cs_advection_field.h File Reference
+ Include dependency graph for cs_advection_field.h:
Classes
struct  cs_adv_field_t
Macros
#define CS_ADVECTION_FIELD_POST_NONE   (1 << 0)
#define CS_ADVECTION_FIELD_POST_COURANT   (1 << 1)
Typedefs
typedef cs_flag_t cs_advection_field_status_t
Enumerations
enum  cs_advection_field_status_bit_t {
  CS_ADVECTION_FIELD_NAVSTO = 1<<0 , CS_ADVECTION_FIELD_GWF = 1<<1 , CS_ADVECTION_FIELD_USER = 1<<2 , CS_ADVECTION_FIELD_TYPE_VELOCITY_VECTOR = 1<<3 ,
  CS_ADVECTION_FIELD_TYPE_SCALAR_FLUX = 1<<4 , CS_ADVECTION_FIELD_STEADY = 1<<5 , CS_ADVECTION_FIELD_LEGACY_FV = 1<<6 , CS_ADVECTION_FIELD_DEFINE_AT_VERTICES = 1<<7 ,
  CS_ADVECTION_FIELD_DEFINE_AT_BOUNDARY_FACES = 1<<8
 Bit values for specifying the definition/behavior of an advection field. More...
static void cs_advection_field_set_status (cs_adv_field_t *adv, cs_advection_field_status_t status)
 Set a new status for the given advection field structure. More...
static bool cs_advection_field_is_uniform (const cs_adv_field_t *adv)
 returns true if the advection field is uniform, otherwise false More...
static bool cs_advection_field_is_cellwise (const cs_adv_field_t *adv)
 returns true if the advection field is uniform in each cell otherwise false More...
static const char * cs_advection_field_get_name (const cs_adv_field_t *adv)
 Retrieve the name of an advection field. More...
static cs_xdef_type_t cs_advection_field_get_deftype (const cs_adv_field_t *adv)
 Retrieve the type of definition used to set the current advection field structure. More...
static cs_field_t * cs_advection_field_get_field (const cs_adv_field_t *adv, cs_mesh_location_type_t ml_type)
 Get a cs_field_t structure related to an advection field and a mesh location. More...
void cs_advection_field_init_sharing (const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect)
 Set shared pointers to main domain members. More...
int cs_advection_field_get_n_fields (void)
 Get the number of allocated cs_adv_field_t structures. More...
cs_adv_field_t * cs_advection_field_by_name (const char *name)
 Search in the array of advection field structures which one has the name given in argument. More...
cs_adv_field_t * cs_advection_field_by_id (int id)
 Search in the array of advection field structures which one has the id given in argument. More...
cs_adv_field_t * cs_advection_field_add_user (const char *name)
 Add and initialize a new user-defined advection field structure. More...
cs_adv_field_t * cs_advection_field_add (const char *name, cs_advection_field_status_t status)
 Add and initialize a new advection field structure. More...
void cs_advection_field_destroy_all (void)
 Free all alllocated cs_adv_field_t structures and its related array. More...
bool cs_advection_field_check_name (const cs_adv_field_t *adv, const char *ref_name)
 Check if the given advection field has the name ref_name. More...
void cs_advection_field_log_setup (void)
 Print all setup information related to cs_adv_field_t structures. More...
void cs_advection_field_set_postprocess (cs_adv_field_t *adv, cs_flag_t post_flag)
 Set optional post-processings. More...
void cs_advection_field_def_by_value (cs_adv_field_t *adv, cs_real_t vector[3])
 Define the value of a cs_adv_field_t structure. More...
void cs_advection_field_def_by_analytic (cs_adv_field_t *adv, cs_analytic_func_t *func, void *input)
 Define a cs_adv_field_t structure thanks to an analytic function. More...
void cs_advection_field_def_by_dof_func (cs_adv_field_t *adv, cs_flag_t dof_location, cs_dof_func_t *func, void *input)
 Define a cs_adv_field_t structure using a cs_dof_func_t. More...
cs_xdef_t * cs_advection_field_def_by_array (cs_adv_field_t *adv, cs_flag_t val_location, cs_real_t *array, bool is_owner)
 Define a cs_adv_field_t structure thanks to an array of values. If an advanced usage of the definition by array is needed, then call cs_xdef_array_set_sublist or cs_xdef_array_set_adjacency. More...
void cs_advection_field_def_by_field (cs_adv_field_t *adv, cs_field_t *field)
 Define a cs_adv_field_t structure thanks to a field structure. More...
void cs_advection_field_def_boundary_flux_by_value (cs_adv_field_t *adv, const char *zname, cs_real_t normal_flux)
 Define the value of the boundary normal flux for the given cs_adv_field_t structure. More...
