cs_prototypes.h File Reference
+ Include dependency graph for cs_prototypes.h:
void cs_user_1d_wall_thermal (int iappel)
 Data Entry of the 1D wall thermal module. More...
void cs_user_atmo_1d_rad_prf (cs_real_t preray[], cs_real_t temray[], cs_real_t romray[], cs_real_t qvray[], cs_real_t qlray[], cs_real_t ncray[], cs_real_t aeroso[])
 Fill in vertical profiles of atmospheric properties prior to solving 1D radiative transfers. More...
void cs_user_boundary_conditions_setup (cs_domain_t *domain)
 Setup boundary conditions to be applied. More...
void cs_user_boundary_conditions (cs_domain_t *domain, int bc_type[])
 User definition of boundary conditions. More...
void cs_user_boundary_conditions_ale (cs_domain_t *domain, int bc_type[], int ale_bc_type[], int impale[])
 User definition of boundary conditions for ALE. More...
void cs_user_saturne_coupling (void)
 Define couplings with other instances of code_saturne. More...
void cs_user_syrthes_coupling (void)
 Define couplings with the SYRTHES code. More...
void cs_user_syrthes_coupling_volume_h (int coupling_id, const char *syrthes_name, cs_lnum_t n_elts, const cs_lnum_t elt_ids[], cs_real_t h_vol[])
 Compute a volume exchange coefficient for SYRTHES couplings. More...
void cs_user_cathare_coupling (void)
 Define couplings with CATHARE code. More...
void cs_user_scaling_elec (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, cs_real_t *dt)
 Rescale all electro-magnetic physical fields (electric potential, current density and Joule effect). More...
void cs_user_extra_operations_initialize (cs_domain_t *domain)
 Initialize variables or setup extra operations. More...
void cs_user_extra_operations (cs_domain_t *domain)
 User operations called at the end of each time step. More...
void cs_user_extra_operations_finalize (cs_domain_t *domain)
 User operations called at the end of the calculation. More...
void cs_user_fsi_structure_define (int is_restart, int n_structs, int *plot, cs_time_control_t *plot_time_control, cs_real_t *aexxst, cs_real_t *bexxst, cs_real_t *cfopre, cs_real_t xstr0[][3], cs_real_t vstr0[][3], cs_real_t xstreq[][3])
 Definition of internal mobile structures and corresponding initial conditions (initial displacement and velocity ). More...
void cs_user_fsi_structure_values (int n_structs, const cs_time_step_t *ts, const cs_real_t xstreq[][3], const cs_real_t xstr[][3], const cs_real_t vstr[][3], cs_real_t xmstru[][3][3], cs_real_t xcstru[][3][3], cs_real_t xkstru[][3][3], cs_real_t forstr[][3], cs_real_t dtstr[])
 Time-based settings for internal mobile structures. More...
void cs_user_fsi_structure_num (cs_domain_t *domain, int structure_num[], cs_mobile_structure_type_t structure_typ[])
 Define structure numbers for faces associated with internal or external (code_aster) structures. More...
void cs_user_fsi_external_displacement (const cs_domain_t *domain, const cs_real_3_t *b_stress, cs_real_3_t *disaple)
 Compute displacement fluid boundary for the external structures (code_aster excluded). More...
void cs_user_fsi_external_cvg (const cs_domain_t *domain, const cs_real_t epsilon, int *cvg_status, cs_real_t *residual)
 Compute convergence state of the external structures (code_aster excluded). More...
void cs_user_head_losses (const cs_zone_t *zone, cs_real_t cku[][6])
 Define head losses for a given volume zone. More...
void cs_user_hgn_thermo_relax_time (const cs_mesh_t *mesh, const cs_real_t *alpha_eq, const cs_real_t *y_eq, const cs_real_t *z_eq, const cs_real_t *ei, const cs_real_t *v, cs_real_t *relax_tau)
 Compute the relaxation time-scale to equilibrium in the frame of the homogeneous two-phase model.. More...
void cs_user_initial_conditions (cs_domain_t *domain)
 Define initial conditions for variables. More...
void cs_user_initialization (cs_domain_t *domain)
 Initialize variables. More...
void cs_user_mesh_restart_mode (void)
 Force preprocessing behavior in case of restart. More...
void cs_user_mesh_input (void)
 Define mesh files to read and optional associated transformations. More...
void cs_user_mesh_cartesian_define (void)
 Define a cartesian mesh. More...
void cs_user_join (void)
 Define mesh joinings. More...
void cs_user_periodicity (void)
 Define periodic faces. More...
void cs_user_mesh_warping (void)
 Set options for cutting of warped faces. More...
