| _ns_vals | cs_field_t | |
| bc_coeffs | cs_field_t | |
| clear(const int time_id=-1) | cs_field_t | |
| clear_key_int_bits(int key_id, int mask) | cs_field_t | |
| clear_key_int_bits(const char *key, int mask) | cs_field_t | |
| dim | cs_field_t | |
| get_grad_s() const | cs_field_t | |
| get_grad_t() const | cs_field_t | |
| get_grad_v() const | cs_field_t | |
| get_key_double(int key_id) const | cs_field_t | |
| get_key_double(const char *key) const | cs_field_t | |
| get_key_int(int key_id) const | cs_field_t | |
| get_key_int(const char *key) const | cs_field_t | |
| get_key_str(int key_id) const | cs_field_t | |
| get_key_str(const char *key) const | cs_field_t | |
| get_key_struct(const int key_id, void *s) const | cs_field_t | |
| get_key_struct(const char *key, void *s) const | cs_field_t | |
| get_ns_val_s(const int time_id=0) const | cs_field_t | |
| get_ns_val_t(const int time_id=0) const | cs_field_t | |
| get_ns_val_v(const int time_id=0) const | cs_field_t | |
| get_ns_vals_s(const int time_id=0) const | cs_field_t | |
| get_ns_vals_t(const int time_id=0) const | cs_field_t | |
| get_ns_vals_v(const int time_id=0) const | cs_field_t | |
| get_val_s(const int time_id=0) const | cs_field_t | |
| get_val_t(const int time_id=0) const | cs_field_t | |
| get_val_v(const int time_id=0) const | cs_field_t | |
| get_vals_alloc_mode(const int time_id=0) const | cs_field_t | |
| get_vals_s(const int time_id=0) const | cs_field_t | |
| get_vals_t(const int time_id=0) const | cs_field_t | |
| get_vals_v(const int time_id=0) const | cs_field_t | |
| grad | cs_field_t | |
| has_sub_fields() const | cs_field_t | inline |
| id | cs_field_t | |
| initialize_sub_fields(void) | cs_field_t | |
| is_owner | cs_field_t | |
| is_part_of_series() const | cs_field_t | inline |
| is_series_owner() const | cs_field_t | inline |
| is_sub_field() const | cs_field_t | inline |
| is_sub_field_of(const int owner_id) const | cs_field_t | inline |
| location_id | cs_field_t | |
| map_to_ns_data(void) | cs_field_t | |
| map_values(cs_real_t *val_new, cs_real_t *val_pre_new) | cs_field_t | |
| n_time_vals | cs_field_t | |
| name | cs_field_t | |
| ns_idx | cs_field_t | |
| ns_owner | cs_field_t | |
| ns_size | cs_field_t | |
| ns_view(const int time_id=0) const | cs_field_t | |
| series_id() const | cs_field_t | inline |
| series_size() const | cs_field_t | inline |
| set_key_double(int key_id, double value) | cs_field_t | |
| set_key_double(const char *key, double value) | cs_field_t | |
| set_key_int(int key_id, int value) | cs_field_t | |
| set_key_int(const char *key, int value) | cs_field_t | |
| set_key_int_bits(int key_id, int mask) | cs_field_t | |
| set_key_int_bits(const char *key, int mask) | cs_field_t | |
| set_key_str(int key_id, const char *str) | cs_field_t | |
| set_key_str(const char *key, const char *str) | cs_field_t | |
| set_ns_owner(int owner_id) | cs_field_t | inline |
| set_ns_parameters(const int series_size, const int series_idx, const int series_owner) | cs_field_t | inline |
| type | cs_field_t | |
| update_public_pointers(void) | cs_field_t | |
| update_size(const int time_id=-1) | cs_field_t | |
| update_sub_fields_mapping(void) const | cs_field_t | |
| val | cs_field_t | |
| val_pre | cs_field_t | |
