cs_macfb_builder_t Struct Reference
#include <cs_macfb_builder.h>
+ Collaboration diagram for cs_macfb_builder_t:
Public Attributes
cs_lnum_t c_id
short int n_dofs
short int n_max_dofs
cs_lnum_t dof_ids [30]
short int n_fc
cs_lnum_t f_ids [30]
cs_flag_cartesian_axis_t f_axis [30]
short int f_sgn_axis [6]
cs_real_t f_vol_cv [6]
cs_real_t f_h_cv [6]
short int f_opp_idx [6]
short int f2f_idx [6][4]
cs_lnum_t f2f_ids [6][4]
short int f2fo_idx [6][4][2]
cs_real_t f2f_h [6][4]
cs_real_t f2f_surf_cv_c [6][4]
cs_lnum_t f2e_ids [6][4]
cs_real_t dir_values [6][4]
Member Data Documentation
◆ c_id
cs_lnum_t c_id
cell id
◆ dir_values
cs_real_t dir_values[6][4]
dirichlet values at edges
◆ dof_ids
cs_lnum_t dof_ids[30]
face DoF ids
◆ f2e_ids
cs_lnum_t f2e_ids[6][4]
cellwise face->edges ids, same order as f2f
◆ f2f_h
cs_real_t f2f_h[6][4]
distance beetwen barycenter of each face->face 4 entries by face
◆ f2f_ids
cs_lnum_t f2f_ids[6][4]
cellwise face->face ids with same direction and sharing an edge with the current face Negative index means to that is not a face 4 entries by face
◆ f2f_idx
short int f2f_idx[6][4]
cellwise face->face index with same direction and sharing an edge with the current face Negative index means to skip entry 4 entries by face
◆ f2f_surf_cv_c
cs_real_t f2f_surf_cv_c[6][4]
surface of each face of the controle volume face->face (restricted to the cell)
◆ f2fo_idx
short int f2fo_idx[6][4][2]
cellwise face->face index with orthogonal direction and sharing an edge with the current face Negative index means to skip entry 8 = (4*2) entries by face
◆ f_axis
axis of local faces
◆ f_h_cv
cs_real_t f_h_cv[6]
normal length of the control volume for a face
◆ f_ids
cs_lnum_t f_ids[30]
face ids on this rank
◆ f_opp_idx
short int f_opp_idx[6]
opposite face index to the face inside the cell
◆ f_sgn_axis
short int f_sgn_axis[6]
axis incidence number between f and c
◆ f_vol_cv
cs_real_t f_vol_cv[6]
volume of the control volume for a face
◆ n_dofs
short int n_dofs
number of dofs in a cell
◆ n_fc
short int n_fc
number of faces in a cell (inner and outer) > 6
◆ n_max_dofs
maximum number of dofs in a cell