void cs_user_mesh_boundary (cs_mesh_t *mesh)
 Insert boundaries into a mesh. More...
void cs_user_mesh_modify (cs_mesh_t *mesh)
 Modify geometry and mesh. More...
void cs_user_mesh_smoothe (cs_mesh_t *mesh)
 Mesh smoothing. More...
void cs_user_mesh_save (cs_mesh_t *mesh)
 Enable or disable mesh saving. More...
void cs_user_mesh_bad_cells_tag (cs_mesh_t *mesh, cs_mesh_quantities_t *mesh_quantities)
 Tag bad cells within the mesh based on user-defined geometric criteria. More...
void cs_user_mesh_modify_partial (cs_mesh_t *mesh, cs_mesh_quantities_t *mesh_quantities)
 Apply partial modifications to the mesh after the preprocessing and initial postprocessing mesh building stage. More...
void cs_user_paramedmem_define_couplings (void)
 Define ParaMEDMEM coupling(s) More...
void cs_user_paramedmem_define_meshes (void)
 Define coupled meshes. More...
void cs_user_paramedmem_define_fields (void)
 Define fields to couple with ParaMEDMEM. More...
void cs_user_model (void)
 Select physical model options, including user fields. More...
void cs_user_parameters (cs_domain_t *domain)
 Define or modify general numerical and physical user parameters. More...
void cs_user_linear_solvers (void)
 Define linear solver options. More...
void cs_user_time_moments (void)
 Define time moments. More...
void cs_user_internal_coupling (void)
 Define internal coupling options. More...
void cs_user_finalize_setup (cs_domain_t *domain)
 Define or modify output user parameters. More...
void cs_user_numbering (void)
 Define advanced mesh numbering options. More...
void cs_user_partition (void)
 Define advanced partitioning options. More...
void cs_user_parallel_io (void)
 Define parallel IO settings. More...
void cs_user_matrix_tuning (void)
 Define sparse matrix tuning options. More...
void cs_user_physical_properties (cs_domain_t *domain)
 Function called at each time step to define physical properties. More...
void cs_user_physical_properties_h_to_t (cs_domain_t *domain, const cs_zone_t *z, bool z_local, const cs_real_t h[], cs_real_t t[])
 User definition of enthalpy to temperature conversion. More...
void cs_user_physical_properties_t_to_h (cs_domain_t *domain, const cs_zone_t *z, bool z_local, const cs_real_t t[], cs_real_t h[])
 User definition of temperature to enthalpy conversion. More...
void cs_user_physical_properties_turb_viscosity (cs_domain_t *domain)
 User modification of the turbulence viscosity. More...
void cs_user_physical_properties_td_pressure (cs_real_t *td_p)
 User function to define a custom law for the thermodynamic pressure. More...
void cs_user_porosity (cs_domain_t *domain)
 Compute the porosity (volume factor $ \epsilon $ when the porosity model is activated. (cs_glob_porous_model > 0). More...
void cs_user_postprocess_writers (void)
 Define post-processing writers. More...
void cs_user_postprocess_meshes (void)
 Define post-processing meshes. More...
void cs_user_postprocess_probes (void)
 Define monitoring probes and profiles. More...
void cs_user_postprocess_values (const char *mesh_name, int mesh_id, int cat_id, cs_probe_set_t *probes, cs_lnum_t n_cells, cs_lnum_t n_i_faces, cs_lnum_t n_b_faces, cs_lnum_t n_vertices, const cs_lnum_t cell_list[], const cs_lnum_t i_face_list[], const cs_lnum_t b_face_list[], const cs_lnum_t vertex_list[], const cs_time_step_t *ts)
 User function for output of values on a post-processing mesh. More...
void cs_user_postprocess_activate (int nt_max_abs, int nt_cur_abs, double t_cur_abs)
 Override default frequency or calculation end based output. More...
void cs_user_rad_transfer_absorption (const int bc_type[], cs_real_t ck[])
 Absorption coefficient for radiative module. More...
void cs_user_rad_transfer_net_flux (const int itypfb[], const cs_real_t twall[], const cs_real_t qincid[], const cs_real_t xlam[], const cs_real_t epa[], const cs_real_t eps[], const cs_real_t ck[], cs_real_t net_flux[])
 Compute the net radiation flux. More...
void cs_user_radiative_transfer_bcs (cs_domain_t *domain, const int bc_type[], int isothp[], cs_real_t *tmin, cs_real_t *tmax, cs_real_t *tx, const cs_real_t dt[], const cs_real_t thwall[], const cs_real_t qincid[], cs_real_t hfcnvp[], cs_real_t flcnvp[], cs_real_t xlamp[], cs_real_t epap[], cs_real_t epsp[], cs_real_t textp[])
 User definition of radiative transfer boundary conditions. More...
