cs_cdofb_scaleq.h File Reference
+ Include dependency graph for cs_cdofb_scaleq.h:
bool cs_cdofb_scaleq_is_initialized (void)
 Check if the generic structures for building a CDO-Fb scheme are allocated. More...
void cs_cdofb_scaleq_init_sharing (const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step)
 Allocate work buffer and general structures related to CDO scalar-valued face-based schemes. Set shared pointers from the main domain members. More...
void cs_cdofb_scaleq_get (cs_cell_sys_t **csys, cs_cell_builder_t **cb)
void cs_cdofb_scaleq_finalize_sharing (void)
 Free work buffer and general structure related to CDO face-based schemes. More...
void * cs_cdofb_scaleq_init_context (cs_equation_param_t *eqp, int var_id, int bflux_id, cs_equation_builder_t *eqb)
 Initialize a cs_cdofb_scaleq_t structure storing data useful for building and managing such a scheme. More...
void * cs_cdofb_scaleq_free_context (void *data)
 Destroy a cs_cdofb_scaleq_t structure. More...
void cs_cdofb_scaleq_init_values (cs_real_t t_eval, const int field_id, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
 Set the initial values of the variable field taking into account the boundary conditions. Case of scalar-valued CDO-Fb schemes. More...
void cs_cdofb_scaleq_interpolate (const cs_mesh_t *mesh, const cs_real_t *cell_values, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
 Build and solve the linear system arising from a scalar steady-state convection/diffusion/reaction equation with a CDO-Fb scheme Use for interpolation purpose from cell values to face values. One works cellwise and then process to the assembly. More...
void cs_cdofb_scaleq_solve_steady_state (bool cur2prev, const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
 Build and solve the linear system arising from a scalar steady-state convection/diffusion/reaction equation with a CDO-Fb scheme One works cellwise and then process to the assembly. More...
void cs_cdofb_scaleq_solve_implicit (bool cur2prev, const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
 Build and solve the linear system arising from a scalar convection/diffusion/reaction equation with a CDO-Fb scheme and an implicit Euler scheme. One works cellwise and then process to the assembly. More...
void cs_cdofb_scaleq_solve_theta (bool cur2prev, const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
 Build and solve the linear system arising from a scalar convection/diffusion/reaction equation with a CDO-Fb scheme and an implicit/explicit theta scheme. One works cellwise and then process to the assembly. More...
cs_cdo_balance_t * cs_cdofb_scaleq_balance (const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
 Compute the balance for an equation over the full computational domain between time t_cur and t_cur + dt_cur Case of scalar-valued CDO face-based scheme. More...
void cs_cdofb_scaleq_diff_flux_faces (const cs_real_t *f_values, const cs_real_t *c_values, const cs_equation_param_t *eqp, const cs_property_t *diff_pty, cs_real_t t_eval, cs_equation_builder_t *eqb, void *context, cs_real_t *diff_flux)
 Cellwise computation of the diffusive flux accross primal faces. Interior faces first and then boundary faces. Values at faces are recovered thanks to the equation builder Case of scalar-valued CDO-Fb schemes. More...
void cs_cdofb_scaleq_boundary_diff_flux (const cs_real_t *pot_f, const cs_real_t *pot_c, const cs_equation_param_t *eqp, const cs_property_t *diff_pty, const cs_real_t t_eval, cs_equation_builder_t *eqb, void *context, cs_real_t *bflux)
 Compute an approximation of the diffusive flux across each boundary face. Case of scalar-valued CDO-Fb schemes. More...
void cs_cdofb_scaleq_current_to_previous (const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
void cs_cdofb_scaleq_extra_post (const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
cs_real_t * cs_cdofb_scaleq_get_cell_values (void *context, bool previous)
 Get the computed values at mesh cells from the inverse operation w.r.t. the static condensation (DoF used in the linear system are located at primal faces) The lifecycle of this array is managed by the code. So one does not have to free the return pointer. More...
cs_real_t * cs_cdofb_scaleq_get_face_values (void *context, bool previous)
 Retrieve an array of values at mesh faces for the current context. The lifecycle of this array is managed by the code. So one does not have to free the return pointer. More...
cs_real_t * cs_cdofb_scaleq_get_source_term_values (void *context)
 Retrieve the array storing the source term values at mesh cells. The lifecycle of this array is managed by the code. So one does not have to free the return pointer. More...
