Basic examples (legacy method)
The preferred method for defining boundary conditions (besides using the GUI) is to assign zone-based definitions in the cs_user_boundary_conditions_setup function (cs_user_boundary_conditions.cpp).
As an alternative, the same definitions may be defined in cs_user_finalize_setup_wrapper (cs_user_parameters), which is called immediately after cs_user_boundary_conditions_setup. Choosing one or the other should be based on the best balance for reability and maintainability,
Initialization
The following initialization block needs to be added for the following examples:
const int n_fields = cs_field_n_fields();
const auto bpro_rho = CS_F_(rho_b)->get_val_s();
const int keysca = cs_field_key_id("scalar_id");
const cs_zone_t *zn = nullptr;
auto vel_val_ext = CS_F_(vel)->bc_coeffs->get_val_ext_v();
Definition: cs_defs.h:332
int cs_field_n_fields(void)
Definition: cs_field.cpp:1505
Definition: cs_field.cpp:2728
@ vel
Definition: cs_field_pointer.h:66
@ rho_b
#define CS_F_(e)
Definition: cs_field_pointer.h:47
Definition: cs_physical_constants.cpp:462
double viscl0
Definition: cs_physical_constants.h:75
Definition: cs_zone.h:51
Body
In the body, we may define several boundary conditions. Here are a few examples.
Inlet example with hydraulic diameter
Assign an inlet to boundary faces of in zone 'inlet_1'.
Warning
the <, <=, >, and >= operators may only be used with variables x, y, and z. This syntax is not a full equation interpreter, so formulas involving x, y, or z are not allowed.
Set a a Dirichlet value on the three components of $ \vect{u} $ on the faces with the selection criterion '2 and x < 0.01' and set a Dirichlet to all the scalars $ \varia $.
Turbulence example computed using equations valid for a pipe.
We will be careful to specify a hydraulic diameter adapted to the current inlet.
We will also be careful if necessary to use a more precise formula for the dynamic viscosity use in the calculation of the Reynolds number (especially if it is variable, it may be useful to take the law from cs_user_physical_properties. Here, we use by default the 'viscl0" value.
Regarding the density, we have access to its value at boundary faces (b_roh) so this value is the one used here (specifically, it is consistent with the processing in cs_user_physical_properties, in case of variable density).
zn = cs_boundary_zone_by_name("inlet_1");
for (cs_lnum_t e_idx = 0; e_idx < zn->n_elts; e_idx++) {
const cs_lnum_t face_id = zn->elt_ids[e_idx];
bc_type[face_id] = CS_INLET;
vel_val_ext(face_id, 0) = 0; /* vel_x */
vel_val_ext(face_id, 1) = 0; /* vel_y */
vel_val_ext(face_id, 2) = 0; /* vel_z */
cs_real_t uref2 = 0;
for (cs_lnum_t ii = 0; ii < 3; ii++)
uref2 += cs_math_pow2(vel_val_ext(face_id, ii));
uref2 = cs::max(uref2, 1e-12);
/* Turbulence example computed using equations valid for a pipe.
* We will be careful to specify a hydraulic diameter adapted
* to the current inlet.
* We will also be careful if necessary to use a more precise
* formula for the dynamic viscosity use in the calculation of
* the Reynolds number (especially if it is variable, it may be
* useful to take the law from 'cs_user_physical_properties'
* Here, we use by default the 'viscl0" value.
* Regarding the density, we have access to its value at boundary
* faces (b_rho) so this value is the one used here (specifically,
* it is consistent with the processing in 'cs_user_physical_properties',
* in case of variable density) */
/* Hydraulic diameter */
/* Calculation of turbulent inlet conditions using
the turbulence intensity and standard laws for a circular pipe
(their initialization is not needed here but is good practice) */
cs_real_t b_rho = bpro_rho[face_id];
uref2,
xdh,
b_rho,
viscl0);
/* Set user scalar values to 1 */
cs_field_t *f = cs_field(f_id);
if (f->get_key_int(keysca) > 0) {
auto val_ext = f->bc_coeffs->get_val_ext();
val_ext[face_id] = 1.0;
cs_span< cs_real_t > get_val_ext() const
Return a 1D span view of boundary condition external values.
Definition: cs_field.cpp:5826
Definition: cs_field.h:275
int get_key_int(int key_id) const
Definition: cs_field.cpp:4507
Definition: cs_field.h:309
Definition: cs_boundary_zone.cpp:708
Definition: cs_defs.h:325
cs_field_t * cs_field(int id)
Return a pointer to a field based on its id. This function requires that a field of the given id is d...
Definition: cs_field.cpp:4295
CS_F_HOST_DEVICE cs_real_t cs_math_pow2(cs_real_t x)
Definition: cs_math.h:902
cs_real_t cs_notebook_parameter_value_by_name(const char *name)
Return a parameter value (real).
Definition: cs_notebook.cpp:408
@ CS_INLET
Definition: cs_parameters.h:83
Definition: cs_turbulence_bc.cpp:745
CS_F_HOST_DEVICE T max(const T a, const T b)
Definition: cs_defs.h:735
const cs_lnum_t * elt_ids
Definition: cs_zone.h:61
cs_lnum_t n_elts
Definition: cs_zone.h:60
Inlet example with turbulence intensity
Assign an inlet to boundary faces of zone 'inlet_2'.
