Setting porosity values from a CAD file
Using an appropriate CAD representation, it may be possible to compute the porosity fields using "common" or "cut" boolean operations between cells in the porous zones and the CAD volume. If the CAD shape represents the actual fluid volume, the common volume between the shape and the porous mesh section's cells will be used. If the CAD shape represents the solid volume, it should be cut from the pourous mesh section's cells.
The following example uses functions from the OpenCascade Technology (OCCT) libraries (https://dev.opencascade.org/doc/overview/html/index.html), and assumes they are installed on the user's machine. As these libraries form the backbone of the SALOME platform's CAD features, they are present with any generic or common SALOME install, and are available as a package in many Linux distributions.
Libraries to compile and link.
As the OCCT libraries provide a C++ API, interfacing them with code_saturne requires a file written in C++, so the following example uses a separate C++ file, cs_cad_intersect.cxx to to most of the work. This file is also a user example, and may be improved or modified.
To compile and link, additional compiler flags must be passed to code_saturne. They may be defined in <_ref cs_user_scripts.py, and the following values are recommended (adapting the paths to the local environment):
occ_include_path = "/opt/occ/7.4.0/include/opencascade"
occ_lib_paths = ("/opt/occ/7.4.0/lib", "/opt/gl2ps/1.4.0.1/lib")
occ_libs "-lTKMesh -lTKernel -lTKG2d -lTKG3d -lTKMath -lTKIGES -lTKXSBase -lTKBin -lTKBool -lTKBO -lTKCDF -lTKBRep -lTKTopAlgo -lTKGeomAlgo -lTKGeomBase -lTKOffset -lTKPrim -lTKSTEP -lTKSTEPBase -lTKSTEPAttr -lTKHLR -lTKFeat"
domain.compile_cxxflags = "-std=c++11 -I" + occ_include_path;
domain.compile_libs = ""
for p in occ_lib_paths:
domain.compile_libs += "-L" + p + " -Wl,-rpath -Wl," + p + " "
domain.compile_libs += occ_libs
Function prototypes.
As the prototypes for the cs_cad_intersect.cxx are not part of the defaul code_saturne installation, do not forget to include the cs_cad_intersect.h header in the Local headers section of the cs_user_porosity.c file:
#include "user_examples/cs_cad_intersect.h"
Zone selection
It is recommended to use the standard zone selection mechanism to select cells which may be intersected by the CAD shape, for example:
const cs_zone_t *z_poro = cs_volume_zone_by_name("Zone_1");
const cs_zone_t * cs_volume_zone_by_name(const char *name)
Return a pointer to a volume zone based on its name if present.
Definition: cs_volume_zone.cpp:665
Definition: cs_zone.h:51
Local variables and initialization
A few local variables may allow a more concise syntax, and optional face porosity arrays may be declared as temporary work arrays if face factors are required::
const cs_lnum_t n_i_faces = m->n_i_faces;
const cs_lnum_t n_b_faces = m->n_b_faces;
/* Temporary arrays for face porosity */
auto cell_porosity = cs_field("porosity")->get_val_s();
cs_real_t *i_face_porosity, *b_face_porosity;
CS_MALLOC(i_face_porosity, m->n_i_faces, cs_real_t);
CS_MALLOC(b_face_porosity, m->n_b_faces, cs_real_t);
for (cs_lnum_t i = 0; i < m->n_i_faces; i++)
i_face_porosity[i] = 1;
for (cs_lnum_t i = 0; i < m->n_b_faces; i++)
b_face_porosity[i] = 1;
cs_span< cs_real_t > get_val_s(const int time_id=0) const
Return a 1D span view of field values. If the field is not a scalar a fatal error is provoked.
Definition: cs_field.cpp:5080
Definition: cs_defs.h:332
Definition: cs_defs.h:325
cs_field_t * cs_field(int id)
Return a pointer to a field based on its id. This function requires that a field of the given id is d...
Definition: cs_field.cpp:4295
#define CS_MALLOC(_ptr, _ni, _type)
Definition: cs_mem.h:75
cs_mesh_t * cs_glob_mesh
Definition: cs_mesh_quantities.h:88
Definition: cs_mesh.h:85
cs_lnum_t n_i_faces
Definition: cs_mesh.h:98
cs_lnum_t n_b_faces
Definition: cs_mesh.h:99
CAD intersection operation
The actual CAD intersection is done using the following call (adapting the file path to the actual file):
cs_cad_intersect(m,
"Compound_1.step",
CS_CAD_INTERSECT_CUT,
z_poro->n_elts,
z_poro->elt_ids,
cell_porosity,
nullptr, /* modified cell centers */
i_face_porosity,
nullptr, /* modified interior face centers */
b_face_porosity,
nullptr); /* modified boundary face centers */
const cs_lnum_t * elt_ids
Definition: cs_zone.h:61
cs_lnum_t n_elts
Definition: cs_zone.h:60
Computing porous quantities
Though the cell porosity is directly set by the call above, face quantities may be computed from the face porosities. The following code also handles the cleanup op local arrays.
