57typedef struct _cs_hho_vecteq_t cs_hho_vecteq_t;
266 void *scheme_context);
282 void *scheme_context);
time step descriptor
Definition: cs_time_step.h:60
Definition: cs_defs.h:332
unsigned short int cs_flag_t
Definition: cs_defs.h:334
void cs_hho_vecteq_update_field(const cs_real_t *solu, const cs_real_t *rhs, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data, cs_real_t *field_val)
Store solution(s) of the linear system into a field structure Update extra-field values required for ...
Definition: cs_hho_vecteq.cpp:1389
cs_real_t * cs_hho_vecteq_get_face_values(void *data, bool previous)
Get the computed values at faces (DoF used in the linear system are located at primal faces)
Definition: cs_hho_vecteq.cpp:1516
void cs_hho_vecteq_read_restart(cs_restart_t *restart, const char *eqname, void *scheme_context)
Definition: cs_hho_vecteq.cpp:1569
void cs_hho_vecteq_get(cs_cell_sys_t **csys, cs_cell_builder_t **cb, cs_hho_builder_t **hhob)
Definition: cs_hho_vecteq.cpp:686
void * cs_hho_vecteq_free_context(void *data)
Destroy a cs_hho_vecteq_t structure.
Definition: cs_hho_vecteq.cpp:924
cs_real_t * cs_hho_vecteq_get_cell_values(void *data, bool previous)
Get the computed values at cells (DoF used in the linear system are located at primal faces)
Definition: cs_hho_vecteq.cpp:1543
void cs_hho_vecteq_init_values(cs_real_t t_eval, const int field_id, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Set the initial values of the variable field taking into account the boundary conditions....
Definition: cs_hho_vecteq.cpp:962
void cs_hho_vecteq_write_restart(cs_restart_t *restart, const char *eqname, void *scheme_context)
Definition: cs_hho_vecteq.cpp:1652
void cs_hho_vecteq_extra_post(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Definition: cs_hho_vecteq.cpp:1713
void cs_hho_vecteq_init_sharing(cs_flag_t scheme_flag, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step)
Allocate work buffer and general structures related to HHO schemes Set shared pointers.
Definition: cs_hho_vecteq.cpp:584
void * cs_hho_vecteq_init_context(cs_equation_param_t *eqp, int var_id, int bflux_id, cs_equation_builder_t *eqb)
Initialize a cs_hho_vecteq_t structure storing data useful for managing such a scheme.
Definition: cs_hho_vecteq.cpp:743
void cs_hho_vecteq_compute_source(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data)
Compute the contributions of source terms (store inside builder)
Definition: cs_hho_vecteq.cpp:1008
void cs_hho_vecteq_finalize_sharing(void)
Free buffers and generic structures related to HHO schemes.
Definition: cs_hho_vecteq.cpp:704
void cs_hho_vecteq_build_system(const cs_mesh_t *mesh, const cs_real_t *field_val, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Build the linear system arising from a scalar convection/diffusion equation with a HHO scheme....
Definition: cs_hho_vecteq.cpp:1100
Definition: cs_restart.h:91
double precision, dimension(:,:), pointer solu
Definition: atincl.f90:260
Definition: cs_cdo_connect.h:57
Definition: cs_cdo_quantities.h:142
Definition: cs_cdo_local.h:56
Definition: cs_cdo_local.h:163
Definition: cs_hho_builder.h:50