void cs_cdofb_scaleq_read_restart (cs_restart_t *restart, const char *eqname, void *scheme_context)
void cs_cdofb_scaleq_write_restart (cs_restart_t *restart, const char *eqname, void *scheme_context)
◆ cs_cdofb_scaleq_balance()
cs_cdo_balance_t * cs_cdofb_scaleq_balance ( const cs_equation_param_t *  eqp,
cs_equation_builder_t *  eqb,
void *  context
[in,out]contextpointer to a scheme builder structure
a pointer to a cs_cdo_balance_t structure
◆ cs_cdofb_scaleq_boundary_diff_flux()
void cs_cdofb_scaleq_boundary_diff_flux ( const cs_real_t *  pot_f,
const cs_real_t *  pot_c,
const cs_property_t *  diff_pty,
void *  context,
cs_real_t *  bflux
[in]pot_farray of values at faces
[in]pot_carray of values at cells
[in]diff_ptypointer to the diffusion property to use
[in,out]bfluxpointer to the values of the diffusive flux
◆ cs_cdofb_scaleq_current_to_previous()
void cs_cdofb_scaleq_current_to_previous ( const cs_equation_param_t *  eqp,
void *  context
[in,out]contextpointer to cs_cdofb_scaleq_t structure
◆ cs_cdofb_scaleq_diff_flux_faces()
void cs_cdofb_scaleq_diff_flux_faces ( const cs_real_t *  f_values,
const cs_real_t *  c_values,
cs_real_t  t_eval,
void *  context,
cs_real_t *  diff_flux
[in]f_valuesvalues for the potential at faces
[in]c_valuesvalues for the potential at cells
[in,out]contextpointer to cs_cdovb_scaleq_t structure
[in,out]diff_fluxvalue of the diffusive flux at primal faces
◆ cs_cdofb_scaleq_extra_post()
void cs_cdofb_scaleq_extra_post ( const cs_equation_param_t *  eqp,
void *  context
◆ cs_cdofb_scaleq_finalize_sharing()
void cs_cdofb_scaleq_finalize_sharing ( void  )
◆ cs_cdofb_scaleq_free_context()
void * cs_cdofb_scaleq_free_context ( void *  data)
[in,out]datapointer to a cs_cdofb_scaleq_t structure
a null pointer
◆ cs_cdofb_scaleq_get()
void cs_cdofb_scaleq_get ( cs_cell_sys_t **  csys,
cs_cell_builder_t **  cb
◆ cs_cdofb_scaleq_get_cell_values()
cs_real_t * cs_cdofb_scaleq_get_cell_values ( void *  context,
bool  previous
a pointer to an array of cs_real_t (size n_cells)
◆ cs_cdofb_scaleq_get_face_values()
cs_real_t * cs_cdofb_scaleq_get_face_values ( void *  context,
bool  previous
a pointer to an array of cs_real_t (size n_faces)
◆ cs_cdofb_scaleq_get_source_term_values()
cs_real_t * cs_cdofb_scaleq_get_source_term_values ( void *  context)
◆ cs_cdofb_scaleq_init_context()
void * cs_cdofb_scaleq_init_context ( cs_equation_param_t *  eqp,
int  var_id,
int  bflux_id,
a pointer to a new allocated cs_cdofb_scaleq_t structure
◆ cs_cdofb_scaleq_init_sharing()
void cs_cdofb_scaleq_init_sharing ( const cs_cdo_quantities_t *  cdoq,
[in]cdoqadditional mesh quantities struct.
◆ cs_cdofb_scaleq_init_values()
void cs_cdofb_scaleq_init_values ( cs_real_t  t_eval,
const int  field_id,
const cs_mesh_t *  mesh,
void *  context
◆ cs_cdofb_scaleq_interpolate()
void cs_cdofb_scaleq_interpolate ( const cs_mesh_t *  mesh,
const cs_real_t *  cell_values,
const int  field_id,
void *  context
[in]cell_valuesarray of cell values
[in]field_idid of the variable field
◆ cs_cdofb_scaleq_is_initialized()
bool cs_cdofb_scaleq_is_initialized ( void  )
true or false
◆ cs_cdofb_scaleq_read_restart()
void cs_cdofb_scaleq_read_restart ( cs_restart_t *  restart,
const char *  eqname,
void *  scheme_context
◆ cs_cdofb_scaleq_solve_implicit()
void cs_cdofb_scaleq_solve_implicit ( bool  cur2prev,
const int  field_id,
void *  context
◆ cs_cdofb_scaleq_solve_steady_state()
void cs_cdofb_scaleq_solve_steady_state ( bool  cur2prev,
const int  field_id,
void *  context
◆ cs_cdofb_scaleq_solve_theta()
void cs_cdofb_scaleq_solve_theta ( bool  cur2prev,
const int  field_id,
void *  context
◆ cs_cdofb_scaleq_write_restart()
void cs_cdofb_scaleq_write_restart ( cs_restart_t *  restart,