int cs_user_solver_set (void)
 Set user solver. More...
void cs_user_solver (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities)
 Main call to user solver. More...
void cs_user_source_terms (cs_domain_t *domain, int f_id, cs_real_t *st_exp, cs_real_t *st_imp)
 Additional user-defined source terms for variable equations (momentum, scalars, turbulence...). More...
void cs_user_time_table (void)
 Define time tables using C API. This function is called at the begin of the simulation only. More...
void cs_user_turbomachinery (void)
 Define rotor/stator model. More...
void cs_user_turbomachinery_rotor (void)
 Define rotor axes, associated cells, and rotor/stator faces. More...
void cs_user_turbomachinery_set_rotation_velocity (void)
 Define rotation velocity of rotor. More...
void cs_user_wall_condensation (int iappel)
 Source terms associated at the boundary faces and the neighboring cells with surface condensation. More...
void cs_user_zones (void)
 Define volume and surface zones. More...
◆ cs_user_1d_wall_thermal()
void cs_user_1d_wall_thermal ( int  iappel)
[in]iappelCall number:
  • 1: first call during the initialization (called once) Setting the number of cells nfpt1d.
  • 2: second call during the initialization (called once) Filling ifpt1d, nppt1d, eppt1d and rgpt1d arrays.
  • 3: called at each time step Filling iclt1d, xlmbt1, rcpt1d and dtpt1d arrays.
◆ cs_user_atmo_1d_rad_prf()
void cs_user_atmo_1d_rad_prf ( cs_real_t  preray[],
cs_real_t  temray[],
cs_real_t  romray[],
cs_real_t  qvray[],
cs_real_t  qlray[],
cs_real_t  ncray[],
cs_real_t  aeroso[]
[in,out]preraypressure vertical profile
[in,out]temrayreal temperature vertical profile
[in,out]romraydensity vertical profile
[in,out]qvraywater vapor content vertical profile
[in,out]qlraywater liquid content vertical profile
[in,out]ncraydroplets density vertical profile
[in,out]aerosoaerosol concentration vertical profile
◆ cs_user_boundary_conditions()
void cs_user_boundary_conditions ( cs_domain_t *  domain,
int  bc_type[]
[in,out]bc_typeboundary face types
This function is called at each times step. The icodcl and rcodcl arrays are pre-initialized based on default and GUI-defined definitions, and may be modified here.
For a given variable field f, and a given face "face_id", these arrays may be used as follows:
  • Boundary condition type code given at: f->bc_coeffs->icodcl[face_id]
  • Dirichlet value defined at: f->bc_coeffs->rcodcl1[face_id]
  • Interior exchange coefficient (infinite if no exchange) at: f->bc_coeffs->rcodcl2[face_id]
  • Flux density defined at: f->bc_coeffs->rcodcl3[face_id]
For vector or tensor fields, these arrays are not interleaved, so for a given face "face_id" and field component "comp_id", access is as follows (where n_b_faces is domain->mesh->n_b_faces):
f->bc_coeffs->rcodcl1[n_b_faces*comp_id + face_id]
f->bc_coeffs->rcodcl2[n_b_faces*comp_id + face_id]
f->bc_coeffs->rcodcl3[n_b_faces*comp_id + face_id]
The icodcl values are common to all components, so icodcl values are defined as for a scalar.
◆ cs_user_boundary_conditions_ale()
void cs_user_boundary_conditions_ale ( cs_domain_t *  domain,
int  bc_type[],
int  ale_bc_type[],
int  impale[]
See Boundary conditions for ALE (Arbitrary Lagrangian Eulerian) for additional details.
[in,out]ale_bc_typeboundary face types for mesh velocity (see cs_boundary_ale_subtype_bits_t)
[in]impaleindicator for prescribed node displacement (0 or 1)
◆ cs_user_boundary_conditions_setup()
void cs_user_boundary_conditions_setup ( cs_domain_t *  domain)
This function is called just before cs_user_finalize_setup, and boundary conditions can be defined in either of those functions, depending on whichever is considered more readable or practical for a given use.
◆ cs_user_cathare_coupling()
void cs_user_cathare_coupling ( void  )
This is done by calling the cs_sys_coupling_add function for each
◆ cs_user_extra_operations()
void cs_user_extra_operations ( cs_domain_t *  domain)
This function has a very general purpose, although it is recommended to handle mainly postprocessing or data-extraction type operations.