/* synchronize ghost cells */
if (m->halo != nullptr)
cs_halo_sync(m->halo, CS_HALO_EXTENDED, cell_porosity);
/* Set interior and boundary face values */
if (mq->i_f_face_surf != mq->i_face_surf) {
const cs_real_3_t *restrict i_face_normal
= (const cs_real_3_t *)mq->i_face_normal;
cs_real_3_t *restrict i_f_face_normal
= (cs_real_3_t *)mq->i_f_face_normal;
cs_real_t *i_f_face_surf = mq->i_f_face_surf;
for (cs_lnum_t f_id = 0; f_id < n_i_faces; f_id++) {
cs_real_t f_porosity = i_face_porosity[f_id];
for (cs_lnum_t i = 0; i < 3; i++)
i_f_face_normal[f_id][i] = f_porosity * i_face_normal[f_id][i];
i_f_face_surf[f_id] = cs_math_3_norm(i_f_face_normal[f_id]);
if (mq->b_f_face_surf != mq->b_face_surf) {
const cs_real_3_t *restrict b_face_normal
= (const cs_real_3_t *)mq->b_face_normal;
cs_real_3_t *restrict b_f_face_normal
= (cs_real_3_t *)mq->b_f_face_normal;
cs_real_t *b_f_face_surf = mq->b_f_face_surf;
for (cs_lnum_t f_id = 0; f_id < n_b_faces; f_id++) {
cs_real_t f_porosity = b_face_porosity[f_id];
b_f_face_normal[f_id][i] = f_porosity * b_face_normal[f_id][i];
b_f_face_surf[f_id] = cs_math_3_norm(b_f_face_normal[f_id]);
CS_FREE(i_face_porosity);
CS_FREE(b_face_porosity);
/* Four set face factor */
if (mq->i_f_face_factor != nullptr) {
const cs_lnum_2_t *i_face_cells = m->i_face_cells;
const cs_real_t *i_face_surf = mq->i_face_surf;
const cs_real_t *i_f_face_surf = mq->i_f_face_surf;
for (cs_lnum_t f_id = 0; f_id < m->n_i_faces; f_id++) {
cs_lnum_t ii = i_face_cells[f_id][0];
cs_lnum_t jj = i_face_cells[f_id][1];
cs_real_t face_porosity
= cs::max(i_f_face_surf[f_id] / i_face_surf[f_id],
mq->i_f_face_factor[f_id][0] = cell_porosity[ii] / face_porosity;
mq->i_f_face_factor[f_id][1] = cell_porosity[jj] / face_porosity;
#define restrict
Definition: cs_defs.h:148
cs_lnum_t cs_lnum_2_t[2]
Definition: cs_defs.h:342
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:349
void cs_halo_sync(const cs_halo_t *halo, cs_halo_type_t sync_mode, cs_datatype_t data_type, int stride, void *val)
Update array of values in case of parallelism or periodicity.
Definition: cs_halo.cpp:2240
@ CS_HALO_EXTENDED
Definition: cs_halo.h:56
static constexpr cs_real_t cs_math_epzero
Definition: cs_math.h:102
CS_F_HOST_DEVICE T cs_math_3_norm(const T v[3])
Compute the euclidean norm of a vector of dimension 3.
Definition: cs_math.h:240
#define CS_FREE(_ptr)
Definition: cs_mem.h:151
CS_F_HOST_DEVICE T max(const T a, const T b)
Definition: cs_defs.h:735
cs_real_t * i_face_surf
Definition: cs_mesh_quantities.h:107
cs_real_2_t * i_f_face_factor
Definition: cs_mesh_quantities.h:115
cs_real_t * b_face_surf
Definition: cs_mesh_quantities.h:108
cs_real_t * b_face_normal
Definition: cs_mesh_quantities.h:97
cs_real_t * i_face_normal
Definition: cs_mesh_quantities.h:95
cs_halo_t * halo
Definition: cs_mesh.h:156
cs_lnum_2_t * i_face_cells
Definition: cs_mesh.h:111
