition: cs_lagr_agglo.cpp:384