◆ cs_user_extra_operations_finalize()
void cs_user_extra_operations_finalize ( cs_domain_t *  domain)
◆ cs_user_extra_operations_initialize()
void cs_user_extra_operations_initialize ( cs_domain_t *  domain)
This function is called at beginning of the computation (restart or not) before the time step loop.
This is intended to initialize or modify (when restarted) variable and time step values.
◆ cs_user_finalize_setup()
void cs_user_finalize_setup ( cs_domain_t *  domain)
For CDO schemes, this function concludes the setup of properties, equations, source terms...
◆ cs_user_fsi_external_cvg()
void cs_user_fsi_external_cvg ( const cs_domain_t *  domain,
int *  cvg_status,
cs_real_t *  residual
Compute converge status and residual of the external coupling Convergence status: 0 - external coupling has not converged 1 - external coupling has converged
[in]domainpointer to a cs_domain_t structure
[in]epsilonconvergence criterion
[out]cvg_statusconvergence status
[out]residualvalue of the residual
◆ cs_user_fsi_external_displacement()
void cs_user_fsi_external_displacement ( const cs_domain_t *  domain,
const cs_real_3_t *  b_stress,
cs_real_3_t *  disaple
[in]b_stresspointer to boundary stress array
[in,out]disaplepointer to mesh_displacement array
◆ cs_user_fsi_structure_define()
void cs_user_fsi_structure_define ( int  is_restart,
int  n_structs,
int *  plot,
cs_time_control_t *  plot_time_control,
cs_real_t *  aexxst,
cs_real_t *  bexxst,
cs_real_t *  cfopre,
[in]is_restartindicate if computation is restarted
[in]n_structsnumber of mobile structures
[in,out]plot;monitoring format mask 0: no plot 1: plot to text (.dat) format 2: plot to .csv format 3: plot to both formats
[in,out]plot_time_controlplot time output frequency control
[in,out]aexxstcoefficient for predicted displacement
[in,out]bexxstcoefficient for predicted displacement
[in,out]cfoprecoefficient for predicted force
[in,out]xstr0initial displacement per structure
[in,out]vstr0initial velocity per structure
[in,out]xstreqdisplacement of initial mesh relative to structures position at equilibrium
◆ cs_user_fsi_structure_num()
void cs_user_fsi_structure_num ( cs_domain_t *  domain,
Structure numbers associated to a given face have the following values:
  • -i where coupled to i-th (1-to n) external (code_aster) structure.
  • 0 where not coupled with an internal or external structure.
  • i where coupled to i-th (1-to n) internal (mass-spring) structure.
[in,out]structure_numstructure id associated to each face
[in,out]structure_typstructure type associated to each face
◆ cs_user_fsi_structure_values()
void cs_user_fsi_structure_values ( int  n_structs,
const cs_time_step_t *  ts,
cs_real_t  dtstr[]
[in]tstime step structure
[in]xstreqdisplacement of initial mesh rel. to equilibrium
[in]xstrstructural displacement
[in]vstrstructural velocity
[in,out]xmstrumatrix of structural mass
[in,out]xcstrumatrix of structural friction
[in,out]xkstrumatrix of structural stiffness
[in,out]forstrforces acting on structures (take forces)
[in,out]dtstrstructural time step
◆ cs_user_head_losses()
void cs_user_head_losses ( const cs_zone_t *  zone,
cs_real_t  cku[][6]
Head loss tensor coefficients for each cell are organized as follows: ck11, ck22, ck33, ck12, ck23, ck13.
Diagonal coefficients must be positive; the calculation may diverge if this is not the case.
[in]zonepointer to zone structure
[in,out]ckuhead loss coefficients
◆ cs_user_hgn_thermo_relax_time()
void cs_user_hgn_thermo_relax_time ( const cs_mesh_t *  mesh,
const cs_real_t *  alpha_eq,
const cs_real_t *  y_eq,
const cs_real_t *  z_eq,
const cs_real_t *  ei,
const cs_real_t *  v,
cs_real_t *  relax_tau
[in]meshpointer to mesh
[in]alpha_eqequilibrium volume fraction
[in]y_eqequilibrium mass fraction
[in]z_eqequilibrium energy fraction
[in]eispecific internal energy
[in]vspecific volume
[in]relax_taurelaxation time scale towards equilibrium
◆ cs_user_initial_conditions()
void cs_user_initial_conditions ( cs_domain_t *  domain)
This function is not yet called by code_saturne, use cs_user_initialization for the time being This function is called before the beginning of the computation allowing an overload of the GUI defined initialization (called just after cs_gui_initial_conditions).
