1#ifndef CS_CDOCB_SCALEQ_H
2#define CS_CDOCB_SCALEQ_H
212 const cs_cdocb_scaleq_t *eqc,
time step descriptor
Definition: cs_time_step.h:60
void * cs_cdocb_scaleq_free_context(void *scheme_context)
Destroy a cs_cdocb_scaleq_t structure.
Definition: cs_cdocb_scaleq.cpp:1206
cs_real_t * cs_cdocb_scaleq_get_face_values(void *context, bool previous)
Retrieve an array of values at mesh faces for the variable field associated to the given context The ...
Definition: cs_cdocb_scaleq.cpp:1684
void cs_cdocb_scaleq_current_to_previous(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Copy current content of the related variables-fields to previous values Case of the monolithic coupli...
Definition: cs_cdocb_scaleq.cpp:1625
bool cs_cdocb_scaleq_is_initialized(void)
Check if the generic structures for building a CDO-Cb scheme are allocated.
Definition: cs_cdocb_scaleq.cpp:862
void cs_cdocb_scaleq_diffusion(const cs_equation_param_t *eqp, const cs_equation_builder_t *eqb, const cs_cdocb_scaleq_t *eqc, const cs_cell_mesh_t *cm, cs_hodge_t *diff_hodge, cs_cell_sys_t *csys, cs_cell_builder_t *cb)
Build the local matrices arising from the diffusion term in the scalar-valued CDO-Cb schemes.
Definition: cs_cdocb_scaleq.cpp:1472
void cs_cdocb_scaleq_setup(cs_real_t t_eval, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb)
Set the boundary conditions known from the settings Define an indirection array for the enforcement o...
Definition: cs_cdocb_scaleq.cpp:1272
void cs_cdocb_scaleq_init_sharing(const cs_mesh_t *mesh, const cs_cdo_quantities_t *cdoq, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step)
Definition: cs_cdocb_scaleq.cpp:905
cs_cdo_balance_t * cs_cdocb_scaleq_balance(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Compute the balance for an equation over the full computational domain Case of scalar-valued CDO cell...
Definition: cs_cdocb_scaleq.cpp:1773
void cs_cdocb_scaleq_extra_post(const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Definition: cs_cdocb_scaleq.cpp:1899
void cs_cdocb_scaleq_solve_steady_state(bool cur2prev, const cs_mesh_t *mesh, const int field_id, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Solve the steady-state equation with a CDO cell-based scheme Scalar-valued diffusion equation up-to-n...
Definition: cs_cdocb_scaleq.cpp:1523
cs_real_t * cs_cdocb_scaleq_get_cell_values(void *context, bool previous)
Retrieve an array of values at mesh cellss for the variable field associated to the given context The...
Definition: cs_cdocb_scaleq.cpp:1651
void * cs_cdocb_scaleq_init_context(cs_equation_param_t *eqp, int var_id, int bflux_id, cs_equation_builder_t *eqb)
Initialize a cs_cdocb_scaleq_t structure storing data useful for building and managing such a scheme.
Definition: cs_cdocb_scaleq.cpp:994
void cs_cdocb_scaleq_init_values(cs_real_t t_eval, const int field_id, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context)
Set the initial values of the variable field taking into account the boundary conditions....
Definition: cs_cdocb_scaleq.cpp:1318
void cs_cdocb_scaleq_get(cs_cell_sys_t **csys, cs_cell_builder_t **cb)
Definition: cs_cdocb_scaleq.cpp:880
void cs_cdocb_scaleq_finalize_sharing(void)
Free shared pointers with lifecycle dedicated to this file.
Definition: cs_cdocb_scaleq.cpp:958
void cs_cdocb_scaleq_diff_flux_faces(const cs_real_t *values, const cs_equation_param_t *eqp, cs_real_t t_eval, cs_equation_builder_t *eqb, void *context, cs_real_t *diff_flux)
Cellwise computation of the diffusive flux accross (primal) faces A scalar-valued flux for each face....
Definition: cs_cdocb_scaleq.cpp:1723
Definition: cs_defs.h:332
Definition: cs_cdo_toolbox.h:64
Definition: cs_cdo_connect.h:57
Definition: cs_cdo_quantities.h:142
Definition: cs_cdo_local.h:56
Definition: cs_cdo_local.h:242
Definition: cs_cdo_local.h:163
Definition: cs_hodge.h:179
