cs_domain_op.cpp File Reference
#include <cassert>
#include <cstring>
#include "base/cs_mem.h"
#include "base/cs_array_reduce.h"
#include "base/cs_dispatch.h"
#include "base/cs_log.h"
#include "base/cs_log_iteration.h"
#include "base/cs_parall.h"
#include "base/cs_post.h"
#include "base/cs_restart.h"
#include "base/cs_restart_default.h"
#include "cdo/cs_advection_field.h"
#include "cdo/cs_cdo_quantities.h"
#include "cdo/cs_equation.h"
#include "cdo/cs_equation_param.h"
#include "cdo/cs_maxwell.h"
#include "cdo/cs_navsto_system.h"
#include "cdo/cs_property.h"
#include "cdo/cs_solidification.h"
#include "cdo/cs_walldistance.h"
#include "gwf/cs_gwf.h"
#include "cdo/cs_domain_op.h"
+ Include dependency graph for cs_domain_op.cpp:
static bool _needs_adimensional_numbers (void)
 Check if one needs to compute at least one adimensional number. More...
static void _analyze_cell_array (const cs_cdo_quantities_t *cdoq, const char basename[], const cs_real_t array[])
 Compute very simple statistic for an array with values located at cells (scalar-valued) More...
static void _post_courant_number (const cs_adv_field_t *adv, const cs_cdo_quantities_t *cdoq, const cs_time_step_t *time_step)
 Predefined Courant number post-processing for advection fields. More...
static void _post_peclet_number (const cs_equation_t *eq, const cs_cdo_quantities_t *cdoq, const cs_time_step_t *time_step)
 Predefined Peclet number post-processing for an equation. More...
static void _post_fourier_number (const cs_property_t *pty, const cs_cdo_quantities_t *cdoq, const cs_time_step_t *time_step)
 Predefined Fourier number post-processing for a property. More...
static void _domain_post (void *input, int mesh_id, int cat_id, int ent_flag[5], cs_lnum_t n_cells, cs_lnum_t n_i_faces, cs_lnum_t n_b_faces, const cs_lnum_t cell_ids[], const cs_lnum_t i_face_ids[], const cs_lnum_t b_face_ids[], const cs_time_step_t *time_step)
 Predefined post-processing output for the computational domain The prototype of this function is fixed since it is a function pointer defined in cs_post.h (cs_post_time_mesh_dep_output_t) More...
void cs_domain_add_extra_op_time_control (cs_domain_t *domain, cs_time_control_t *tc)
 Add a time control dedicated to the extra-operations. The lifecycle of the time control is now managed by the domain structure. More...
void cs_domain_post_init (cs_domain_t *domain)
 Initialize the generic post-processing related to a domain. More...
void cs_domain_extra_op (cs_domain_t *domain)
 Extra-operations of the computational domain after a resolution. Mostly used inside CDO schemes User-defined extra-operations are also called inside this function. More...
void cs_domain_read_restart (cs_domain_t *domain)
 Read a restart file for the CDO/HHO module. More...
void cs_domain_write_restart (const cs_domain_t *domain)
 Write a restart file for the CDO/HHO module. More...
◆ _analyze_cell_array()
static void _analyze_cell_array ( const cs_cdo_quantities_t *  cdoq,
static
[in]cdoqpointer to a cs_cdo_quantities_t struct.
[in]basenamelabel for output in the log
[in]arraypointer to the array to analyze
◆ _domain_post()
static void _domain_post ( void *  input,
int  mesh_id,
int  cat_id,
int  ent_flag[5],
cs_lnum_t  n_cells,
static
[in,out]inputpointer to a optional structure (here a cs_gwf_t structure)
[in]mesh_idid of the output mesh for the current call
[in]cat_idcategory id of the output mesh for this call
[in]ent_flagindicate global presence of cells (ent_flag[0]), interior faces (ent_flag[1]), boundary faces (ent_flag[2]), particles (ent_flag[3]) or probes (ent_flag[4])
[in]n_cellslocal number of cells of post_mesh
[in]n_i_faceslocal number of interior faces of post_mesh
[in]n_b_faceslocal number of boundary faces of post_mesh
[in]cell_idslist of cells (0 to n-1)
[in]i_face_idslist of interior faces (0 to n-1)
[in]b_face_idslist of boundary faces (0 to n-1)
[in]time_steppointer to a cs_time_step_t struct.
◆ _needs_adimensional_numbers()
static bool _needs_adimensional_numbers ( void  )
static
◆ _post_courant_number()
static void _post_courant_number ( const cs_adv_field_t *  adv,
static
[in]advpointer to a cs_adv_field_t structure
◆ _post_fourier_number()
static void _post_fourier_number ( const cs_property_t *  pty,
static
[in]ptypointer to a cs_property_t structure
◆ _post_peclet_number()
static void _post_peclet_number ( const cs_equation_t *  eq,
static
[in]eqpointer to a cs_equation_t structure
◆ cs_domain_add_extra_op_time_control()
void cs_domain_add_extra_op_time_control ( cs_domain_t *  domain,
cs_time_control_t *  tc
[in]tcpointer to a time control structure
◆ cs_domain_extra_op()
void cs_domain_extra_op ( cs_domain_t *  domain)
◆ cs_domain_post_init()
void cs_domain_post_init ( cs_domain_t *  domain)
[in]domainpointer to a cs_domain_t structure
◆ cs_domain_read_restart()
void cs_domain_read_restart ( cs_domain_t *  domain)
◆ cs_domain_write_restart()
void cs_domain_write_restart ( const cs_domain_t *  domain)