◆ cs_user_initialization()
void cs_user_initialization ( cs_domain_t *  domain)
◆ cs_user_internal_coupling()
void cs_user_internal_coupling ( void  )
Options are usually defined using cs_internal_coupling_add_entity.
◆ cs_user_join()
void cs_user_join ( void  )
◆ cs_user_linear_solvers()
void cs_user_linear_solvers ( void  )
This function is called at the setup stage, once user and most model-based fields are defined.
Available native iterative linear solvers include conjugate gradient, Jacobi, BiCGStab, BiCGStab2, and GMRES. For symmetric linear systems, an algebraic multigrid solver is available (and recommended).
External solvers may also be setup using this function, the cs_sles_t mechanism allowing such through user-define functions.
◆ cs_user_matrix_tuning()
void cs_user_matrix_tuning ( void  )
◆ cs_user_mesh_bad_cells_tag()
void cs_user_mesh_bad_cells_tag ( cs_mesh_t *  mesh,
cs_mesh_quantities_t *  mesh_quantities
[in,out]meshpointer to a cs_mesh_t structure
[in,out]mesh_quantitiespointer to a cs_mesh_quantities_t structure
◆ cs_user_mesh_boundary()
void cs_user_mesh_boundary ( cs_mesh_t *  mesh)
◆ cs_user_mesh_cartesian_define()
void cs_user_mesh_cartesian_define ( void  )
◆ cs_user_mesh_input()
void cs_user_mesh_input ( void  )
◆ cs_user_mesh_modify()
void cs_user_mesh_modify ( cs_mesh_t *  mesh)
◆ cs_user_mesh_modify_partial()
void cs_user_mesh_modify_partial ( cs_mesh_t *  mesh,
◆ cs_user_mesh_restart_mode()
void cs_user_mesh_restart_mode ( void  )
By default, in case of restart, if a "restart/mesh_input.csm" file is present, it will be read and proprocessing will be skipped.
This behavior may be changed in the GUI (in the "Mesh" section, unchecking "Use unmodified checkpoint mesh in case of restart"), or by calling cs_preprocessor_data_set_restart_mode in this function.
◆ cs_user_mesh_save()
void cs_user_mesh_save ( cs_mesh_t *  mesh)
By default, mesh is saved when modified.
◆ cs_user_mesh_smoothe()
void cs_user_mesh_smoothe ( cs_mesh_t *  mesh)
Mesh smoothing.
◆ cs_user_mesh_warping()
void cs_user_mesh_warping ( void  )
◆ cs_user_model()
void cs_user_model ( void  )
This function is called at the earliest stages of the data setup, so field ids are not available yet.
◆ cs_user_numbering()
void cs_user_numbering ( void  )
◆ cs_user_parallel_io()
void cs_user_parallel_io ( void  )
◆ cs_user_paramedmem_define_couplings()
void cs_user_paramedmem_define_couplings ( void  )
◆ cs_user_paramedmem_define_fields()
void cs_user_paramedmem_define_fields ( void  )
◆ cs_user_paramedmem_define_meshes()
void cs_user_paramedmem_define_meshes ( void  )
◆ cs_user_parameters()
void cs_user_parameters ( cs_domain_t *  domain)
At the calling point of this function, most model-related most variables and other fields have been defined, so specific settings related to those fields may be set here.
At this stage, the mesh is not built or read yet, so associated data such as field values are not accessible yet, though pending mesh operations and some fields may have been defined.
◆ cs_user_partition()
void cs_user_partition ( void  )
◆ cs_user_periodicity()
void cs_user_periodicity ( void  )
◆ cs_user_physical_properties()
void cs_user_physical_properties ( cs_domain_t *  domain)
◆ cs_user_physical_properties_h_to_t()
void cs_user_physical_properties_h_to_t ( cs_domain_t *  domain,
const cs_zone_t *  z,
bool  z_local,
cs_real_t  t[]
This allows overwriting the solver defaults if necessary.
This function may be called on a per-zone basis, so as to allow different conversion relations in zones representing solids or different fluids.
[in]zzone (volume or boundary) applying to current call
[in]z_localif true, h and t arrays are defined in a compact (contiguous) manner for this zone only; if false, h and t are defined on the zone's parent location (usually all cells or boundary faces)
[in]henthalpy values
[in,out]ttemperature values
◆ cs_user_physical_properties_t_to_h()
void cs_user_physical_properties_t_to_h ( cs_domain_t *  domain,
bool  z_local,
cs_real_t  h[]
[in]htemperature values
[in,out]tenthalpy values
◆ cs_user_physical_properties_td_pressure()
void cs_user_physical_properties_td_pressure ( cs_real_t *  td_p)
Allows to define a custom law for the constant uniform thermodynamic pressure (whenn cs_velocity_pressure_model_t::idilat = 3 or cs_fluid_properties_t::ipthrm = 1).
