cs_porous_model.h File Reference
#include "base/cs_base.h"
#include "mesh/cs_mesh.h"
#include "fvm/fvm_nodal.h"
+ Include dependency graph for cs_porous_model.h:
Classes
struct  cs_porous_model_extra_faces
void cs_porous_map_mesh_quantites_f_and_compute (void)
 Map fluid mesh quantities. More...
void cs_porous_model_set_model (int porous_model)
void cs_porous_model_init_disable_flag (void)
 Initialize disable_flag. More...
void cs_porous_model_set_has_disable_flag (int flag)
 Set (unset) has_disable_flag. More...
void cs_porous_model_init_fluid_quantities (void)
 Init fluid quantities. More...
void cs_porous_model_mesh_quantities_update (void)
 Compute solid quantities. More...
void cs_porous_model_auto_face_porosity (void)
 Automatic computation of the face porosity and factors. More...
void cs_porous_model_fluid_surfaces_preprocessing (void)
 Preprocess the fluid surfaces. More...
void cs_porous_model_clip (void)
void cs_porous_model_convert_cell_to_boundary (const cs_lnum_t n_ib_cells, const cs_lnum_t ibcell_cells[])
 Convert cell array to boundary array. More...
void cs_porous_model_postprocess_meshes (void)
 Initialize porous model arrays. More...
void cs_porous_model_post_immmersed_plane (const cs_lnum_t n_ib_cells, const cs_lnum_t n_ib_cells_filt, const cs_lnum_t ib_cells_filt[], const cs_lnum_t n_glob_vtx, const cs_lnum_t ibcell_cells[], const cs_lnum_t vtx_ids[][2], const cs_lnum_t w_vtx_idx[], const cs_lnum_t face_vertex_idx[], const cs_real_t w_vtx[][3])
 Post-processes the immersed boundary (ib) planes for display on paraview. More...
cs_porous_model_extra_faces * cs_glob_porous_model_extra_faces
int cs_glob_porous_model
cs_mesh_quantities_t * cs_glob_mesh_quantities_f
◆ cs_porous_map_mesh_quantites_f_and_compute()
void cs_porous_map_mesh_quantites_f_and_compute ( void  )
◆ cs_porous_model_auto_face_porosity()
void cs_porous_model_auto_face_porosity ( void  )
This is useful for the integral porous model.
◆ cs_porous_model_clip()
void cs_porous_model_clip ( void  )
◆ cs_porous_model_convert_cell_to_boundary()
void cs_porous_model_convert_cell_to_boundary ( const cs_lnum_t  n_ib_cells,
[in]n_ib_cellsimmersed cell number
[in]ibcell_cellsimmersed cell to cell connectivity
◆ cs_porous_model_fluid_surfaces_preprocessing()
void cs_porous_model_fluid_surfaces_preprocessing ( void  )
◆ cs_porous_model_init_disable_flag()
void cs_porous_model_init_disable_flag ( void  )
◆ cs_porous_model_init_fluid_quantities()
void cs_porous_model_init_fluid_quantities ( void  )
◆ cs_porous_model_mesh_quantities_update()
void cs_porous_model_mesh_quantities_update ( void  )
◆ cs_porous_model_post_immmersed_plane()
void cs_porous_model_post_immmersed_plane ( const cs_lnum_t  n_ib_cells,
[in]n_ib_cellsib cell number
[in]n_ib_cells_filtib cell number after filtering
[in]ib_cells_filtindices of the filtered cells
[in]n_glob_vtxtotal vertex number
[in]ibcell_cellsconnectivity ib_cell->cells
[in]ibcell_cells_filtconnectivity ib_cell->cells after filtering
[in]vtx_idsvertex ids on both sides of a IB vertex (v0<v1)
[in]w_vtx_idxib vertex indexes
[in]face_vertex_idxvertex indexes of the ib faces
[in]w_vtxib vertex coordinates
◆ cs_porous_model_postprocess_meshes()
void cs_porous_model_postprocess_meshes ( void  )
◆ cs_porous_model_set_has_disable_flag()
void cs_porous_model_set_has_disable_flag ( int  flag)
[in]flag1: on, 0: off
◆ cs_porous_model_set_model()
void cs_porous_model_set_model ( int  porous_model)
◆ cs_glob_mesh_quantities_f
cs_mesh_quantities_t* cs_glob_mesh_quantities_f
extern
◆ cs_glob_porous_model
extern
◆ cs_glob_porous_model_extra_faces
cs_porous_model_extra_faces* cs_glob_porous_model_extra_faces
extern