Set a a Dirichlet value on the three components of $ \vect{u} $ on the faces with the selection criterion '3' and set a Dirichlet to all the scalars $ \varia $.
Turbulence example computed using turbulence intensity data.
Calculation of $ k $ and $ \varepsilon $ at the inlet (xkent and xeent) using the turbulence intensity and standard laws for a circular pipe (their initialization is not needed here but is good practice)
zn = cs_boundary_zone_by_name("inlet_2");
/* Hydraulic diameter: to be defined in the GUI notebook. */
/* Turbulence intensity: to be defined in the GUI notebook. */
vel_val_ext(face_id, 1) = 1.1; /* vel_y */
* the turbulence intensity and standard laws for a circular pipe
* (their initialization is not needed here but is good practice) */
cs_turbulence_bc_inlet_turb_intensity(face_id, uref2, xitur, xdh);
void cs_turbulence_bc_inlet_turb_intensity(cs_lnum_t face_id, double uref2, double t_intensity, double dh)
Set inlet boundary condition values for turbulence variables based on a diameter ,...
Definition: cs_turbulence_bc.cpp:773
Assign an outlet to boundary faces of zone 'outlet'
Outlet:
  • zero flux for velocity and temperature, prescribed pressure
  • Note that the pressure will be set to P0 at the first
  • free outlet face (CS_OUTLET)
zn = cs_boundary_zone_by_name("outlet");
bc_type[face_id] = CS_OUTLET;
@ CS_OUTLET
Definition: cs_parameters.h:84
Wall example
Assign a wall to boundary faces of zone '5'.
Wall:
  • zero flow (zero flux for pressure)
  • friction for velocities (+ turbulent variables)
  • zero flux for scalars
bc_type[face_id] = CS_SMOOTHWALL;
/* Temperature */
if (th_f != nullptr) {
int *th_icodcl = th_f->bc_coeffs->icodcl;
auto th_val_ext = th_f->bc_coeffs->get_val_ext();
auto th_h_ext = th_f->bc_coeffs->get_h_ext();
auto th_q_ext = th_f->bc_coeffs->get_q_ext();
/* If temperature prescribed to 20 with wall law */
th_icodcl[face_id] = CS_BC_WALL_MODELLED;
th_val_ext[face_id] = 20.;
/* If temperature prescribed to 50 with no wall law (simple Dirichlet)
* with exchange coefficient 8 */
th_f->bc_coeffs->icodcl[face_id] = CS_BC_DIRICHLET;
th_val_ext[face_id] = 50.;
th_h_ext[face_id] = 8.;
/* If flux prescribed to 4. */
th_icodcl[face_id] = CS_BC_NEUMANN;
th_q_ext[face_id] = 4.;
cs_span< cs_real_t > get_h_ext() const
Return a 1D span view of boundary condition external exchange coefficient.
Definition: cs_field.cpp:5931
cs_span< cs_real_t > get_q_ext() const
Return a 1D span view of boundary condition prescribed flux.
Definition: cs_field.cpp:6018
int * icodcl
Definition: cs_field.h:111
@ CS_BC_NEUMANN
Definition: cs_param_types.h:511
@ CS_BC_DIRICHLET
Definition: cs_param_types.h:506
@ CS_BC_WALL_MODELLED
Definition: cs_param_types.h:516
@ CS_SMOOTHWALL
Definition: cs_parameters.h:87
cs_field_t * cs_thermal_model_field(void)
Definition: cs_thermal_model.cpp:180
Rough wall example
Assign a rough wall to boundary faces of zone '7'.
Wall:
  • rough friction for velocities (+ turbulent variables)
cs_span<cs_real_t> bpro_roughness;
cs_span<cs_real_t> bpro_roughness_t;
if (cs_field_try("boundary_roughness") != nullptr)
bpro_roughness = cs_field("boundary_roughness")->get_val_s();
if (cs_field_try("boundary_thermal_roughness") != nullptr)
bpro_roughness_t = cs_field("boundary_thermal_roughness")->get_val_s();
/* Wall: zero flow (zero flux for pressure)
* rough friction for velocities (+ turbulent variables)
* zero flux for scalars*/
bc_type[face_id] = CS_ROUGHWALL;
/* Roughness for velocity: 1cm */
if (bpro_roughness.size() != 0)
bpro_roughness[face_id] = 0.01;
/* Roughness for temperature (if required): 1cm */
if (bpro_roughness_t.size() != 0)
bpro_roughness_t[face_id] = 0.01;
/* If sliding wall with velocity */
vel_val_ext(face_id, 0) = 1.;
Define a templated mdspan class (non owner of data)
Definition: cs_mdspan.h:68
CS_F_HOST_DEVICE cs_lnum_t size() const
Getter for total size.
Definition: cs_mdspan.h:508
cs_span< cs_real_t > get_val_s(const int time_id=0) const
Return a 1D span view of field values. If the field is not a scalar a fatal error is provoked.
Definition: cs_field.cpp:5080
cs_field_t * cs_field_try(int id)
Return a pointer to a field based on its id. If no field of the given name is defined,...
Definition: cs_field.cpp:4371
@ CS_ROUGHWALL
Definition: cs_parameters.h:88
Symmetry example
Assign a symmetry condition to boundary faces of zone '4'
bc_type[face_id] = CS_SYMMETRY;
@ CS_SYMMETRY
Definition: cs_parameters.h:85