The density is then updated (in cs_compute_thermo_pressure_density.c) as:
\[\rho^{n+1} =\rho^{n} \cdot \frac{P_{th}^{n+1}}{P_{th}^{n}}\]
[in,out]td_pUpdated value of the thermodynamic pressure
◆ cs_user_physical_properties_turb_viscosity()
void cs_user_physical_properties_turb_viscosity ( cs_domain_t *  domain)
Turbulent viscosity $ \mu_T $ (kg/(m s)) can be modified. You can access the field by its name.
◆ cs_user_porosity()
void cs_user_porosity ( cs_domain_t *  domain)
This function is called at the beginning of the simulation only.
◆ cs_user_postprocess_activate()
void cs_user_postprocess_activate ( int  nt_max_abs,
int  nt_cur_abs,
double  t_cur_abs
This allows fine-grained control of activation or deactivation,
[in]nt_max_absmaximum time step number
[in]nt_cur_abscurrent time step number
[in]t_cur_absabsolute time at the current time step
◆ cs_user_postprocess_meshes()
void cs_user_postprocess_meshes ( void  )
The main post-processing meshes may be configured, and additional post-processing meshes may be defined as a subset of the main mesh's cells or faces (both interior and boundary).
◆ cs_user_postprocess_probes()
void cs_user_postprocess_probes ( void  )
Profiles are defined as sets of probes.
◆ cs_user_postprocess_values()
void cs_user_postprocess_values ( const char *  mesh_name,
int  mesh_id,
int  cat_id,
cs_probe_set_t *  probes,
cs_lnum_t  n_cells,
[in]mesh_namename of the output mesh for the current call
[in]mesh_idid of the output mesh for the current call
[in]cat_idcategory id of the output mesh for the current call
[in]probespointer to associated probe set structure if the mesh is a probe set, null otherwise
[in]n_cellslocal number of cells of post_mesh
[in]n_i_faceslocal number of interior faces of post_mesh
[in]n_b_faceslocal number of boundary faces of post_mesh
[in]n_verticeslocal number of vertices faces of post_mesh
[in]cell_listlist of cells (0 to n-1) of post-processing mesh
[in]i_face_listlist of interior faces (0 to n-1) of post-processing mesh
[in]b_face_listlist of boundary faces (0 to n-1) of post-processing mesh
[in]vertex_listlist of vertices (0 to n-1) of post-processing mesh
[in]tstime step status structure, or nullptr
◆ cs_user_postprocess_writers()
void cs_user_postprocess_writers ( void  )
The default output format and frequency may be configured, and additional post-processing writers allowing outputs in different formats or with different format options and output frequency than the main writer may be defined.
◆ cs_user_rad_transfer_absorption()
void cs_user_rad_transfer_absorption ( const int  bc_type[],
cs_real_t  ck[]
It is necessary to define the value of the fluid's absorption coefficient Ck.
This value is defined automatically for specific physical models, such as gas and coal combustion, so this function is not used by these models.
For a transparent medium, the coefficient should be set to 0.
In the case of the P-1 model, we check that the optical length is at least of the order of 1.
[in]bc_typeboundary face types
[out]ckmedium's absorption coefficient (zero if transparent)
◆ cs_user_rad_transfer_net_flux()
void cs_user_rad_transfer_net_flux ( const int  itypfb[],
The density of net radiation flux must be calculated consistently with the boundary conditions of the intensity. The density of net flux is the balance between the radiative emiting part of a boundary face (and not the reflecting one) and the radiative absorbing part.
[in]twallinside current wall temperature (K)
[in]qincidradiative incident flux (W/m2)
[in]xlamconductivity (W/m/K)
[in]epathickness (m)
[in]epsemissivity (>0)
[in]ckabsorption coefficient
[out]net_fluxnet flux (W/m2)
◆ cs_user_radiative_transfer_bcs()
void cs_user_radiative_transfer_bcs ( cs_domain_t *  domain,
int  isothp[],
cs_real_t *  tmin,
cs_real_t *  tmax,
cs_real_t *  tx,
cs_real_t  hfcnvp[],
cs_real_t  flcnvp[],
cs_real_t  xlamp[],
cs_real_t  epap[],
cs_real_t  epsp[],
cs_real_t  textp[]
See Examples of data settings for radiative transfers for examples.
Warning
the temperature unit here is the Kelvin
For each boundary face face_id, a specific output (logging and postprocessing) class id may be assigned. This allows realizing balance sheets by treating them separately for each zone. By default, the output class id is set to the general (input) zone id associated to a face.