void cs_advection_field_def_boundary_flux_by_analytic (cs_adv_field_t *adv, const char *zname, cs_analytic_func_t *func, void *input)
 Define the value of the boundary normal flux for the given cs_adv_field_t structure using an analytic function. More...
cs_xdef_t * cs_advection_field_def_boundary_flux_by_array (cs_adv_field_t *adv, const char *zname, cs_flag_t val_loc, cs_real_t *array, bool is_owner, bool full_length)
 Define the value of the boundary normal flux for the given cs_adv_field_t structure using an array of values. More...
void cs_advection_field_def_boundary_flux_by_field (cs_adv_field_t *adv, cs_field_t *field)
 Define the value of the boundary normal flux for the given cs_adv_field_t structure using a field structure. More...
void cs_advection_field_create_fields (void)
 Create all needed cs_field_t structures related to an advection field. More...
void cs_advection_field_finalize_setup (void)
 Last stage of the definition of an advection field based on several definitions (i.e. definition by subdomains on the boundary) More...
void cs_advection_field_get_cell_vector (cs_lnum_t c_id, const cs_adv_field_t *adv, cs_nvec3_t *vect)
 Compute the value of the advection field at the cell center. More...
void cs_advection_field_cw_eval_at_xyz (const cs_adv_field_t *adv, const cs_cell_mesh_t *cm, const cs_real_3_t xyz, cs_real_t time_eval, cs_nvec3_t *eval)
 Compute the vector-valued interpolation of the advection field at a given location inside a cell. More...
void cs_advection_field_in_cells (const cs_adv_field_t *adv, cs_real_t time_eval, cs_real_t *cell_values)
 Compute the mean-value of the vector-valued field related to the advection field inside each cell. More...
void cs_advection_field_at_vertices (const cs_adv_field_t *adv, cs_real_t time_eval, cs_real_t *vtx_values)
 Compute the value of the advection field at vertices. More...
void cs_advection_field_across_boundary (const cs_adv_field_t *adv, cs_real_t time_eval, cs_real_t *flx_values)
 Compute the value of the normal flux of the advection field across the boundary faces. More...
void cs_advection_field_cw_boundary_f2v_flux (const cs_cell_mesh_t *cm, const cs_adv_field_t *adv, short int f, cs_real_t time_eval, cs_real_t *fluxes)
 Compute the value of the normal flux of the advection field across the closure of the dual cell related to each vertex belonging to the boundary face f. More...
cs_real_t cs_advection_field_cw_boundary_face_flux (const cs_real_t time_eval, const short int f, const cs_cell_mesh_t *cm, const cs_adv_field_t *adv)
 Compute the value of the normal flux of the advection field across a boundary face f (cellwise version) More...
void cs_advection_field_cw_face_flux (const cs_cell_mesh_t *cm, const cs_adv_field_t *adv, cs_real_t time_eval, cs_real_t *fluxes)
 Compute the value of the flux of the advection field across the the (primal) faces of a cell. More...
void cs_advection_field_cw_dface_flux (const cs_cell_mesh_t *cm, const cs_adv_field_t *adv, cs_real_t time_eval, cs_real_t *fluxes)
 Compute the value of the flux of the advection field across the the dual faces of a cell. More...
void cs_advection_field_macb_dface_flux (const cs_macfb_builder_t *macb, const cs_adv_field_t *adv, cs_real_t time_eval, cs_real_t *fluxes)
 Compute the value of the flux of the advection field across the the dual faces of a cell MAC face-based scheme. More...
void cs_advection_field_update (cs_real_t t_eval, bool cur2prev)
 For each cs_adv_field_t structures, update the values of the related field(s) More...
void cs_advection_get_peclet (const cs_adv_field_t *adv, const cs_property_t *diff, cs_real_t t_eval, cs_real_t peclet[])
 Compute the Peclet number in each cell. More...
void cs_advection_get_courant (const cs_adv_field_t *adv, cs_real_t dt_cur, cs_real_t courant[])
 Compute the Courant number in each cell. More...
cs_real_t * cs_advection_field_divergence_at_vertices (const cs_adv_field_t *adv, cs_real_t t_eval)
 Compute the divergence of the advection field at vertices Useful for CDO Vertex-based schemes. More...
Typedef Documentation
◆ cs_advection_field_status_t
◆ cs_advection_field_status_bit_t
Enumerator
Advection field stemming from the velocity in the (Navier-)Stokes system
Advection field stemming from the "GroundWater Flows" module. This is the Darcean flux.
User-defined advection field.
The advection field stands for a velocity. This is described by a vector-valued array or function.
The advection field stands for a flux. This is described by a scalar-valued array or function.
