1#ifndef CS_GWF_HYDRAULIC_MODEL_H
2#define CS_GWF_HYDRAULIC_MODEL_H
Definition: cs_field.h:275
Definition: cs_defs.h:332
unsigned short int cs_flag_t
Definition: cs_defs.h:334
void() cs_gwf_darcy_update_t(const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *cdoq, cs_real_t t_eval, bool cur2prev, cs_gwf_darcy_flux_t *darcy)
Update the advection field/arrays related to the Darcy flux. The context associated to a cs_gwf_darcy...
Definition: cs_gwf_hydraulic_model.h:62
cs_gwf_tpf_approx_type_t
Type of approximation used for the computation of unsteady or diffusion properties.
Definition: cs_gwf_hydraulic_model.h:288
@ CS_GWF_TPF_APPROX_PC_CELL_VERTEX_AVERAGE
Definition: cs_gwf_hydraulic_model.h:291
@ CS_GWF_TPF_N_APPROX
Definition: cs_gwf_hydraulic_model.h:297
@ CS_GWF_TPF_APPROX_PC_VERTEX_AVERAGE
Definition: cs_gwf_hydraulic_model.h:293
@ CS_GWF_TPF_APPROX_VERTEX_SUBCELL
Definition: cs_gwf_hydraulic_model.h:295
@ CS_GWF_TPF_APPROX_PC_CELL_AVERAGE
Definition: cs_gwf_hydraulic_model.h:290
@ CS_GWF_TPF_APPROX_PC_EDGE_AVERAGE
Definition: cs_gwf_hydraulic_model.h:292
cs_gwf_tpf_solver_type_t
Type of solver considered for a two-phase flow model.
Definition: cs_gwf_hydraulic_model.h:273
@ CS_GWF_TPF_SOLVER_PLPC_COUPLED
Definition: cs_gwf_hydraulic_model.h:275
@ CS_GWF_TPF_SOLVER_PLPC_COUPLED_INCR
Definition: cs_gwf_hydraulic_model.h:276
@ CS_GWF_TPF_N_SOLVERS
Definition: cs_gwf_hydraulic_model.h:278
cs_gwf_model_type_t
Definition: cs_gwf_param.h:123
Structure and routines handling the SLES ((Sparse Linear Equation Solver) settings stored inside a cs...
cs_param_nl_algo_t
Class of non-linear iterative algorithm.
Definition: cs_param_types.h:715
Definition: cs_gwf_priv.h:51
Definition: cs_cdo_connect.h:57
Definition: cs_cdo_quantities.h:142
Main structure to handle a set of coupled equations.
Definition: cs_equation_system.h:121
Structure to handle a Darcy flux.
Structure to handle the modelling of a single-phase flows in a porous media considered as saturated.
Definition: cs_gwf_hydraulic_model.h:81
cs_gwf_darcy_flux_t * darcy
Definition: cs_gwf_hydraulic_model.h:107
cs_equation_t * richards
Definition: cs_gwf_hydraulic_model.h:94
cs_property_t * moisture_content
Definition: cs_gwf_hydraulic_model.h:119
cs_field_t * pressure_head
Definition: cs_gwf_hydraulic_model.h:135
Main set of parameters/structures to manage the groundwater flow (GWF) module. This is an explicit de...
Definition: cs_gwf_hydraulic_model.h:640
cs_gwf_model_type_t model
Definition: cs_gwf_hydraulic_model.h:663
cs_flag_t flag
Definition: cs_gwf_hydraulic_model.h:664
cs_flag_t post_flag
Definition: cs_gwf_hydraulic_model.h:665
int verbosity
Definition: cs_gwf_hydraulic_model.h:662
cs_property_t * soil_porosity
Definition: cs_gwf_hydraulic_model.h:685
void * model_context
Definition: cs_gwf_hydraulic_model.h:699
cs_property_t * abs_permeability
Definition: cs_gwf_hydraulic_model.h:686
Structure to handle the modelling of miscible or immiscible two-phase flows in a porous media.
Definition: cs_gwf_hydraulic_model.h:328
double cell_weight
weight associated to the cell value w.r.t. to the values at vertices when a CS_GWF_TPF_APPROX_PC_CELL...
Definition: cs_gwf_hydraulic_model.h:616
cs_real_t henry_constant
Definition: cs_gwf_hydraulic_model.h:566
cs_real_t l_diffusivity_h
Definition: cs_gwf_hydraulic_model.h:563
cs_real_t h_molar_mass
Definition: cs_gwf_hydraulic_model.h:564
cs_property_t * diff_hl_pty
Definition: cs_gwf_hydraulic_model.h:452
cs_property_t * time_hc_pty
Definition: cs_gwf_hydraulic_model.h:448
cs_property_t * time_hl_pty
Definition: cs_gwf_hydraulic_model.h:451
cs_field_t * c_pressure
Definition: cs_gwf_hydraulic_model.h:491
cs_property_t * diff_wl_pty
Definition: cs_gwf_hydraulic_model.h:446
cs_param_nl_algo_t nl_algo_type
Definition: cs_gwf_hydraulic_model.h:619
cs_equation_param_t * b01_w_eqp
Definition: cs_gwf_hydraulic_model.h:358
cs_iter_algo_param_aac_t anderson_param
Definition: cs_gwf_hydraulic_model.h:622
cs_field_t * l_saturation
Definition: cs_gwf_hydraulic_model.h:494
cs_gwf_tpf_solver_type_t solver_type
Type of solver considered to solve the system of equations (choice of main unknowns and strategy of r...