To access output class ids (both for reading and modifying), use the cs_boundary_zone_face_class_id function. The zone id values are arbitrarily chosen by the user, but must be positive integers; very high numbers may also lead to higher memory consumption.
Wall characteristics
The following face characteristics must be set:
  • isothp(face_id) boundary face type
    • CS_BOUNDARY_RAD_WALL_GRAY: Gray wall with temperature based on fluid BCs
    • CS_BOUNDARY_RAD_WALL_GRAY_EXTERIOR_T: Gray wall with fixed outside temperature
    • CS_BOUNDARY_RAD_WALL_REFL_EXTERIOR_T: Reflecting wall with fixed outside temperature
    • CS_BOUNDARY_RAD_WALL_GRAY_COND_FLUX: Gray wall with fixed conduction flux
    • CS_BOUNDARY_RAD_WALL_REFL_COND_FLUX: Reflecting wall with fixed conduction flux
Depending on the value of isothp, other values may also need to be set:
  • rcodcl = conduction flux
  • epsp = emissivity
  • xlamp = conductivity (W/m/K)
  • epap = thickness (m)
  • textp = outside temperature (K)
[in]isothpboundary face type for radiative transfer
[out]tminmin allowed value of the wall temperature
[out]tmaxmax allowed value of the wall temperature
[in]txrelaxation coefficient (0 < tx < 1)
[in]dttime step (per cell)
[in]thwallinside current wall temperature (K)
[in]hfcnvpconvective exchange coefficient (W/m2/K)
[in]flcnvpconvective flux (W/m2)
[out]xlampconductivity (W/m/K)
[out]epapthickness (m)
[out]epspemissivity (>0)
[out]textpoutside temperature (K)
◆ cs_user_saturne_coupling()
void cs_user_saturne_coupling ( void  )
This is done by calling the cs_sat_coupling_define function for each coupling to add.
◆ cs_user_scaling_elec()
void cs_user_scaling_elec ( const cs_mesh_t *  mesh,
const cs_mesh_quantities_t *  mesh_quantities,
cs_real_t *  dt
[in]dttime step per cell
These options allow defining the time step synchronization policy, as well as a time step multiplier.
◆ cs_user_solver()
void cs_user_solver ( const cs_mesh_t *  mesh,
◆ cs_user_solver_set()
int cs_user_solver_set ( void  )
Set user solver.
1 if user solver is called, 0 otherwise
◆ cs_user_source_terms()
void cs_user_source_terms ( cs_domain_t *  domain,
int  f_id,
cs_real_t *  st_exp,
cs_real_t *  st_imp
This function is called at each time step, for each relevant field. It is therefore necessary to test the value of the field id or name to separate the treatments of the different variables.
The additional source term is decomposed into an explicit part (st_exp) and an implicit part (st_imp) that must be provided here. The resulting equation solved by the code for a scalar f is:
\[ \rho*volume*\frac{df}{dt} + .... = st\_imp*f + st\_exp \]
Note that st_exp and st_imp are defined after the Finite Volume integration over the cells, so they include the "volume" term. More precisely:
  • st_exp is expressed in kg.[var]/s, where [var] is the unit of the variable. Its dimension is the one of the variable (3 for vectors)
  • st_imp is expressed in kg/s. Its dimension is 1 for scalars, 3x3 for vectors.
The st_exp and st_imp arrays are already initialized to 0 (or a value defined through the GUI or defined by a model) before entering the function. It is generally not useful to reset them here.
For stability reasons, code_saturne will not add -st_imp directly to the diagonal of the matrix, but Max(-st_imp,0). This way, the st_imp term is treated implicitely only if it strengthens the diagonal of the matrix. However, when using the second-order in time scheme, this limitation cannot be done anymore and -st_imp is added directly. The user should therefore check for the negativity of st_imp.
When using the second-order in time scheme, one should supply:
  • st_exp at time n
  • st_imp at time n+1/2
Warning
If the variable is a temperature, the resulting equation solved is:
rho*Cp*volume*dT/dt + .... = st_imp*T + st_exp
  • st_exp is expressed in W
  • st_imp is expressed in W/K
Steep source terms
In case of a complex, non-linear source term, say F(f), for variable f, the easiest method is to implement the source term explicitly.
df/dt = .... + F(f(n)) where f(n) is the value of f at time tn, the beginning of the time step.
