cs_syr_coupling.h File Reference
#include "fvm/fvm_defs.h"
#include "base/cs_base.h"
#include "base/cs_zone.h"
+ Include dependency graph for cs_syr_coupling.h:
void cs_syr_coupling_define (const char *syrthes_name, const char *boundary_criteria, const char *volume_criteria, char projection_axis, bool allow_nonmatching, float tolerance, int verbosity, int visualization)
 Define new SYRTHES coupling. More...
void cs_syr_coupling_add_zone (const char *syrthes_name, const cs_zone_t *z)
 Associated a zone to a defined SYRTHES coupling. More...
void cs_syr_coupling_all_init (void)
void cs_syr_coupling_all_finalize (void)
int cs_syr_coupling_n_couplings (void)
void cs_syr_coupling_set_conservativity (int flag)
void cs_syr_coupling_set_explicit_treatment (void)
void cs_syr_coupling_set_time_sync_flag (int cpl_id, int flag)
 Set time synchronization mode for a given SYRTHES coupling. More...
void cs_syr_coupling_log_setup (void)
 Log SYRTHES coupling setup information. More...
void cs_syr_coupling_init_meshes (void)
 Create coupled meshes and setup PLE locator for Syrthes couplings. More...
int cs_syr_coupling_is_surf (int cpl_id)
 Check if the given SYRTHES coupling number is a surface couplings. More...
void cs_syr_coupling_recv_boundary (const int nvar, int bc_type[])
 Read boundary field/variable values relative to a SYRTHES coupling. More...
void cs_syr_coupling_send_boundary (const cs_real_t h_wall[], cs_real_t v_fluid[])
 Send field/variable values relative to a SYRTHES coupling. More...
void cs_syr_coupling_exchange_volume (void)
 Exchange volume values relative to a SYRTHES coupling. More...
void cs_syr_coupling_volume_source_terms (int field_id, cs_real_t st_exp[], cs_real_t st_imp[])
 Compute the source term (implicit and/or explicit part) for a volume coupling with SYRTHES. More...
cs_lnum_t cs_syr_coupling_n_elts (int cpl_id, int mode)
 Get number of coupled elements with SYRTHES. More...
void cs_syr_coupling_elt_ids (int cpl_id, int mode, cs_lnum_t elt_ids[])
 Get local ids of elements coupled with SYRTHES. More...
void cs_syr_coupling_recv_tsolid (int cpl_id, int mode, cs_real_t t_solid[])
 Receive coupling variables from SYRTHES. More...
void cs_syr_coupling_send_tf_hf (int cpl_id, int mode, const cs_lnum_t elt_ids[], cs_real_t t_fluid[], cs_real_t h_fluid[])
 Send coupling variables to SYRTHES. More...
void cs_syr_coupling_recv_tf_hf (int cpl_id, int mode, const cs_lnum_t elt_ids[], cs_real_t t_fluid[], cs_real_t h_fluid[])
 Receive coupling variables (Tf,hf) from code_saturne (called by CDO thermal solver). More...
void cs_syr_coupling_send_tsolid (int cpl_id, int mode, const cs_real_t t_solid[])
 Send coupling variables (Ts) to code_saturne (called by CDO thermal solver). More...
int cs_syr_coupling_is_bnd_zone_coupled (const cs_zone_t *z)
 Check if a boundary zone is coupled. More...
◆ cs_syr_coupling_add_zone()
void cs_syr_coupling_add_zone ( const char *  syrthes_name,
const cs_zone_t *  z
[in]syrthes_namematching SYRTHES application name
[in]zpointer to matching zone (boundary or volume)
◆ cs_syr_coupling_all_finalize()
void cs_syr_coupling_all_finalize ( void  )
◆ cs_syr_coupling_all_init()
void cs_syr_coupling_all_init ( void  )
◆ cs_syr_coupling_define()
void cs_syr_coupling_define ( const char *  syrthes_name,
const char *  boundary_criteria,
const char *  volume_criteria,
float  tolerance,
int  verbosity,
int  visualization
[in]boundary_criteriasurface selection criteria, or nullptr
[in]volume_criteriavolume selection criteria, or nullptr
[in]projection_axisx', 'y', or 'y' for 2D projection axis (case independent), or ' ' for standard 3D coupling
[in]allow_nonmatchingallow nearest-neighbor mapping where matching within tolerance is not available (useful when meshes have a different level of detail)
[in]toleranceaddition to local extents of each element extent = base_extent * (1 + tolerance)
[in]verbosityverbosity level
[in]visualizationvisualization output level (0 or 1)
In the case of a single code_saturne and single SYRTHES instance, the 'syrthes_name' argument is ignored, as there is only one matching possibility.