Definition: cs_gwf_hydraulic_model.h:613
cs_real_t * srct_h_array
Definition: cs_gwf_hydraulic_model.h:518
double upwind_weight
weight associated to the upwind value w.r.t. to the centered value There is no effect when CS_GWF_TPF...
Definition: cs_gwf_hydraulic_model.h:617
cs_real_t l_mass_density
Definition: cs_gwf_hydraulic_model.h:560
cs_property_t * time_wc_pty
Definition: cs_gwf_hydraulic_model.h:445
int nl_algo_verbosity
Definition: cs_gwf_hydraulic_model.h:620
cs_equation_t * w_eq
Definition: cs_gwf_hydraulic_model.h:343
cs_property_t * lsat_pty
Definition: cs_gwf_hydraulic_model.h:412
cs_real_t ref_temperature
Definition: cs_gwf_hydraulic_model.h:565
cs_gwf_darcy_flux_t * g_darcy
Definition: cs_gwf_hydraulic_model.h:389
cs_equation_param_t * b10_h_eqp
Definition: cs_gwf_hydraulic_model.h:365
cs_real_t g_viscosity
Definition: cs_gwf_hydraulic_model.h:562
cs_field_t * g_pressure
Definition: cs_gwf_hydraulic_model.h:493
cs_real_t * srct_w_array
Definition: cs_gwf_hydraulic_model.h:517
cs_field_t * g_rho_h
Definition: cs_gwf_hydraulic_model.h:496
bool enforce_pg_positivity
Apply a rescaling on the gas pressure to avoid a negative value.
Definition: cs_gwf_hydraulic_model.h:614
cs_field_t * l_rho_h
Definition: cs_gwf_hydraulic_model.h:495
cs_property_t * krl_pty
Definition: cs_gwf_hydraulic_model.h:410
cs_gwf_darcy_flux_t * l_darcy
Definition: cs_gwf_hydraulic_model.h:388
cs_equation_system_t * system
Definition: cs_gwf_hydraulic_model.h:372
cs_property_t * krg_pty
Definition: cs_gwf_hydraulic_model.h:411
cs_iter_algo_t * nl_algo
Definition: cs_gwf_hydraulic_model.h:624
cs_param_convergence_t nl_cvg_param
Definition: cs_gwf_hydraulic_model.h:621
bool is_miscible
Definition: cs_gwf_hydraulic_model.h:558
cs_real_t * lsat_pre_array
Definition: cs_gwf_hydraulic_model.h:519
cs_gwf_tpf_approx_type_t approx_type
type of approximation used for the computation of diffusion, unsteady coefficients
Definition: cs_gwf_hydraulic_model.h:615
cs_property_t * lcap_pty
Definition: cs_gwf_hydraulic_model.h:413
cs_equation_t * h_eq
Definition: cs_gwf_hydraulic_model.h:351
cs_field_t * l_pressure
Definition: cs_gwf_hydraulic_model.h:492
cs_real_t l_viscosity
Definition: cs_gwf_hydraulic_model.h:561
cs_property_t * diff_hc_pty
Definition: cs_gwf_hydraulic_model.h:449
cs_property_t * diff_g_pty
Definition: cs_gwf_hydraulic_model.h:454
Structure to handle the modelling of a single-phase flows in a porous media considered as saturated o...
Definition: cs_gwf_hydraulic_model.h:155
Definition: cs_gwf_hydraulic_model.h:180
cs_field_t * moisture_field
Definition: cs_gwf_hydraulic_model.h:237
Definition: cs_gwf_hydraulic_model.h:167
cs_property_t * soil_capacity
Definition: cs_gwf_hydraulic_model.h:202
cs_real_t * head_in_law
Definition: cs_gwf_hydraulic_model.h:241
Definition: cs_gwf_hydraulic_model.h:201
Definition: cs_gwf_hydraulic_model.h:239
cs_field_t * capacity_field
Definition: cs_gwf_hydraulic_model.h:238
cs_field_t * permeability_field
Definition: cs_gwf_hydraulic_model.h:236
cs_property_t * permeability
Definition: cs_gwf_hydraulic_model.h:200
Structure storing all the parameters to drive the algorithm called Anderson acceleration.
Definition: cs_iter_algo.h:134
Definition: cs_iter_algo.h:285
Set of parameters to check the convergence (or the divergence) of an iterative process (tolerances or...
Definition: cs_param_types.h:603