This yields: st_exp = volume*F(f(n)) st_imp = 0
However, if the source term is potentially steep, this fully explicit method will probably generate instabilities. It is therefore wiser to partially implicit the term by writing:
df/dt = .... + dF/df*f(n+1) - dF/df*f(n) + F(f(n))
This yields: st_exp = volume*( F(f(n)) - dF/df*f(n) ) st_imp = volume*dF/df
[in]f_idfield id of the variable
[out]st_expexplicit source term
[out]st_impimplicit part of the source term
◆ cs_user_syrthes_coupling()
void cs_user_syrthes_coupling ( void  )
This is done by calling the cs_syr_coupling_define function for each coupling to add.
◆ cs_user_syrthes_coupling_volume_h()
void cs_user_syrthes_coupling_volume_h ( int  coupling_id,
const char *  syrthes_name,
cs_lnum_t  n_elts,
cs_real_t  h_vol[]
[in]coupling_idSyrthes coupling id
[in]syrthes_namename of associated Syrthes instance
[in]n_eltsnumber of associated cells
[in]elt_idsassociated cell ids
[out]h_volassociated exchange coefficient (size: n_elts)
◆ cs_user_time_moments()
void cs_user_time_moments ( void  )
This function is called at the setup stage, once user and most model-based fields are defined, and before fine control of field output options is defined.
◆ cs_user_time_table()
void cs_user_time_table ( void  )
◆ cs_user_turbomachinery()
void cs_user_turbomachinery ( void  )
◆ cs_user_turbomachinery_rotor()
void cs_user_turbomachinery_rotor ( void  )
◆ cs_user_turbomachinery_set_rotation_velocity()
void cs_user_turbomachinery_set_rotation_velocity ( void  )
◆ cs_user_wall_condensation()
void cs_user_wall_condensation ( int  iappel)
This function fills the condensation source terms for each variable at the cell center associated to the boundary faces identifed in the mesh. The fluid exchange coefficient is computed with a empirical law to be imposed at the boundary face where the condensation phenomenon occurs.
This user function is called which allows the setting of $ \gamma_{\mbox{cond}} $ the condensation source term.
This function fills the condensation source term array gamma_cond adding to the following equations:
  • The equation for mass conservation:
    \[ D\frac{rho}{dt} + divs \left( \rho \vect{u}^n\right) = \Gamma _{cond}
  • The equation for a variable $\Phi $:
    \[ D\frac{\phi}{dt} = ... + \Gamma _{cond}*(\Phi _i - \Phi)
discretized as below:
\[ \rho*\dfrac{\Phi^{n+1}-\Phi^{n}}/dt = ...
                           + \Gamma _{cond}*(\Phi _i - \Phi^{n+1})
Remarks
  • $ \Phi _i $ is the value of $ \Phi $ associated to the injected condensation rate.
    With 2 options are available:
    • the condensation rate is injected with the local value of variable $ \Phi = \Phi ^{n+1}$ in this case the $ \Phi $ variable is not modified.
    • the condensation rate is injected with a specific value for $ \Phi = \Phi _i $ the specified value given by the user.
Usage
The three stages in the code where this User subroutine is called (with
iappel = 1, 2 and 3
iappel = 1
  • Calculation of the number of cells where a mass source term is imposed: ncesmp Called once at the beginning of the calculation
iappel = 2
  • Identification of the cells where a mass source term is imposed: array icesmp(ncesmp) Called once at the beginning of the calculation
iappel = 3
  • Calculation of the values of the mass source term Called at each time step
specific variables to define with is user subroutine
  • ifbpcd(ieltcd): identification of the faces where a condensation source term is imposed.
  • itypcd(ieltcd,ivar): type of treatment for variable ivar in the ieltcd cell with condensation source term.
    • itypcd = 0 – * injection of ivar at local value
    • itypcd = 1 – * injection of ivar at user specified value.
  • spcond(ielscd,ipr): value of the injection condensation rate gamma_cond (kg/m3/s) in the ieltcd cell with condensation source term.
  • spcond(ieltcd,ivar): specified value for variable ivar associated to the injected condensation in the ieltcd cell with a condensation source term except for ivar=ipr.
Remarks
  • For each face where a condensation source term is imposed ielscd in [1;nfbpcd]), ifbpcd(ielscd) is the global index number of the corresponding face (ifbpcd(ieltcd) in [1;ncel]).
  • if itypcd(ieltcd,ivar)=0, spcond(ielpcd,ivar) is not used.
  • if spcond(ieltcd,ipr)<0, mass is removed from the system, therefore Code_Saturna automatically considers f_i=f^(n+1), whatever the values of itypcd or smacel specified by the user
Examples of settings for boundary condensation mass source terms
Examples are available here.
[in]iappelindicates which at which stage the routine is
◆ cs_user_zones()
void cs_user_zones ( void  )
See Element selection criteria for details on selection criteria.