In case of multiple couplings, a coupling will be matched with available SYRTHES instances based on the 'syrthes_name' argument.
◆ cs_syr_coupling_elt_ids()
void cs_syr_coupling_elt_ids ( int  cpl_id,
int  mode,
cs_lnum_t  elt_ids[]
[in]cpl_idcoupling id
[in]mode0 for boundary, 1 for volume
[out]elt_idsids of coupled elements (preallocated)
◆ cs_syr_coupling_exchange_volume()
void cs_syr_coupling_exchange_volume ( void  )
◆ cs_syr_coupling_init_meshes()
void cs_syr_coupling_init_meshes ( void  )
◆ cs_syr_coupling_is_bnd_zone_coupled()
int cs_syr_coupling_is_bnd_zone_coupled ( const cs_zone_t *  z)
1 if coupled 0 if not.
[in]zboundary zone pointer
◆ cs_syr_coupling_is_surf()
int cs_syr_coupling_is_surf ( int  cpl_id)
[in]cpl_idmatching SYRTHES coupling id
1 if the coupling includes the surface, 0 otherwise.
◆ cs_syr_coupling_log_setup()
void cs_syr_coupling_log_setup ( void  )
◆ cs_syr_coupling_n_couplings()
int cs_syr_coupling_n_couplings ( void  )
◆ cs_syr_coupling_n_elts()
cs_lnum_t cs_syr_coupling_n_elts ( int  cpl_id,
int  mode
number of coupled elements for this coupling
◆ cs_syr_coupling_recv_boundary()
void cs_syr_coupling_recv_boundary ( const int  nvar,
int  bc_type[]
[in]nvarnumber of variables
[in]bc_typeboundary condition type
[out]icodclboundary condition codes
[out]rcodclboundary condition values
◆ cs_syr_coupling_recv_tf_hf()
void cs_syr_coupling_recv_tf_hf ( int  cpl_id,
int  mode,
cs_real_t  h_fluid[]
[in]elt_idsids of coupled elements
[out]t_fluidfluid temperature
[out]h_fluidfluid exchange coefficient
◆ cs_syr_coupling_recv_tsolid()
void cs_syr_coupling_recv_tsolid ( int  cpl_id,
int  mode,
cs_real_t  t_solid[]
[out]t_solidsolid temperature
◆ cs_syr_coupling_send_boundary()
void cs_syr_coupling_send_boundary ( const cs_real_t  h_wall[],
cs_real_t  v_fluid[]
[in]h_wallwall thermal exchange coefficient
[in]v_fluidnear-wall fluid thermal variable
◆ cs_syr_coupling_send_tf_hf()
void cs_syr_coupling_send_tf_hf ( int  cpl_id,
int  mode,
cs_real_t  h_fluid[]
[in]t_fluidfluid temperature
[in]h_fluidfluid exchange coefficient
◆ cs_syr_coupling_send_tsolid()
void cs_syr_coupling_send_tsolid ( int  cpl_id,
int  mode,
[in]t_solidsolid temperature
◆ cs_syr_coupling_set_conservativity()
void cs_syr_coupling_set_conservativity ( int  flag)
◆ cs_syr_coupling_set_explicit_treatment()
void cs_syr_coupling_set_explicit_treatment ( void  )
◆ cs_syr_coupling_set_time_sync_flag()
void cs_syr_coupling_set_time_sync_flag ( int  cpl_id,
int  flag
This will suggest options on the SYRTHES side.
[in]flagsuggested synchronization flags for the SYRTHES side This should be a combination of
  • PLE_COUPLING_TS_MIN (use smallest time step)
  • PLE_COUPLING_TS_LEADER (prescribe time step for all)
  • PLE_COUPLING_TS_FOLLOWER (time step of this domain is ignored by coupled applications)
  • PLE_COUPLING_TS_INDEPENDENT (do not modify time step based on other applications)
By default, no flags are set for constant and local (pseudo-steady) time stepping schemes. With a adaptive time step, the default is PLE_COUPLING_TS_MIN | PLE_COUPLING_TS_FOLLOWER so that the smallest time step of code_saturne domains will be used, but the time step of the SYRTHES domains is ignored (as it does not recompute an adaptive time step, not making it a follower would let it provide the smallest time step encountered, preventing time steps from icnreasing again in the case of multiple fluid domains).
◆ cs_syr_coupling_volume_source_terms()
void cs_syr_coupling_volume_source_terms ( int  field_id,
cs_real_t  st_exp[],
cs_real_t  st_imp[]
[in]field_idfield id
[in,out]st_expexplicit source term
[in,out]st_impimplicit source term