Advection field is steady-state
Advection field shared with the legacy Finite Volume solver
Define a field structure related to the advection field at vertices Post-processing and log operations are automatically activated.
Define a field structure related to the advection field at boundary faces Post-processing and log operations are automatically activated.
◆ cs_advection_field_across_boundary()
void cs_advection_field_across_boundary ( const cs_adv_field_t *  adv,
cs_real_t *  flx_values
[in]advpointer to a cs_adv_field_t structure
[in,out]flx_valuesarray storing the results
◆ cs_advection_field_add()
cs_adv_field_t * cs_advection_field_add ( const char *  name,
[in]namename of the advection field
[in]statusstatus of the advection field to create
a pointer to the new allocated cs_adv_field_t structure
◆ cs_advection_field_add_user()
cs_adv_field_t * cs_advection_field_add_user ( const char *  name)
◆ cs_advection_field_at_vertices()
void cs_advection_field_at_vertices ( const cs_adv_field_t *  adv,
cs_real_t *  vtx_values
[in,out]vtx_valuesarray storing the results
◆ cs_advection_field_by_id()
cs_adv_field_t * cs_advection_field_by_id ( int  id)
[in]ididentification number
a pointer to a cs_adv_field_t structure or null if not found
◆ cs_advection_field_by_name()
cs_adv_field_t * cs_advection_field_by_name ( const char *  name)
◆ cs_advection_field_check_name()
bool cs_advection_field_check_name ( const cs_adv_field_t *  adv,
const char *  ref_name
[in]advpointer to a cs_adv_field_t structure to test
[in]ref_namename of the advection field to find
true if the name of the advection field is ref_name otherwise false
◆ cs_advection_field_create_fields()
void cs_advection_field_create_fields ( void  )
◆ cs_advection_field_cw_boundary_f2v_flux()
void cs_advection_field_cw_boundary_f2v_flux ( const cs_cell_mesh_t *  cm,
short int  f,
cs_real_t *  fluxes
[in]fface id in the cellwise numbering
[in,out]fluxesnormal boundary flux for each vertex of the face
◆ cs_advection_field_cw_boundary_face_flux()
cs_real_t cs_advection_field_cw_boundary_face_flux ( const cs_real_t  time_eval,
const short int  f,
the normal boundary flux for the face f
◆ cs_advection_field_cw_dface_flux()
void cs_advection_field_cw_dface_flux ( const cs_cell_mesh_t *  cm,
cs_real_t *  fluxes
[in,out]fluxesarray of values attached to dual faces of a cell
◆ cs_advection_field_cw_eval_at_xyz()
void cs_advection_field_cw_eval_at_xyz ( const cs_adv_field_t *  adv,
cs_nvec3_t *  eval
[in]xyzlocation where to perform the evaluation
[in,out]evalpointer to a cs_nvec3_t
◆ cs_advection_field_cw_face_flux()
void cs_advection_field_cw_face_flux ( const cs_cell_mesh_t *  cm,
cs_real_t *  fluxes
[in,out]fluxesarray of values attached to primal faces of a cell
◆ cs_advection_field_def_boundary_flux_by_analytic()
void cs_advection_field_def_boundary_flux_by_analytic ( cs_adv_field_t *  adv,
const char *  zname,
cs_analytic_func_t *  func,
void *  input
[in,out]advpointer to a cs_adv_field_t structure
[in]znamename of the boundary zone to consider
[in]funcpointer to a function
[in]inputnull or pointer to a structure cast on-the-fly
◆ cs_advection_field_def_boundary_flux_by_array()
cs_xdef_t * cs_advection_field_def_boundary_flux_by_array ( cs_adv_field_t *  adv,
const char *  zname,
cs_flag_t  val_loc,
cs_real_t *  array,
bool  is_owner,
bool  full_length
[in]val_locinformation to know where are located values
[in]arraypointer to an array
[in]is_ownertransfer the lifecycle to the cs_xdef_t struct. (true or false)
[in]full_lengthif true, the size of "array" should be allocated to the total numbers of entities related to the given location. If false, a new list is allocated and filled with the related subset indirection.
a pointer to the resulting definition
◆ cs_advection_field_def_boundary_flux_by_field()
void cs_advection_field_def_boundary_flux_by_field ( cs_adv_field_t *  adv,
cs_field_t *  field
[in]fieldpointer to a cs_field_t structure
◆ cs_advection_field_def_boundary_flux_by_value()
void cs_advection_field_def_boundary_flux_by_value ( cs_adv_field_t *  adv,
const char *  zname,
[in]normal_fluxvalue to set
◆ cs_advection_field_def_by_analytic()
void cs_advection_field_def_by_analytic ( cs_adv_field_t *  adv,
void *  input
◆ cs_advection_field_def_by_array()
cs_xdef_t * cs_advection_field_def_by_array ( cs_adv_field_t *  adv,
cs_real_t *  array,
bool  is_owner
[in]val_locationinformation to know where are located values
[in]is_ownertransfer the lifecycle to the cs_xdef_t struc. (true or false)
a pointer to the resulting cs_xdef_t structure
◆ cs_advection_field_def_by_dof_func()
void cs_advection_field_def_by_dof_func ( cs_adv_field_t *  adv,
cs_dof_func_t *  func,
void *  input
[in]dof_locationlocation where values are computed
[in]funcpointer to a cs_dof_func_t function
◆ cs_advection_field_def_by_field()
void cs_advection_field_def_by_field ( cs_adv_field_t *  adv,
cs_field_t *  field
◆ cs_advection_field_def_by_value()
void cs_advection_field_def_by_value ( cs_adv_field_t *  adv,
cs_real_t  vector[3]
[in]vectorvalues to set
◆ cs_advection_field_destroy_all()
void cs_advection_field_destroy_all ( void  )
◆ cs_advection_field_divergence_at_vertices()
cs_real_t * cs_advection_field_divergence_at_vertices ( const cs_adv_field_t *  adv,
cs_real_t  t_eval
[in]advpointer to the advection field struct.
[in]t_evaltime at which one evaluates the advection field
a pointer to an array storing the result
◆ cs_advection_field_finalize_setup()
void cs_advection_field_finalize_setup ( void  )
◆ cs_advection_field_get_cell_vector()
void cs_advection_field_get_cell_vector ( cs_lnum_t  c_id,
cs_nvec3_t *  vect
[in]c_idid of the current cell
[in,out]vectpointer to a cs_nvec3_t structure (meas + unitv)
◆ cs_advection_field_get_deftype()
static cs_xdef_type_t cs_advection_field_get_deftype ( const cs_adv_field_t *  adv)
inlinestatic
[in]advpointer to an advection field structure
◆ cs_advection_field_get_field()
static cs_field_t * cs_advection_field_get_field ( const cs_adv_field_t *  adv,
inlinestatic
[in]ml_typetype of mesh location (cells or vertices)
a pointer to a cs_field_t structure
◆ cs_advection_field_get_n_fields()
int cs_advection_field_get_n_fields ( void  )
the number of advection fields
◆ cs_advection_field_get_name()
static const char * cs_advection_field_get_name ( const cs_adv_field_t *  adv)
inlinestatic
the name of the related advection field
◆ cs_advection_field_in_cells()
void cs_advection_field_in_cells ( const cs_adv_field_t *  adv,
cs_real_t *  cell_values
[in,out]cell_valuesarray of values at cell centers
◆ cs_advection_field_init_sharing()
void cs_advection_field_init_sharing ( const cs_cdo_quantities_t *  quant,
const cs_cdo_connect_t *  connect
◆ cs_advection_field_is_cellwise()
static bool cs_advection_field_is_cellwise ( const cs_adv_field_t *  adv)
inlinestatic
[in]advpointer to an advection field to test
true or false
◆ cs_advection_field_is_uniform()
static bool cs_advection_field_is_uniform ( const cs_adv_field_t *  adv)
inlinestatic
true or false
◆ cs_advection_field_log_setup()
void cs_advection_field_log_setup ( void  )
◆ cs_advection_field_macb_dface_flux()
void cs_advection_field_macb_dface_flux ( const cs_macfb_builder_t *  macb,
cs_real_t *  fluxes
[in]macbpointer to a cs_macfb_builder_t structure
◆ cs_advection_field_set_postprocess()
void cs_advection_field_set_postprocess ( cs_adv_field_t *  adv,
cs_flag_t  post_flag
[in]post_flagflag to set
◆ cs_advection_field_set_status()
static void cs_advection_field_set_status ( cs_adv_field_t *  adv,
inlinestatic
[in,out]advpointer to an advection field structure
[in]statusstatus flag to add to the current status
◆ cs_advection_field_update()
void cs_advection_field_update ( cs_real_t  t_eval,
bool  cur2prev
[in]t_evalphysical time at which one evaluates the term
[in]cur2prevtrue or false
◆ cs_advection_get_courant()
void cs_advection_get_courant ( const cs_adv_field_t *  adv,
cs_real_t  dt_cur,
cs_real_t  courant[]
[in]dt_curcurrent time step
[in,out]courantpointer to an array storing the Courant number
◆ cs_advection_get_peclet()
void cs_advection_get_peclet ( const cs_adv_field_t *  adv,
const cs_property_t *  diff,
cs_real_t  t_eval,
cs_real_t  peclet[]
[in]diffpointer to the diffusion property struct.
[in,out]pecletpointer to an array storing the Peclet number
